foobar2000 v0.9.5.1 beta 1
ну чтож господа, тестируем.
    * Improvements to new Default User Interface:
          o New built-in Media Library Search dialog, with advanced autoplaylist creation features.
          o Configurable left/center/right alignment of custom columns in Playlist View.
          o Usability: switching layouts now flashes labels to reduce user confusion.
          o Ability to customize toolbar buttons.
    * New: Warning popup when trying to close foobar2000 while tasks such as conversion or ReplayGain scan are active.
    * Various UI responsivity improvements and speed optimizations; much faster Album List refresh with large libraries.
    * Usability: positions of various dialogs are now remembered, relative to their parent windows.
    * Properties dialog: “Tools” button, “Automatically Fill Values” can now use clipboard as source.
    * Converter clean-ups, ability to manually edit commandline encoder executable paths through Advanced Preferences.
    * WMA handling bug fixes, ability to store arbitrary metadata fields in WMA tags.
    * ID3v2 tagging compatibility improvements.
    * Various bug fixes.
http://foobar2000.org/beta/index.html
