foobar2000 v1.5.8
Сообщение #1 VEG » 09.11.2021, 15:52
Вышла финальная версия foobar2000 v1.5.8! Предыдущая версия: foobar2000 v1.5.7. Эта версия поддерживает Windows XP.
  • Бэкпортированы исправления ошибок из foobar2000 v1.6.8.
  • Fixed visual glitches when scrolling lists horizontally with mouse wheel through Logitech software.
  • Improved handling of malformed FLAC files, prevented crash from too many cuesheet entries.
  • Correct reporting of AC3 channel count in MP4 files even without AC3 component installed (before it would incorrectly report stereo).
  • Fixed htmlspecialchars misuse in component update list / component page link.
  • Fixed a bug causing alt+f4 (and possibly other keyboard events) to be disregarded if mouse pointer is above specific interactive portion of a window (list controls, buttons in editboxes).
  • Improved handling of files with malformed APE tags - some files were entirely unplayable.
  • Backported Matroska tagging code from 1.6 series, many bugs fixed.
  • Converter: Fixed some warning prompts not being possible to permanently disable.
Скачать: https://www.foobar2000.org/old
Автор темы, Администратор
Вернуться в Новости плеера
