foobar2000 v1.6.1+
Сообщение #1 VEG » 02.09.2020, 15:09
Вышла финальная версия foobar2000 v1.6.1! Предыдущая версия: foobar2000 v1.6.0. Версия для Windows XP: foobar2000 v1.5.6+.
  • Added support for HLS: HTTP Live Streaming. To use, add internet M3U8 file through Add Location dialog.
  • Enabled icy-metadata support for Ogg FLAC internet radio streams.
  • Updated Properties / ReplayGain page layout if editing a single file.
  • Improved Properties dialog performance, list of autocomplete entries is populated asynchronously.
  • Enabled embedded album art loading from raw .AAC files with ID3 tags.
  • Updated FFmpeg to 4.3.1.
  • Added support for playing Matroska A_MS/ACM content.
  • Fixes for rare AAC codec configurations that FFmpeg doesn't fully support - an add-on decoder can override the built-in one for such special cases.
  • Decoders are now made aware of output sample rate (from Windows Mixer settings) and can decode certain formats directly to the intended sample rate, skipping potential resampling steps.
  • Fixed "fade on manual track change" setting not being used since version 1.6. (beta 6)
  • Changing volume no longer affects Windows Mixer sliders; restarting foobar2000 no longer resets Windows Mixer slider to 100%. (beta 7)
  • Mitigated crash when initiating drag&drop of a very large number of songs (such as Album List "all music"). (beta 8)
  • Enabled support for 7-zip archives using PPMd compression. (beta 8)
Автор темы, Администратор
С нами: 14 лет 4 месяца
foobar2000 v1.6.16
Сообщение #181 VEG » 16.01.2023, 15:27
Вышла финальная версия foobar2000 v1.6.15, и следом за ней v1.6.16!
  • Maintenance release with changes backported from 2.0 series.
  • Less DSP reinitializing when cycling played tracks etc.
  • Fixed crash after loss of audio output device while playing.
  • RIFF64 format reading bug fixes.
  • Fixed playlist column layout changes not being remembered in certain scenarios.
  • Converter: Fixed very old bugs in AU writer.
  • Less strict reading of AIFF format.
  • Media Library: Don't report non-audio files (such as pictures or text) inside archives as indexing errors.
  • Fixed problems with accessing some non-UTF8-compliant FTP servers.
  • (v1.6.16) Reverted 1.6.15 optimization with fast DSP reinitialization on manual track change.
    This behavior breaks many third party components and can't be enabled by default.
    It's now available as an option because it improves performance when using heavy-to-initialize DSPs such as new VST adapter.
Сообщение #182 main user » 02.04.2023, 12:13
Подскажите, плиз. Фубар 1.6.11.
Говорю о сравнении встроенного wasapi [exclusive] с версии 1.6.7 и плагина foo_out_wasapi.fb2k-component.
Когда установлен плагин, в настройках Фубара - Расширенные (Advanced) - есть пункты - Воспроизведение - Вывод WASAPI, и там push/event, размер аппаратного буфера, приоритет процесса...
Когда плагина нет, только встройка wasapi, тогда в настройках - Расширенные (Advanced) - вообще нет пункта/слова WASAPI. Есть только - Эксклюзивные корректировки вывода, размер аппаратного буфера. Всё. push ли, event ли - неизвестно. Где и как менять/регулировать это - неизвестно.
Так и должно быть?
main user
С нами: 3 года 7 месяцев
Сообщение #183 Azaza » 02.04.2023, 12:27
main user:push ли, event ли - неизвестно. Где и как менять/регулировать это - неизвестно.
По умолчанию Push. Если хочешь Event, то ставишь галки "Exclusive output overrides" И "Use event".
С нами: 10 лет
Сообщение #184 main user » 02.04.2023, 12:43
Azaza, да я об этом читал тут выше.
Но у меня нет этого почему-то. "Exclusive output overrides" - это есть. "Hardware buffer..." есть.
Когда ставишь галку на "Exclusive output overrides" никакого пункта "Use event" не появляется вообще. Все как и было. В чем может быть проблема?
Добавлено спустя 1 минуту 6 секунд:
Т.е. умолчание не меняется никак...
Добавлено спустя 15 минут 32 секунды:
Я уже и настройки сбрасывал. Замкнутый круг какой-то. Галка "Exclusive output overrides" вообще ничего не меняет/не дает.
Получается, что мне лучше работать именно с внешним плагином, чем с встроенным WASAPI [exclusive]?
main user
Сообщение #185 Azaza » 02.04.2023, 13:01
main user, в строке Filter (там , где у меня на скрине "exclus") при этом что-то набрано?
С нами: 10 лет
Сообщение #186 main user » 02.04.2023, 13:04
Azaza, я уже по всякому пробовал. И набирал в поиске, и просто находил нужный пункт (там чисто). Это ничего не меняет.
Пункт "Exclusive output overrides" есть. По умолчанию без галки. Пункта "Use event" нет. Галка ничего не дает/не меняет от слова совсем.
Добавлено спустя 4 минуты 40 секунд:
Я уже и не знаю... Может надо после моих упражнений/сравниваний этих wasapi что-то в реестре Windows чичтить? Хотя, сомнительно.
фубар, кстати, портативный.
main user
Сообщение #187 main user » 13.05.2023, 22:56
А чем оргументировано то, что теперь при установке нельзя удалить (снять чекбокс) на стандартных DSP (которые со времен царя Гороха входили в состав Фубара)?
Раньше всю эту ненужность можно было не устанавливать.
Добавлено спустя 42 минуты 8 секунд:
Такой (может быть дилетантский) вопрос.
Чем Kernel Streaming хуже Wasapi exclusive? Путь такой же короткий (если не короче). Если есть возможность такого вывода. Главное, чтобы звуковая карта/ЦАП поддерживали (а в Windows поддерживается и в 10, только не документируется официально)
main user
Сообщение #188 ManikManik2011 » 13.05.2023, 23:41
main user:Чем Kernel Streaming хуже Wasapi exclusive?
Как по мне ничем, пользовался и DSD ASIO и просто ASIO и DirectSound и KernelStreaming и WASAPI и WASAPI Exclusive. У WASAPI звучание по приятнее.
ManikManik2011 M
С нами: 3 года 4 месяца
Сообщение #189 Azaza » 14.05.2023, 00:12
main user:А чем оргументировано то, что теперь при установке нельзя удалить (снять чекбокс) на стандартных DSP (которые со времен царя Гороха входили в состав Фубара)?
https://www.foobar2000.org/changelog
Standard DSP Array is no longer an optional component, as it's required for new WASAPI output to work correctly.
Тем, что при его использовании могут происходить всякие чудеса, а может просто не работать. Если работает, и чудеса не происходят, то ничем не хуже.
С нами: 10 лет
Сообщение #190 main user » 14.05.2023, 00:23
Azaza, хм..., вообще интересно каким образом весь тот массив связан с правильностью функционирования Wasapi.
main user
Сообщение #191 Azaza » 14.05.2023, 00:30
main user:вообще интересно каким образом весь тот массив связан с правильностью функционирования Wasapi.
При выводе в общем режиме фубар делает ресемплинг и даунмиксинг при необходимости. Для этого ему нужны DSP.
К слову, весь этот "массив" весит ничтожные 206 КБ в установленном виде.
С нами: 10 лет
Сообщение #192 main user » 11.06.2023, 13:58
Доброго дня. Не знаю где спросить... Наверно где-то обсуждалось, не нашел.
Иногда при воспроизведении идут равномерные щелчки. Какие параметры надо менять? Вывод Wasapi Exclusive.
Один вариант поменять Event на Push. Вроде помогает. Но не всегда.
Что ещё? Размер буфера увеличивать? Это на той же вкладке - Playback/Вывод - Звуковые устройства вывода - Размер буфера?
Ещё что-то может как-то влиять? На вкладке Advanced/Расширенные настройки надо что-то делать?
Добавлено спустя 1 минуту 26 секунд:
Интересует такая вещь. Есть в настройках вкладка Playback/Вывод, там есть размер буфера.
И есть в Advanced/Расширенные - Вывод WASAPI, и там размеры аппаратного буфера.
Как эти параметры сочетаются друг с другом? Это разные вещи? Везде разные числа стоят. Что, где и как надо устанавливать?
main user
Сообщение #193 Azaza » 11.06.2023, 15:08
main user:Что ещё? Размер буфера увеличивать?
Для начала попробовать увеличить до максимума тот буфер, который в File->Preferences->Playback->output->Buffer length. В настройках WASAPI вернуть буферы к значениям по умолчанию, и, если это WASAPI не встроенный, а через компонент, то в его настройках поставить галку High worker process priority. Убедиться, что в File->Preferences->Advanced->Playback->Thread priority выставлено значение 7 (семь). Там же поставить галку "Use MMCSS" и в "MMCSS mode" вписать Pro Audio.
Если не помогло, то уже поэкспериментировать с переключением Push/Event. С величиной буферов в настройках WASAPI тоже можно попытаться поэкспериментировать, но, чаще всего, можно сделать только хуже, а не лучше.
Попробовать встроенный WASAPI вместо компонента или наоборот, смотря, какой уже используется.
Если WASAPI наладить не удастся, попробовать вывод через ASIO4ALL. При этом в настройках foo_out_asio поставить галку "Run with realtime process priority", а в настройках самого ASIO4ALL выставить максимальный размер буфера, максимальное значение Kernel Buffers и/или Kernel offset. Latency compensation выставить в 0 (ноль), галки все снять. Чтобы увидеть все настройки нужно нажать на кнопку с гаечным ключом. На windows 7 нужно использовать ASIO4ALL версии 2.14.
main user:Это разные вещи?
Да.
С нами: 10 лет
Сообщение #194 main user » 11.06.2023, 16:34
Azaza, в настройках File->Preferences->Playback->output->Buffer length сейчас установлено 1000 мс.
WASAPI не встроенный. В настройках Advanced WASAPI все буферы стоят по умолчанию, не трогал (push - 200 и event - 25). Галка High worker process priority установлена.
В File->Preferences->Advanced->Playback->Thread priority выставлено значение 7 (приоритет потока)
Use MMCSS - галка установлена. MMCSS mode - Audio (Audio и Pro Audio это разные вещи?)
Изначально всегда выставляю Event. Но потом сменил на Push. Вроде бы помогло (в то время, когда делал это). Но сейчас все равно бывают щелчки. Сменю обратно Push на Event и буду пробовать увеличением буфера в настройках править. Мне казалось, что 1000 мс не мало... (вроде бы так и по умолчанию стояло)
main user
Сообщение #195 Azaza » 11.06.2023, 16:45
main user:Audio и Pro Audio это разные вещи?
Да.
К слову, 1000 мс и 30000 мс - это тоже разные вещи, если что.
Последний раз редактировалось Azaza 11.06.2023, 16:49, всего редактировалось 2 раз(а).
С нами: 10 лет
Сообщение #196 main user » 11.06.2023, 16:47
А вообще, чем меньше величина File->Preferences->Playback->output->Buffer length тем лучше (я не про этот частный случай)?
Сейчас выставил 15000 мс (против 1000 изначально). Играет все ровно (тот же материал).
Сейчас буду уменьшать, посмотрю когда начнутся щелчки...
main user
Сообщение #197 Azaza » 11.06.2023, 16:48
main user:А вообще, чем меньше величина File->Preferences->Playback->output->Buffer length тем лучше (я не про этот частный случай)?
Нет.
Чем больше буфер, тем больше задержка изменений в звуке при изменении настроек DSP на лету. Ну и потребление оперативки тем больше, чем больше буфер. Больше никаких негативных эффектов.
Последний раз редактировалось Azaza 11.06.2023, 16:53, всего редактировалось 1 раз.
С нами: 10 лет
Сообщение #198 main user » 11.06.2023, 16:53
Вообще, чудеса. Темные силы электроники. Тут видимо вообще зависит с какой ноги ноут встанет.
Сейчас вообще вернул буфер к изначальному значению - 1000 мс, WASAPI event. Никаких щелчков.
Добавлено спустя 46 секунд:
А вчера были. :eek:
Добавлено спустя 53 секунды:
Видимо все это эмпирически...
main user
Сообщение #199 Azaza » 11.06.2023, 16:57
Поэтому тестировать нужно при длительном использовании. За 5 минут ничего не поймёшь.
С нами: 10 лет
Сообщение #200 main user » 08.08.2023, 11:09
Подскажите, плиз. Где в настройках Фубара настраивать предварительную буферизацию в память?
Это наверно тут (в Дополнительных настройках) - Настройки - Extended - Playback - Full file buffering up to (kB)? Правильно?
Добавлено спустя 1 минуту 14 секунд:
В основных настройках ничего подобного не увидел.
main user
