foobar2000 v1.6.1+
Сообщение #1 VEG » 02.09.2020, 15:09
Вышла финальная версия foobar2000 v1.6.1! Предыдущая версия: foobar2000 v1.6.0. Версия для Windows XP: foobar2000 v1.5.6+.
  • Added support for HLS: HTTP Live Streaming. To use, add internet M3U8 file through Add Location dialog.
  • Enabled icy-metadata support for Ogg FLAC internet radio streams.
  • Updated Properties / ReplayGain page layout if editing a single file.
  • Improved Properties dialog performance, list of autocomplete entries is populated asynchronously.
  • Enabled embedded album art loading from raw .AAC files with ID3 tags.
  • Updated FFmpeg to 4.3.1.
  • Added support for playing Matroska A_MS/ACM content.
  • Fixes for rare AAC codec configurations that FFmpeg doesn't fully support - an add-on decoder can override the built-in one for such special cases.
  • Decoders are now made aware of output sample rate (from Windows Mixer settings) and can decode certain formats directly to the intended sample rate, skipping potential resampling steps.
  • Fixed "fade on manual track change" setting not being used since version 1.6. (beta 6)
  • Changing volume no longer affects Windows Mixer sliders; restarting foobar2000 no longer resets Windows Mixer slider to 100%. (beta 7)
  • Mitigated crash when initiating drag&drop of a very large number of songs (such as Album List "all music"). (beta 8)
  • Enabled support for 7-zip archives using PPMd compression. (beta 8)
Автор темы, Администратор
С нами: 14 лет 5 месяцев
Сообщение #21 Azaza » 28.09.2020, 20:23
VEG:Changing volume no longer affects Windows Mixer sliders
Поэтому, если вывод не через wasapi exclusive или asio и ползунок для фубара в системном микшере не на 100%, то, действительно, после обновления, можно услышать разницу.
С нами: 10 лет 1 месяц
foobar2000 v1.6.2
Сообщение #22 VEG » 28.09.2020, 20:51
Вышла финальная версия foobar2000 v1.6.2!
  • HLS radio bug fixes.
  • Double clicking album covers in Default User Interface shows full-size picture.
  • Archive reader optimizations; much more efficient handling of uncompressed (store-mode) archives.
  • Drag-and-drop or copy-to-clipboard of large number of tracks no longer copies their plaintext titles.
  • Fixed unresponsive Album List when selecting lots of items.
  • Added workarounds for wrong audio mix format reported by certain buggy soundcard drivers.
  • Added workaround for too quiet playback since removal of Windows Mixer volume slider synchronization in previous versions.
  • Fixed crashing when attempting to read from 7-zip archive that does not exist.
  • Increased playback queue length limit to 256 tracks.
  • Fixed incompatibilities with certain bluetooth headsets introduced in 1.6.1.
  • Fixed incorrect handling of embedded pictures in Speex tags.
  • Fixed incorrect info shown for IMA ADPCM in Matroska.
  • Fixed no error message on failure to update embedded pictures if embedding of pictures is not supported for this file type.
  • Removed nonsensical bit depth info shown with some Matroska files.
  • Cleaned up listed file types in various "import picture" dialogs.
  • Workaround for stuck process if attempting to update foobar2000 while running foobar2000 is busy.
Сообщение #23 sibemol » 29.09.2020, 12:23
улучшения м.б. связаны с этим:
vladj:А то какой-нибудь из плагинов сделал "красивый" звук.
слушаю через асио без плагинов если шо
sibemol
С нами: 6 лет
Сообщение #24 Пряник » 29.09.2020, 14:10
Azaza:Windows Mixer sliders
Тоже подумал что в этом дело. Но регулировки не причём, у меня всё было без плагинов и на 100%. Скорее винда от рождения кривая и чем дальше от неё, тем лучше.
Пряник
С нами: 11 лет 10 месяцев
Сообщение #25 vladj » 29.09.2020, 14:54
sibemol:слушаю через асио без плагинов если шо
А подробней... наушники ? Куда воткнуты ? А то тут уже и для встройки asio сейчас предлагают (имхо, основанные на (не к ночи будь упомянут) суррогатном asio4all).
Сообщение #26 sibemol » 29.09.2020, 19:39
vladj:наушники ?
нет, 5.1 система, карточка asus xonar d1, асио полноценный
sibemol
С нами: 6 лет
Сообщение #27 VEG » 01.10.2020, 12:42
  • Fixed unresponsive Album List when selecting lots of items. (beta 2)
Сообщение #28 imfam » 04.10.2020, 18:54
Кнопка Load не работает
Кнопка Load не работает. Приходится копировать пресет в паттерн вручную. Соответственно не работает выбор пресета в контекстном меню. В версии 1.6.0 тоже. Раньше такого, вроде бы не замечал. Файлов нет в окошке, т.к. их имена уже, как старый паттерн.
imfam M
Сообщение #29 postED » 04.10.2020, 19:31
imfam, все там работает. Туда нужно писать не сам пресет, а его имя (например, Default или Preset 1). Сам пресет пишется собственно только туда, где ему и положено быть - в File name pattern.
1. В поле File name pattern пишется пресет, допустим [%tracknumber%. ][%artist% - ]%title%
2. В поле Presets даем ему название, например Artist - Title
3. Нажимаем Save
4. В поле File name pattern пишется другой пресет, например [%tracknumber%. ]%title%
5. В поле Presets создаем название для этого пресета, например TN. Title
6. Нажимается Save
В списке presets теперь будет два пресета с именами "Artist - Title" и "TN. Title", для загрузки выбираем нужный и жмем Load
Сообщение #30 imfam » 04.10.2020, 20:16
postED, спасибо. Моя ошибка.
imfam M
Сообщение #31 VEG » 06.10.2020, 15:42
  • Added workarounds for wrong audio mix format reported by certain buggy soundcard drivers. (beta 3, beta 4)
  • Added workaround for too quiet playback since removal of Windows Mixer volume slider synchronization in previous versions. (beta 4)
Сообщение #32 VEG » 07.10.2020, 17:08
  • Fixed crashing when attempting to read from 7-zip archive that does not exist. (beta 5)
  • Increased playback queue length limit to 256 tracks. (beta 5)
Сообщение #33 VEG » 11.10.2020, 00:47
Beta 2
  • Fixed missing .webp in stub image picker.
  • Fixed bugs in new image viewer window.
  • Improved Album List performance when selecting lots of item.s
Beta 3
  • Attempted fixes for new default output not working on some machines.
  • Additional output status logging to console.
Beta 4
  • More fixes for new default output not working on some machines,
  • Correct too quiet Windows Mixer volume on first run.
Beta 5
  • Fixed crash when trying to open a non-existent 7-zip archive.
  • Playback queue item limit increased to 256.
Beta 6
  • Fixed wrong error message/status when trying to open a non-existent RAR archive.
  • More default output error logging.
  • Crash if stuck trying to update tags of now playing file for more than one minute, in order to generate crash reports of an apparent rare bug. This change will be reverted for the final version.
Сообщение #34 VEG » 20.10.2020, 15:44
Beta 7
Сообщение #35 t830x » 22.10.2020, 21:53
foobar2000 1.6.2 final
t830x M
С нами: 14 лет 4 месяца
Сообщение #36 VEG » 23.10.2020, 19:16
Релиз.
Сообщение #37 iPhoneSasuke » 23.10.2020, 20:28
Когда 1.6.3?
iPhoneSasuke M
С нами: 11 лет 8 месяцев
Сообщение #38 VEG » 26.10.2020, 20:17
Как только будет готова, так сразу.
Сообщение #39 iPhoneSasuke » 03.01.2021, 01:52
Уже вышла 1.6.3 b1.
Только, список изменений забыли приложить.
Всех с пережитем 2020 года.
iPhoneSasuke M
Сообщение #40 kolobok15 » 03.01.2021, 08:58
1.6.3
Fixed RAR reading crash bug introduced in 1.6.2.
Improved WASAPI compatibility with specific audio devices.
kolobok15
С нами: 13 лет 11 месяцев
