- Fixed RAR reading crash bug introduced in 1.6.2.
- Improved WASAPI compatibility with specific audio devices.
- Fixed playback queue being flushed when playing a song from library search result. (beta 2)
- Now complains on startup if mixing files from different foobar2000 releases. (beta 2)
- Fixed wrong stream labels in "Select Stream" on Matroska if not all streams were readable by installed decoders. (beta 3)
- Made "Select Stream" dialog show more info about each stream. (beta 3)
- Fixed enter key behavior in "Select Stream" dialog list. (beta 3)
- Various obscure Matroska PCM configurations now decode correctly. (beta 3)
- Converter: Improved long filename support. (beta 3)
- Fixed incorrect behavior of playlist_execute_default_action() method. (final)
