foobar2000 под Android
Список разделов foobar2000 foobar2000 Mobile Edition
Описание: Мобильная версия для Android и iOS
Сообщение #121 VEG » 29.09.2024, 19:51
1.6 released on 2024-08-20
  • Added SMB network share support using libsmb2.
  • New network share credentials management system, no more user:password in share address needed.
  • Media Servers page now uses new network location picker to add/edit addresses.
  • Prettier display of network share names, "share on server" style instead of raw URL.
  • Made remember last used browse/playback page across app restarts.
  • Implemented TV remote navigation in skinned playback screen.
  • Fixed media library merging albums & artists with similar but differently capitalized names. Your library might need rescanning (toggle folders off and back on) for this to take full effect.
  • Added toggle for asymmetric search matching.
  • Dropped support for very old devices. Lowest supported operating system is Android 7 (API 24).
1.6.1 released on 2024-08-28
  • Fixed Media Servers page regressions.
  • Fixed dynamic track title reliability regressions since 1.5 series.
  • Fixed album artist not set for albums with multiple album artists, resulting in multiple albums with same names being merged into one.
  • If playing Matroska file with chapters as one track, individual chapter titles are now shown.
  • Internet radio streaming reliability improvements.
  • TV: Fixed longpress crash in some views.
  • TV: Fixed radio station [x] not being accessible with remote d-pad.
  • Fixed missing permission flags resulting in console errors about foreground modes.
С нами: 13 лет 7 месяцев
Сообщение #122 VEG » 29.09.2024, 19:53
Кажется, после последних обновлений радио стало нормально работать. Ещё пару месяцев назад оно периодически прерывалось и останавливалось в дороге при малейших проблемах с соединением (например, при переходе с Wi-Fi на мобильную сеть и обратно).
Сообщение #123 VEG » 30.09.2024, 20:09
1.6.2 released on 2024-09-30
  • Restored ability to manually input UPnP media server URLs.
  • When turning console logging on, current backlog is now saved.
  • If internet radio stream is stuck at 0:00, clicking same radio station again restarts it rather than doing nothing.
  • Fixed skinned playback view showing nonsensical remaining time for internet radio streams.
  • Made Media Servers page automatically search local network for SMB and FTP servers.
  • Updated invalid filename character criteria; uploading unsupported filenames via FTP should fail more gracefully.
  • Fixed Matroska embedded cover display.
  • Fixed inaccurate timestamps (milliseconds zero'd) in console logs.
  • Reverted 1.6 "share on server" naming of shares in Media Library, to show network protocol (SMB or FTP or other) used.
Сообщение #124 VEG » 18.10.2024, 18:40
1.6.3 released on 2024-10-18
  • Fixed a bug preventing scanned ReplayGain info from being used, if not written to file tags.
  • Fixed various UPnP related bugs; latest version of Gerbera server is now supported.
  • Added tweak options to disable auto discovery of FTP & SMB servers.
  • Updated RAR extraction code to the latest official code release.
  • Fixed a bug that could cause certain playlist manipulation operations to crash.
Сообщение #125 VEG » 11.11.2024, 07:20
1.6.4 released on 2024-11-10
  • Workaround for relative URLs in UPnP server replies.
  • Added option to disable pictures in folder browsing views.
  • Fixed foo_upnp stream looping regression.
  • Fixed various issues with manually-entered UPnP media servers, allowed editing of existing entries, made utilize new user/password system.
  • Fixed UPnP incompatibility with Logitech Music Server.
  • Fixed Ogg VBR bitrate display regression from 1.6.3.
Сообщение #126 Foobik2K » 07.12.2024, 22:42
Foobik2K:не отображаются обложки на экране проигрывания MP3-треков в последней стабилке
Проблема решилась самостоятельно при переходе на 1.6.4.
Foobik2K
Сообщение #127 VEG » 17.12.2024, 22:48
1.6.5 released on 2024-12-17
  • Fixed startup lockup when last browsed location was an inaccessible SMB network share.
  • Fixed a bug that caused authentication errors when using new network credentials system with FTP folders.
  • Slightly updated TV dim screen formatting, no more "unknown artist" prefix.
Сообщение #128 VEG » 27.12.2024, 20:01
1.6.6 released on 2024-12-27
  • Made media indexing use less system resources.
Сообщение #129 VEG » 20.03.2025, 20:01
1.6.7 released on 2025-03-20
  • Fixed crashing on malformed playlists.
  • Fewer HTTP requests per internet radio stream open.
  • Fixed HLS radio starting playback at wrong timestamp.
  • Made printer objects not show in SMB shares.
  • Fixed incorrect seeking in chained Ogg files.
  • Fixed a bug causing spurious "library indexing in progress" prompts.
Сообщение #130 VEG » 01.05.2025, 20:13
1.6.8 released on 2025-05-01
  • Fewer library indexing prompts.
  • Fixed missing HTTPS connect timeout, improved internet radio error recovery.
  • Made now-playing album artist info reported to the system.
  • Utilized new Android 11+ methods to detect mass storage, should fix issues with external disks on Android TV.
Сообщение #131 VEG » 06.07.2025, 20:17
1.6.9 released on 2025-07-06
  • Various stability fixes.
  • Skinning: Fixed [remaining] not being updated correctly.
2.25 preview
  • New versioning scheme in sync with desktop foobar2000.
  • Database format changed, now allows any number of artists/genres/etc per track. Your library will be re-indexed on first run.
  • Built-in UPnP media renderer, both client (play to another device) and server (be controlled by another device).
    • Other foobar2000 instances on your local network, with UPnP remote control feature active, will be listed as output devices.
    • foobar2000-to-foobar2000 playback shows tags with album covers on the other end, using Ogg FLAC as stream container.
  • New default skin icons based on Google Material icon set.
  • Reworked settings page.
  • New audio output implementation, using Google Oboe library, can choose between available audio output devices.
  • Allowed each track of an album to have a different attached cover (before same cover would be shown for all tracks in an album).
  • Skin formatting: added [system_time] and [system_time_seconds].
  • Many smaller changes and tweaks.
Сообщение #132 VEG » 13.09.2025, 13:20
2.25.1 released on 2025-09-11
  • Made folder pic sourced covers shown again for icons when browsing by folder.
  • Fixed 2.25 regression causing missing cover art when playing music from folders rather than library views.
Сообщение #133 VEG » 22.09.2025, 20:50
2.25.2 released on 2025-09-22
  • Fixed incorrect handling of non-alphanumeric characters in network passwords.
  • Fixed lockups with unresponsive UPnP server bookmarks on main page.
  • Fixed WebP covers not showing.
  • Made asymmetric unicode search OFF by default.
  • Use plain case insensitive matching for preferences search - asymmetric search was hard to use with auto capitalization of first typed word.
Сообщение #134 VEG » 04.10.2025, 21:26
2.25.3 released on 2025-10-04
  • Media Servers page: use new network folder picker for adding bookmarks.
  • Fixed crash when trying to unpair TuneFUSION source.
  • Restored compatibility with some http://user:pass@host URLs entered in versions prior to 2.25.2.
Сообщение #135 VEG » 05.11.2025, 05:02
2.25.4 released on 2025-11-04
  • Fixed incorrect rendering of skin volume slider element.
  • Fixed missing "download" command for WebDAV resources.
Сообщение #136 VEG » 16.11.2025, 20:21
2.25.5 released on 2025-11-16
  • FTP server no longer shows network library folders.
  • FTP server no longer kicks client when a file isn't accessible.
Сообщение #137 VEG » 08.12.2025, 21:29
2.25.6 2025-12-08
  • Fixed a bug in library indexing that causes Album Gain values not to be read into the database. To correct missing ReplayGain info, folders must be forcibly reindexed, by disabling & re-enabling in library settings.
  • Made current live console log downloadable via FTP server.
  • Fixed some rare crash bugs.
Вернуться в foobar2000 Mobile Edition
