Сообщение #2541 Ozi » 03.01.2019, 16:48
var DT_TOP = 0x00000000;
var DT_CENTER = 0x00000001;
var DT_VCENTER = 0x00000004;
var DT_WORDBREAK = 0x00000010;
var DT_CALCRECT = 0x00000400;
var DT_NOPREFIX = 0x00000800;
var DT_SINGLELINE = 0x00000020;
var DT_END_ELLIPSIS = 0x00008000;
var DT_WORD_ELLIPSIS = 0x00040000;
var g_text;
var g_font = gdi.Font("kroeger 05_55", 8);
var ww = 0, wh = 0;
var g_textcolor = 0x00787878;
var g_backcolor = 0xffffffff;
var g_need_calc = true;
var g_textheight = 0;
var g_offset = 0;
var g_drag = false;
var g_drag_x = 0;
var g_textwidth;
var title_tf = fb.TitleFormat("%title%");
var album_tf = fb.TitleFormat("%album%");
var artist_tf = fb.TitleFormat("%artist%");
var artist;
var title;
var album;
// START
function on_size() {
reset();
if(fb.IsPlaying) on_playback_new_track();
function on_playback_new_track(){
g_metadb = fb.GetNowPlaying();
artist = artist_tf.EvalWithMetadb(g_metadb);
title = title_tf.EvalWithMetadb(g_metadb);
album = album_tf.EvalWithMetadb(g_metadb);
var g_text = title + " - " + artist + " - " + album;
g_textwidth = gr.CalcTextWidth(g_text, g_font);
if (g_need_calc) {
calc();
if(fb.IsPlaying) {
gr.GdiDrawText(g_text,g_font, g_textcolor, g_offset, 1, ww - g_offset, wh, DT_VCENTER | DT_END_ELLIPSIS | DT_NOPREFIX | DT_SINGLELINE);
function on_mouse_lbtn_down(x) {
g_drag = true;
g_drag_x = x;
function on_mouse_lbtn_up(x) {
g_drag = false;
g_offset=0;
function on_mouse_move(x) {
if (g_drag) {
applyDelta(x - g_drag_x);
g_drag_x = x;
function on_mouse_wheel() {
reset();
function calc() {
// Using a temp IGdiGraphics interface
// Calculate
arr = temp_gr.GdiDrawText(g_text, g_font, g_textcolor, 0, 0, ww, wh, DT_VCENTER | DT_SINGLELINE | DT_CALCRECT | DT_NOPREFIX).toArray();
g_offset = 0;
g_need_calc = false;
// Free the resources
temp_bmp.Dispose();
temp_gr = null;
temp_bmp = null;
function applyDelta(delta) {
var temp = g_offset + delta;
if ((temp <= ww / 2) && (temp >= ww / 2 - g_textwidth)) {
g_offset = temp;
function reset() {
g_need_calc = true;
g_offset = 0;
Ozi M
Сообщение #2542 Marakobes » 03.01.2019, 21:11
kgena_ua:
- добавлена возможность сохранения в папку с исполнителем (см. меню, тестирую);
[b]
С НАСТУПАЮЩИМ НОВЫМ ГОДОМ
УРА!
Добавьте функционал для ковриков, о котором я писал в декабре (отображение папки Covers в папке Альбома и папки Images в папке Исполнителя), хочу сделать две отдельные панели для просмотра того и другого по отдельности
Marakobes
С нами: 14 лет
Сообщение #2543 kgena_ua » 17.01.2019, 18:29
MC Web:Раньше была возможность выбора отображения некоторых пунктов в основном меню
Привет, MC Web
Была возможность, только реализовано было через одно место. :smile: Мне не нравится. Есть другая идея, но пока не получается.
Marakobes,
нормально работает
Сообщение #2544 MC Web » 17.01.2019, 19:25
kgena_ua, привет.
В ЛС не заглядываешь ?
Сообщение #2545 Marakobes » 19.01.2019, 10:26
kgena_ua, привет, в @name "Biography, Albums, Similar and title artist info. www.last.fm" // @version "30122018"
прослушал один альбом, в панели отображалась фото исполнителя, не понравилось - удаляю всю папку, вместе с графикой в "lastFM", запускаю следующий альбом ДРУГОЙ группы, в панели отображается старая физиономия прежней, удаленной тетки, при чем текстовая информация изменилась как и положено
Обновилось только после перезапуска плеера
да нет, вроде пашет, может у меня чего
Marakobes
С нами: 14 лет
Сообщение #2546 kgena_ua » 20.02.2019, 20:01
Сделал такой файл ля очистки временных интернет файлов
clear temporary Internet files.rar
Сообщение #2547 vladj » 21.02.2019, 12:46
Интересно дождусь-ли когда-нибудь полного запрета записи на винт, а только в оперативу? А то приходится при тесте какой-либо сборки затаскивать её в рам диск и запускать там...благо при перезагрузке у меня снова в работе основная, т.к. образ раздела рам на винт не сбрасывется. А так даже если и не включена панель био, всё-равно при каждом изменении исполнителя био пишется в темпоральную папку.
Сообщение #2548 megane68 » 21.02.2019, 15:30
vladj, вроде ui hacks до сих пор актуален и решает эту проблему.
Или я не прав?
Кстати, нескромный вопрос: "Сколько Вы думаете прожить, пока ваш ssd не покроется плесению и не скажет "ну ёкарный бабай, запиши наконец на меня хоть плейлист какой-нибуд?ь"
Сообщение #2549 vladj » 21.02.2019, 23:34
megane68:vladj, Сколько Вы думаете прожить, пока ваш ssd не покроется плесению и не скажет
В машине много лет уже стоит mSATA 15 Gb, сколько-то занимают винда и программы...диагностика, электронная панель приборов. При таком объёме естествено волнуюсь. На ещё 3-х компах стоят 60-ки и только в одном 240, вот его надолго хватит, возможно меня переживёт. Под рам диск обычно выделяю 700Mb, где браузер и одна из сборок ....плюс темпы. А вот в планшете с виндой всё распаяно, износятся ячейки и железка на выброс.
Сообщение #2550 stalk:er » 10.03.2019, 17:55
Парни а как в скрипте kgena_ua - Get Covers (Artwork) radio logos, сделать, чтобы отображалась не одна дефолтная картинка, а дефолтная картинка из папки соответствующая формату файла?
stalk:er M
Сообщение #2551 Marakobes » 18.03.2019, 13:56
kgena_ua:Сделал такой файл ля очистки временных интернет файлов
спасибо. Редко Вы бываете здесь (( жду добавление возможности отображения ковриков в заранее определенной папке (в папке альбома) и отображение фото исполнителя (в папке соответсвующей %Artist%)
Marakobes
С нами: 14 лет
Сообщение #2552 Cerberus » 15.04.2019, 23:46
kgena_ua, Привет! Хочу в сборку LUR внедрить твой скрипт но выдает ошибку в чем может быть проблема?
Вопрос решился с последней версией скрипта)
Cerberus
С нами: 9 лет 10 месяцев
Сообщение #2553 Cerberus » 16.04.2019, 22:00
kgena_ua, Привет! подскажите как вот это убрать (скрин 1) и оставить только Биографию (скрин 2). так сказать, что б ничего лишнего)
Cerberus
Сообщение #2554 MC Web » 20.04.2019, 15:56
Cerberus, самое оптимальное поставить более раннюю версию Biography & Albums & Similar artist info. www.last.fm, например 15122017:
Сообщение #2555 Cerberus » 20.04.2019, 22:02
MC Web:Cerberus, самое оптимальное поставить более раннюю версию
Ранние версии не подходят под JSplitter. Помогите подправить этот скрипт (вложение 1 )он меня полностью устраивает.
Biography, Albums, Similar artist info. www.last.fm 030322018.zip
Cerberus
Сообщение #2556 Cerberus » 25.04.2019, 20:46
Привет! а куда kgena_ua пропал?
Cerberus
Сообщение #2557 Stasila » 04.05.2019, 13:01
скрипт биографии не работает(
Добавлено спустя 4 минуты 18 секунд:
Несколько дней не работал и вдруг только что заработал :eek: :smoke:
Stasila
Сообщение #2558 romarioxxx » 19.05.2019, 15:04
Stasila, Та же история, ни на русском ни на английском не выводится.
romarioxxx
С нами: 9 лет 3 месяца
Сообщение #2559 vladj » 19.05.2019, 20:38
На 14112016 прекрасно работает :smile:
Сообщение #2560 romarioxxx » 19.05.2019, 22:38
vladj, а мне кажется дело не скриптах, а в провайдере, поскольку Last.fm в браузере тоже е открывается (только в Опере с VPN). Версия скрипта 01032017, на 14092018 тоже не хочет.
romarioxxx
