- New version numbering scheme: 2.24 for planned stable release year of 2024.
 - Internet radio bug fixes & reliability improvements.
 - Codec & audio format fixes, most notably:
- Implemented Ogg chapter support.
 - MP4/M4A/M4B tagging & chapter manipulation fixes.
 - WAV compatibility fixes; made zero-length WAV files reported as broken.
 - Cuesheet compatibility improvements - allowed absolute path, allowed playback over network.
 - Usability improvements, most notably:
- Fixed inconsistent drag&drop behavior when dragging items between playlists.
 - Made current console backlog saved when toggling logging on.
 - Prevented Media Library search from clearing other playlists with enter key if library selection playlist feature is active.
 - General improvements, most notably:
- New major revision of bitcompare code, improved performance of 64-bit build.
 - Improved stability of hardware-accelerated visualizations.
 - Improved recovery of corrupted configuration data.
 - Converter:
- Mitigation for Converter failures when writing to a Google Drive volume.
 - More detailed error messages for specific file creation errors.
 - Can write multichapter Ogg files after disabling Ogg chaining support.
 - File Operations:
- Suppressed useless secondary progress bar if renaming files.
 - Defer info reload to prevent bugged display of cuesheets after moving whole folder.
 - Added an option to overwrite existing files.
 - Updated recycle bin detection logic, mitigating lag/lockup occurring for some users.
 - Third party code libraries updated.
 - Various other tweaks & fixes, see release notes for full list of changes.
