Здравствуйте, пытался на выше упомянутые темы найти что-либо через поиск, не нашел. Если тема повторная, то скажите пожалуйста где это уже обсуждалось в форуме.
Комбинация следующая:
Core (2014-04-11 09:51:08 UTC) foobar2000 core 1.3.2
foo_albumlist.dll (2014-04-11 09:49:46 UTC) Album List 4.5
foo_cdda.dll (2014-04-11 09:49:18 UTC) CD Audio Decoder 3.0
foo_comserver2.dll (2006-07-31 19:13:20 UTC) COM Automation server 0.7 alpha 6
foo_converter.dll (2014-04-11 09:49:20 UTC) Converter 1.5
foo_DeleteCurrent.dll (2008-06-30 15:00:02 UTC) FooBar2000 Delete Current Track 1.0.0.0
foo_dsp_eq.dll (2014-04-11 09:49:32 UTC) Equalizer 1.0
foo_dsp_std.dll (2014-04-11 09:49:24 UTC) Standard DSP Array 1.3
foo_dsp_stereoconv.dll (2007-05-17 23:19:46 UTC) Stereo Convolution 1.0.1
foo_fileops.dll (2014-04-11 09:49:06 UTC) File Operations 2.2.1
foo_freedb2.dll (2014-04-11 09:49:24 UTC) Online Tagger 0.7
foo_input_std.dll (2014-04-11 09:51:10 UTC) Standard Input Array 1.0
foo_popupplus.dll (2008-04-24 20:24:18 UTC) PopUp Plus 20080424
foo_quicksearch.dll (2014-06-27 22:49:37 UTC) Quick Search Toolbar 3.4
foo_rgscan.dll (2014-04-11 09:49:26 UTC) ReplayGain Scanner 2.2.1
foo_ui_columns.dll (2011-02-27 20:23:00 UTC) Columns UI 0.3.8.8
foo_ui_std.dll (2014-04-11 09:51:08 UTC) Default User Interface 0.9.5
foo_uie_albumart.dll (2007-12-15 23:22:24 UTC) Album Art Panel 0.2.7.1
foo_uie_biography.dll (2014-06-19 20:00:32 UTC) Biography View 0.4.2.4
foo_uie_explorer.dll (2010-02-22 13:51:29 UTC) Explorer Tree 2.04.8
foo_uie_sql_tree.dll (2014-07-06 16:30:16 UTC) SQL Tree 1.0.4
foo_unpack.dll (2014-04-11 09:48:52 UTC) ZIP/GZIP/RAR Reader 1.6
foo_vis_shpeck.dll (2014-06-29 01:20:14 UTC) Shpeck - Winamp vis plugins wrapper 0.3.7
foo_w7shell.dll (2010-01-17 03:09:20 UTC) Windows 7 integration 0.2.9.1
foo_wave_seekbar.dll (2014-07-06 02:31:42 UTC) Waveform seekbar 0.2.45
Собственно вопросы.
1) Как в Explorer tree изменить света (выделенной папки, выделенной неактивной папки и т.д.)? Через Preferences > Display > Columns UI > Colours and fonts > Таб: Colours получилось пока настроить только цвет шрифта и заднего фона. У кого-нибудь есть идеи?
2) SQL Tree настроил так, что отображаются папки исполнителей, в них папки альбомов и... все. Можно сделать так, чтобы внутри альбомов в SQL tree отображались отдельные треки (наподобие Explorer tree)?
3) Относительно проблем с пунктом нр. 2: может кто подскажет какую-нибудь другую панель библиотеки? Или может кто знает, как вставить Facets в панель? У меня не получается, только в виде отдельного окна, что для меня крайне неудобно.
Заранее спасибо.
