TAK ((T)om's lossless (A)udio (K)ompressor)
Сообщение #1 sanb » 15.04.2007, 13:17
The final release of TAK 1.0.1 [14.04.07]
Features
    * high compression
    * fast compression and decompression speed
    * Streaming support
    * Error tolerance
          o single bit error will never affect more than 250 ms
    * Error detection
          o each frame protected by a 24-bit checksum (CRC)
Pros
    * Fast encoding speed
          o Tak "Extra" encodes as fast as Flac -8 while providing better compression
          o Tak "Turbo" encodes several times faster than FLAC -8 while providing better compression
    * Fast decompression speed (on par with FLAC / WavPack)
    * Good compression levels (on par with Monkey's Audio High)
    * Error Robustness
    * Fast Seeking
TAK wiki
TAK Applications 1.0.1
containing the GUI and command line compressor: TAK_1.0.1.ZIP ( 570.28k )
"входной" плагин (декодер) для Foobar2000 foo_input_tak v0.2.1beta
sanb
Сообщение #2 evil » 25.02.2008, 14:54
The final release of TAK 1.0.3 ((T)om's lossless (A)udio (K)ompressor).
http://www.hydrogenaudio.org/forums/index.php?sho ... 712&st=0&p=535591&#entry535591
Сообщение #3 heckffy » 29.10.2009, 18:49
Давно обновился
TAK V1.1.2 (27.07.2009)
http://www.thbeck.de/Download/TAK_1.1.2.zip
heckffy
Вернуться в Аудиокодеки
