foobar2000 v2.25
Сообщение #1 VEG » 10.05.2025, 00:51
Вышел foobar2000 v2.25! Предыдущая версия: foobar2000 v2.24.
  • Built-in UPnP media renderer, both client (play to another device) and server (be controlled by another device).
    • Other foobar2000 instances on your local network, with UPnP remote control feature active, will be listed as output devices.
    • foobar2000-to-foobar2000 playback shows tags with album covers on the other end, using Ogg FLAC as stream container.
  • Media Library improvements, most notably:
    • Can natively index FTP/WebDAV/SMB network shares.
    • Improved response to enabling/disabling/installing/uninstalling decoders - only reloads info from affected music files.
  • Codecs, most notably:
    • FFmpeg updated to 8.0, added native support for xHE-AAC decoding.
    • Rewritten Ogg FLAC tag handling, properly implemented embedded album art.
    • Fixed ReplayGain tags not being saved in multichapter Ogg/Opus files.
  • Portable install improvements
    • Changed the way relative paths are handled, so cached tags are no longer forgotten after relaunching from a different path.
    • Made possible so specify no-cover pics as relative path to install location.
  • Converter:
    • Enabled RF64 writing.
    • Fixed Converter failing to function until foobar2000 restart after removal of %TEMP%\foo_converter.
  • Other
    • Added preferences page for network share credentials so you don't have to place them in URLs anymore.
    • Made editing DSP settings momentarily lower output latency to make DSPs appear more responsive.
    • Fixed Properties 'rewrite tags' not working if nothing has been edited.
    • Installer is now hi-DPI friendly.
    • Made system file dialogs invoked out-of-process, to avoid stability issues.
  • See release notes for full list of changes.
Автор темы, Администратор
С нами: 14 лет 3 месяца
Сообщение #41 VEG » 23.01.2026, 07:02
2.25.6 released on 2026-01-22
  • Mitigation for "error 380" bug in latest Windows update, which caused specific file manipulations to fail in cloud-synced folders such as OneDrive folder.
  • Fixed MP4/M4A files not being played completely if their tags contain malformed Apple Gapless information.
  • File Operations: Fixed erratic behavior if empty folders can't be removed.
  • Made recover better from fooHelper.exe crash/termination (system file dialogs).
  • Converter: Fixed a bug causing int32 stream to be sent to encoders that don't recognize it if source is float64.
  • Made always write hours and minutes to Ogg chapter mark fields.
Сообщение #42 LUR » 19.02.2026, 17:10
2.25.7 released on 2026-02-19
  • Fixed portable relative path handling bug affecting having portable foobar2000 itself as indexed music folder.
  • Fixed Direct2D visualization race condition bug resulting in random instability.
  • Rebuilt FFmpeg without MSVC /fp:fast, which fixes a mis-compilation bug that resulted in crashing on Wine.
  • Fixed default AccurateRip log save location not being reliably set to scanned album folder.
  • Improved behavior of Advanced Limiter, made sure it resumes outputting bit identical signal after attenuation.
  • Internet Radio: Worked around radio-browser site not working as documented, all tags get fetched again.
  • Fixed a bug in SMB code that prevented password-less user logins (other than guest user) from working.
  • Fixed horrible regression in FPL serialization code that caused nonsensical output when copying or drag&dropping playlist contents between foobar2000 instances using relative paths.
LUR M Онлайн
С нами: 13 лет 8 месяцев
Сообщение #43 VEG » 27.03.2026, 14:57
2.25.8 released on 2026-03-26
  • Fixed lock up on specific playlist + album art + auto sizing column use pattern.
  • Fixed lock up on specific album art tag update operations.
  • More robust radio-browser server discovery.
  • Fixed slow loading of FPL playlists regression.
  • Fixed wrong height & wrong dark mode rendering of popup_message checkbox.
  • Fixed missing URL-decode of WebDAV file names being shown.
  • Album List: Worked around Wine bug #59448, fixed multi selection rendering.
  • Disabled crash report submissions on outdated versions of Wine.
Сообщение #44 LUR » 29.05.2026, 15:14
2.25.9 released on 2026-05-29
  • Restored correct channel mask for 6.1 FLAC.
  • Better remapping of back center channel to 5.1-side speaker setup.
  • Fixed "remove chapters" not working on Ogg files with chapters.
  • Improved WebDAV reliability.
  • Some UPnP bug fixes backported from 2.26 series.
  • Made send Windows version number when checking for component updates, to prevent installation of updates that require specific newer operating system build.
  • Updated zlib to v1.3.2.
  • Fixed some windows discarding multimedia keyboard events.
  • Visual C++ runtime updated.
LUR M Онлайн
Сообщение #45 Гармонист » 02.06.2026, 15:11
Судя по тому, что продолжается развитие 2.25, стабильная версия 2.26 будет еще не скоро.
Гармонист
Сообщение #46 Azaza » 03.06.2026, 00:45
Гармонист:Судя по тому, что продолжается развитие 2.25, стабильная версия 2.26 будет еще не скоро.
Стабильная версия теперь выходит раз в год. "Раз в год" - не фигура речи. Так задумано.
С нами: 9 лет 11 месяцев
Сообщение #47 Гармонист » 03.06.2026, 19:03
Azaza, "Раз в год... Так задумано.". Основанием для новой версии должно быть содержание изменений а не ход времени.
Гармонист
Сообщение #48 VEG » 07.06.2026, 22:35
Ну так за год накапливается достаточно изменений, разве нет?
Сообщение #49 LUR » 26.06.2026, 23:32
2.25.10 released on 2026-06-26
  • Improved implementation of built-in UPnP Media Renderer, implemented gapless playback compatible with popular UPnP control apps.
  • Enabled discovery of OpenHome UPnP devices as output devices.
  • Enabled TLS v1.3 encryption for HTTPS connections.
  • Fixed Ogg/Opus files with single chapter not showing correct track numbers.
  • Fixed Direct2D visualizations getting stuck after GPU driver reinitialization.
  • Updated 7-Zip library to 26.01.
  • Updated UnRAR library to 7.2.6.
LUR M Онлайн
