MilkDrop 2 takes you flying through visualizations of the soundwaves you're hearing. It uses beat detection to trigger myriad psychedelic effects, creating a rich visual journey through sound.
Features
- Uses DirectX 11 for rendering.
- Uses updated libraries.
- vis_milk2 has been upgraded to use more modern C++ alongside DirectX 11. Deprecated or insecure functions have been rewritten and most unused functionality removed.
- Configurable through foobar2000 preferences instead of INI files.
- Supports the Default User Interface (Default UI) only.
- Tested on foobar2000 v2.1.2 (x86 32-bit and x86 64-bit) and Microsoft Windows 11 (Build 22621).
Страница плагина: http://foobar2000.org/components/view/foo_vis_milk2
