foobar2000 v1.6.1+
Сообщение #1 VEG » 02.09.2020, 15:09
Вышла финальная версия foobar2000 v1.6.1! Предыдущая версия: foobar2000 v1.6.0. Версия для Windows XP: foobar2000 v1.5.6+.
  • Added support for HLS: HTTP Live Streaming. To use, add internet M3U8 file through Add Location dialog.
  • Enabled icy-metadata support for Ogg FLAC internet radio streams.
  • Updated Properties / ReplayGain page layout if editing a single file.
  • Improved Properties dialog performance, list of autocomplete entries is populated asynchronously.
  • Enabled embedded album art loading from raw .AAC files with ID3 tags.
  • Updated FFmpeg to 4.3.1.
  • Added support for playing Matroska A_MS/ACM content.
  • Fixes for rare AAC codec configurations that FFmpeg doesn't fully support - an add-on decoder can override the built-in one for such special cases.
  • Decoders are now made aware of output sample rate (from Windows Mixer settings) and can decode certain formats directly to the intended sample rate, skipping potential resampling steps.
  • Fixed "fade on manual track change" setting not being used since version 1.6. (beta 6)
  • Changing volume no longer affects Windows Mixer sliders; restarting foobar2000 no longer resets Windows Mixer slider to 100%. (beta 7)
  • Mitigated crash when initiating drag&drop of a very large number of songs (such as Album List "all music"). (beta 8)
  • Enabled support for 7-zip archives using PPMd compression. (beta 8)
Автор темы, Администратор
С нами: 14 лет 5 месяцев
Сообщение #141 OlolOшник » 13.08.2021, 22:15
Azaza:https://hydrogenaud.io/index.php?topic=121356.0
Спасибо за ссылку, теперь все стало ясно!
OlolOшник
С нами: 5 лет 1 месяц
Сообщение #142 Crescendo » 13.08.2021, 23:46
В новой версии над аудиоинтерфейсами, помеченными как [Exclusive], находятся такие же аудиоинтерфейсы, но без приписок, в связи с чем вопрос: это DirectSound или WASAPI Shared?
Crescendo M
Сообщение #143 Azaza » 14.08.2021, 00:30
Crescendo:это DirectSound или WASAPI Shared?
WASAPI Shared
С нами: 10 лет 1 месяц
Сообщение #144 postED » 14.08.2021, 01:50
Crescendo, это WASAPI Shared. Начиная с версии 1.6 вывод через DirectSound отсутствует.
Сообщение #145 rtrtrt111 » 16.08.2021, 02:25
а есть русско язычная версия foobar2000 v1.6.7 ?
rtrtrt111
С нами: 8 лет 8 месяцев
Сообщение #146 VEG » 01.09.2021, 08:36
Официально русской версии foobar2000 нет.
foobar2000 v1.6.8
Сообщение #147 VEG » 07.10.2021, 15:19
Вышла финальная версия foobar2000 v1.6.8!
  • Fixed visual glitches when scrolling lists horizontally with mouse wheel through Logitech software.
  • Improved output format negotiation with exclusive output.
  • Fixed failure to install components from store-mode (uncompressed) zip archives.
  • Improved handling of malformed FLAC files, prevented crash from too many cuesheet entries.
  • Correct reporting of AC3 channel count in MP4 files even without AC3 component installed (before it would incorrectly report stereo).
  • Allowed UTF-8 cuesheets without UTF-8 header.
  • Fixed htmlspecialchars misuse in component update list / component page link.
  • Mapped MP4 @mvn field to "movement name".
  • Prevented the same folder from being added more than once to the Media Library.
  • Properties dialog: deferred logging of user-entered field names for the dropdown list until the tags are saved, effectively preventing typos from being remembered.
  • Fixed a bug causing alt+f4 (and possibly other keyboard events) to be disregarded if mouse pointer is above specific interactive portion of a window (list controls, buttons in editboxes).
  • Improved handling of files with malformed APE tags - some files were entirely unplayable.
  • More thorough 'remove tags' for Vorbis, Opus and Musepack.
  • Fixed text truncation in ReplayGain Scanner preferences page.
  • Made possible to add attached pictures by drag and drop to relevant Properties dialog page.
Сообщение #148 Гармонист » 10.10.2021, 11:41
А где ссылка на "финальная версия foobar2000 v1.6.8!"? Только бетта 2.
Гармонист
Сообщение #149 LUR » 11.10.2021, 04:47
Гармонист:А где ссылка на "финальная версия foobar2000 v1.6.8!"? Только бетта 2.
Действительно.
С нами: 13 лет 10 месяцев
Сообщение #150 VEG » 11.10.2021, 08:52
Ух, походу меня проглючило. Почему-то показалось, что был релиз =) Заполнял в дороге с телефона, может поэтому. Исправил.
Сообщение #151 VEG » 14.10.2021, 07:24
beta 3
  • Made possible to add attached pictures by drag and drop to relevant Properties dialgo page.
Сообщение #152 VEG » 18.10.2021, 17:19
Beta 2
  • Fixed Properties crash regression from beta 1
Beta 3
Beta 4
  • Addressed large playlist scrolling bugs caused by Logitech software bug workaround introduced in beta 1.
Сообщение #153 VEG » 21.10.2021, 11:09
Beta 5
  • Addressed unnecessary album art reloads on tag edit, playcount increment, etc introduced in beta 1.
Сообщение #154 VEG » 23.10.2021, 09:43
Beta 6
  • Addressed failure to parse tag blobs in tag_processor since beta 1 caused by another fix, causing some add-ons to malfunction.
Сообщение #155 matss » 28.10.2021, 16:31
Здравствуйте ! Установил бесплатную версию Foobar2000 v1.6.8 beta6, пытался подключить транспорт (для ЦАП) Amanero - OEM Combo384 to I2S/DSD.
В общем в настройках программы не могу разобраться.
matss M
С нами: 4 года 11 месяцев
Сообщение #156 Гармонист » 09.11.2021, 01:01
Заметил, что на одном треке FLAC в одном месте происходит слабый щелчок. Причем иногда бывает, что щелчка нет и он может быть разной громкости. Такое впечатление, что попадает какая то случайная информация. Версию 1.6.8 пока не ставил. Вроде в ней есть сообщение об устранении сбоев при воспроизведении FLAC.
Гармонист
Сообщение #157 VEG » 09.11.2021, 14:59
Вышел релиз, вместе с новым foobar2000 v1.5.8 для Windows XP.
Сообщение #158 Гармонист » 09.11.2021, 18:48
"Вышел релиз, вместе с новым foobar2000 v1.5.8 для Windows XP.". А случайно 1.6.8 финал не вышел? Чем черт не шутит.
Гармонист
Сообщение #159 t830x » 09.11.2021, 18:51
Гармонист, а в самое первое сообщение поднять глаза?
t830x M
С нами: 14 лет 4 месяца
Сообщение #160 Гармонист » 09.11.2021, 20:29
Так это "первое сообщение" от 07.10.2021, 16:19 и тогда точно финальной версии не было и поэтому смотреть туда не целесообразно.
Гармонист
