Сообщение #761 KNR » 29.03.2020, 06:28
I refrain from going out, so I made this to pass the time
Images (12.8 MB) of skins (The collection) - but it's better to try it for yourself
I renamed original files
* M4762- Green (LED) .bin -> M4762 Green (LED).bin
("-" after "M4762" / space before ".bin")
* М4762 - Blue.bin -> M4762 Blue-.bin , and move to folder "M1"
(Russian? "М" -> English "M" / position of "-")
* vu1.bin -> vu-1.bin
* vu2.bin -> vu-2.bin
The following is a personal note, so please leave it at that
<same files (?)>
* Accuphase A-46 DO 1.bin <=> Accuphase A-46 HD 1.bin
* Accuphase A-46 DO 2.bin <=> Accuphase A-46 HD 2.bin
* ELECTRIC1.bin <=> Test1.bin
* ELECTRIC2.bin <=> Test2.bin
* M136.bin <=> m136w.bin
* M68504 (for CompactOne).bin <=> M68504 (for CompactOne)-1.bin
* pifco.bin <=> stock_moving_coil.bin
* REPLICA vu1.bin <=> vu-1.bin
* REPLICA vu2.bin <=> vu-2.bin
* Rockruepel 1.bin <=> Rockruepel DO 1.bin
* Rockruepel 2.bin <=> Rockruepel DO 2.bin
<similar / related skins>
* 1LE <=> LE
* 7inch_3 <=> nik320d
* Accuphase A-46 <=> neutron_light_b <=> ppl
* AKAI (mod DarkOne) <=> Roberts
* bb <=> ww
* Blue- <=> Gray
* Снежеть 110 <=> M68502 (for DarkOne)
* FM-Stereo <=> Stereo-FM3
* M68502 <=> souz110 <=> Soyuz Black
* moving_coil <=> pifco = stock_moving_coil
* vst <=> white
etc.
KNR
С нами: 6 лет 7 месяцев
Сообщение #762 KNR » 31.03.2020, 13:27
Regarding "The collection"
Rename because it doesn't appear in the menu
* Hartmann & Braun1.bin -> Hartmann & Braun-.bin
* Hartmann & Braun2.bin -> Hartmann & Braun--.bin
<similar skins>
* 06-2013 <=> neutron_v062013
* 2vladj <=> FS light
_______<=> Hartmann & Braun
* BPhilmore <=> Philmore
* с4202 <=> Ц4202 (mod DarkOne)
* Foxboro <=> TV-7D
* Grundig <=> neutron
* Revox C270 <=> Studer
There may be more
<seem to be similar>
* Blue Sea <=> Voltcraft_40kV
* M4762 <=> spellman
* Onkyo <=> Yamaha 2002 (mod DarkOne)
* Rebrand <=> t
* Classic 2 (for DarkOne) #2 <=> spl (for DarkOne)
________________________<=> TL Audio
* Ashdown <=> neutron light
* Sony 2 (mod DarkOne) <=> Studer 169 (for DarkOne)
_____________________<=> Ampex (for DarkOne)
_____________________<=> Молот (mod DarkOne)
_____________________<=> Teletronix (for DarkOne)
_____________________<=> D.W. FEARN (for DarkOne)
_____________________<=> Standard
KNR
The collection
Сообщение #763 Haloweenhamster » 01.04.2020, 10:04
I did notice some looked very similar or the same, all of the DarkOne (DO) mod files will be the same as another vu but tweaked in some way I'm guessing & people might of done the same meter but named it differently, I kept all the ones that looked similar but were different file sizes, different a resolution or that I noticed that the sustain was different
In the 2nd collection;
The M in the file names I did replace as I noticed that they didn't list correctly
I rearranged the M & S folders to keep similar meters together like the M4762 & Sony meters
Renamed a few files that you highlighted in the posts on pg38
The above 2 posts above I'm guessing are for the original collection?
When I've finished work I'll look at the suggestions above & see if any changes are required
Haloweenhamster
С нами: 6 лет 5 месяцев
Сообщение #764 KNR » 01.04.2020, 14:52
Haloweenhamster
I understand only a little English (not Russian at all).
So I'm sorry if I've misunderstood the meaning, or if the sentences are wrong.
I agree with your point of view.
My posts above aren't a suggestion.
For example, I wanted to link "Blue-" to the presence of a different color "Gray".
I think the name given by the author needs to be respected as much as possible.
And I think it's okay to have a file with the exact same content but with a different name.
The post above, "<same files (?) >" is a list of files that have been determined to be identical by the file comparison tool.
KNR
Сообщение #765 MC Web » 01.04.2020, 16:24
Haloweenhamster, вы молодец, что решили собрать все скины для VU Meter в одно место, но один большой архив не совсем удобен и не всем нужен. Помимо архива, гораздо удобнее было бы разместить фото и файлы по отдельности, где каждый выберет то, что ему нужно:
Сообщение #766 epic72 » 02.04.2020, 18:51
Подскажите, кто знает, как этот индикатор называется?
epic72
Сообщение #767 MC Web » 02.04.2020, 19:13
Сбоку, у каждой картинки, название написано.
Сообщение #768 epic72 » 03.04.2020, 04:28
Понял. ок.
epic72
Сообщение #769 KNR » 03.04.2020, 13:19
blackened JVC KD-A22
kutuzof, Я использовал твой образ JVC KD-A22.
Пожалуйста, прокомментируйте, если это неуместно.
Я удалю его.
(kutuzof, I used your image of JVC KD-A22.
Please comment if it's inappropriate.
I'll remove it.)
zip
KNR
Сообщение #770 KNR » 03.04.2020, 15:00
blackened JVC KD-A22, I think it's not good to use it without permission, so I removed it.
KNR
Сообщение #771 kutuzof » 03.04.2020, 15:22
KNR, no problem, use on health, everything is in the public domain. If you still need some sort of source, contact. I still have some left.
С нами: 9 лет 11 месяцев
Сообщение #772 Juri63 » 04.04.2020, 03:43
epic72:Подскажите, кто знает, как этот индикатор называется?
Grundig
Juri63 M
С нами: 8 лет 2 месяца
Technics
Сообщение #773 macarych » 04.04.2020, 08:47
Мрачный вариант.
technics_b.zip
technics.zip
Последний раз редактировалось macarych 04.04.2020, 10:53, всего редактировалось 2 раз(а).
Сообщение #774 KNR » 04.04.2020, 10:44
kutuzof, Thanks.
I'll comment when I need the source.
ZIP
KNR
Сообщение #775 SergPuh.68 » 04.04.2020, 11:05
macarych,привет. Мне как раз мрачный вариант отлично подошел :smile:
С нами: 7 лет 7 месяцев
Сообщение #776 macarych » 04.04.2020, 11:31
Привет, )
Добавлено спустя 8 часов 43 минуты:
Sony TC-K22.zip
Добавлено спустя 15 часов 11 минут:
На основе того что выше
sony cold.zip
sony warm.zip
sony black.zip
Сообщение #777 MC Web » 05.04.2020, 13:12
macarych, привет. :hi:
Раз уж начал делать с разным фоном, то не плохо бы добавить и для DarkOne (19-30-38). Многие используют эту тему и переделывают потом. Если не трудно конечно. :smile:
Сообщение #778 macarych » 05.04.2020, 14:30
OK,
sony darkone.zip
TEAC NR-7CD MOD
Сообщение #779 KNR » 05.04.2020, 18:11
Original image, I can't set it any further to the left than -50dB.
ZIP
KNR
Сообщение #780 macarych » 05.04.2020, 18:35
KNR, look, since for me this is not a precise measurement tool, but just a visualization, in such cases I stretched -25 decibels to the end of the scale, to -60 decibels. Similarly up from zero to the side +
