foobar2000 v2.26 preview
Сообщение #1 VEG » 10.10.2025, 20:33
Вышел foobar2000 v2.26! Предыдущая версия: foobar2000 v2.25.
  • Improved recovery of malformed UTF-8 text in various tag formats.
  • Made malformed UTF-8 tags text reported in integrity verifier.
  • MP4 tagging improvements:
    • Tagtype info (Apple, Nero)
    • No longer writes Nero tags by default for single chapter files, only for multi chapter where other tagging formats can't store per track tags.
    • Added support for more rarely used Apple tag elements.
    • No longer alters binary structure of Apple tag elements which are not affected by edits.
  • Monkey's Audio decoding moved to FFmpeg, no longer including Monkey's Audio library with foobar2000 setup.
    • You can once again install Monkey's Audio decoder component to replace built-in FFmpeg decoder.
  • New info field: container (MP4, Matroska, Ogg, etc)
  • New title formatting field: %_cpu_arch%
  • Mac: made playlist view receive copy/paste from Finder
  • Mac: New icon from Apple Icon Composer
  • Mac: Built with Xcode 26, enabled macOS Tahoe looks.
  • Mac: Install components by drag&drop from Finder to components list.
  • Mac: Playlist Manager columns can be toggled.
  • Added drag&drop from Internet Radio pages to playlist.
  • Attempt to play a password-protected resource such as radio stream now shows a password prompt.
  • Converter: Better error messages when receiving unexpected data format change in mid-conversion; made discard blank chunks before checking for format match.
  • Equalizer now accepts presets via drag&drop from Explorer/Finder.
  • Workaround for foo_tags issue [being backported to 2.25.x]
  • Workaround for WAV headers claiming zero length [being backported to 2.25.x]
  • Fixed File Operations link vs portable relative paths [being backported to 2.25.x]
Автор темы, Администратор
С нами: 13 лет 8 месяцев
Сообщение #21 LUR » 17.12.2025, 18:25
2025-12-17
  • Mac: Because of erratic behavior of tableview controls on latest macOS, new macOS 26 appearance has been DISABLED. This will be looked into again later.
  • File Operations: Fixed error with renaming files on redirected portable music folders & macOS volumes.
  • Fixed various regressions with network shares in Media Library preferences page.
  • Made new "Play On" accessible in Internet Radio panel context menus.
  • Updated Opus decoder to v1.6.
С нами: 13 лет 1 месяц
Сообщение #22 LUR » 29.12.2025, 05:12
2025-12-28
  • LargeFieldsConfig technology is back - https://www.foobar2000.org/LargeFieldsConfig-v2
  • Enabled WavPack asm optimizations on Windows for slight decoding speedup.
  • Windows: fixed bugs related to copy-paste of file-relative locations in portable installs.
  • Fixed MP4 tag writer corrupting specific kinds of fragmented/streaming MP4 files. Some of these are currently untaggable (fails cleanly). This will be properly fixed soon.
Сообщение #23 LUR » 30.12.2025, 01:37
2025-12-29
  • Fixed recent regression that caused crashes on a fresh profile.
  • Properly fixed tag writing issues on fragmented/streaming MP4 files.
Сообщение #24 VEG » 02.01.2026, 22:27
2025-12-31
  • Mac: Made pass correct realtime/offline flag to Audio Units, fixed specific Audio Unit visualizations not working.
2026-01-02
  • Windows: Worked around Wine crash in IWICBitmapScaler::CopyPixels(), breaking album art view in Properties dialog.
Сообщение #25 VEG » Вчера, 20:41
2026-01-07
  • Made always write hours and minutes to Ogg chapter mark fields.
  • Fixed Properties 'reload info' evading LargeFieldsConfig settings.
  • Replaced libretro resampler with Speex resampler, providing better quality at comparable speeds / better speeds at comparable quality.
  • Windows: Fixed ARDFTSRC resampler settings dialog being inaccessible from certain pages.
Вернуться в Новости плеера
