foobar2000 v2.26 preview
Сообщение #1 VEG » 10.10.2025, 20:33
Вышел foobar2000 v2.26! Предыдущая версия: foobar2000 v2.25.
  • Improved recovery of malformed UTF-8 text in various tag formats.
  • Made malformed UTF-8 tags text reported in integrity verifier.
  • MP4 tagging improvements:
    • Tagtype info (Apple, Nero)
    • No longer writes Nero tags by default for single chapter files, only for multi chapter where other tagging formats can't store per track tags.
    • Added support for more rarely used Apple tag elements.
    • No longer alters binary structure of Apple tag elements which are not affected by edits.
  • Monkey's Audio decoding moved to FFmpeg, no longer including Monkey's Audio library with foobar2000 setup.
    • You can once again install Monkey's Audio decoder component to replace built-in FFmpeg decoder.
  • New info field: container (MP4, Matroska, Ogg, etc)
  • New title formatting field: %_cpu_arch%
  • Mac: made playlist view receive copy/paste from Finder
  • Mac: New icon from Apple Icon Composer
  • Mac: Built with Xcode 26, enabled macOS Tahoe looks.
  • Mac: Install components by drag&drop from Finder to components list.
  • Mac: Playlist Manager columns can be toggled.
  • Added drag&drop from Internet Radio pages to playlist.
  • Attempt to play a password-protected resource such as radio stream now shows a password prompt.
  • Converter: Better error messages when receiving unexpected data format change in mid-conversion; made discard blank chunks before checking for format match.
  • Equalizer now accepts presets via drag&drop from Explorer/Finder.
  • Workaround for foo_tags issue [being backported to 2.25.x]
  • Workaround for WAV headers claiming zero length [being backported to 2.25.x]
  • Fixed File Operations link vs portable relative paths [being backported to 2.25.x]
Автор темы, Администратор
С нами: 13 лет 10 месяцев
Сообщение #21 LUR » 17.12.2025, 18:25
2025-12-17
  • Mac: Because of erratic behavior of tableview controls on latest macOS, new macOS 26 appearance has been DISABLED. This will be looked into again later.
  • File Operations: Fixed error with renaming files on redirected portable music folders & macOS volumes.
  • Fixed various regressions with network shares in Media Library preferences page.
  • Made new "Play On" accessible in Internet Radio panel context menus.
  • Updated Opus decoder to v1.6.
Сообщение #22 LUR » 29.12.2025, 05:12
2025-12-28
  • LargeFieldsConfig technology is back - https://www.foobar2000.org/LargeFieldsConfig-v2
  • Enabled WavPack asm optimizations on Windows for slight decoding speedup.
  • Windows: fixed bugs related to copy-paste of file-relative locations in portable installs.
  • Fixed MP4 tag writer corrupting specific kinds of fragmented/streaming MP4 files. Some of these are currently untaggable (fails cleanly). This will be properly fixed soon.
Сообщение #23 LUR » 30.12.2025, 01:37
2025-12-29
  • Fixed recent regression that caused crashes on a fresh profile.
  • Properly fixed tag writing issues on fragmented/streaming MP4 files.
Сообщение #24 VEG » 02.01.2026, 22:27
2025-12-31
  • Mac: Made pass correct realtime/offline flag to Audio Units, fixed specific Audio Unit visualizations not working.
2026-01-02
  • Windows: Worked around Wine crash in IWICBitmapScaler::CopyPixels(), breaking album art view in Properties dialog.
Сообщение #25 VEG » 07.01.2026, 20:41
2026-01-07
  • Made always write hours and minutes to Ogg chapter mark fields.
  • Fixed Properties 'reload info' evading LargeFieldsConfig settings.
  • Replaced libretro resampler with Speex resampler, providing better quality at comparable speeds / better speeds at comparable quality.
  • Windows: Fixed ARDFTSRC resampler settings dialog being inaccessible from certain pages.
Сообщение #26 VEG » 16.01.2026, 01:19
2026-01-15
  • Major Converter update:
    • New preset format, presets stored as .ini files in profile subfolder. Old presets imported on first run.
    • Backing up of profile before upgrading is recommended because of the above.
    • Added extensible post-conversion actions which can be used for ReplayGain scanning, integrity testing, etc.
    • On conversion error, encoder's stderr output is forwarded to foobar2000 console.
    • Fixed a bug causing int32 stream to be sent to encoders that don't recognize it if source is float64.
    • Ogg chaining is now off by default, Ogg chapters written by default instead.
  • Fixed logic error in replaygain_scanner API implementation, use of replaygain_scanner object after finalize() wasn't working as documented.
  • ARDFTSRC prevent implicit resampling using "max bandwidth" mode when told to use max quality.
  • Speex resampler code update.
Сообщение #27 MOSSHIFI » 18.01.2026, 21:30
The 32-bit plugin is not compatible. Is there a way to convert it to 64-bit. :smile:
MOSSHIFI
С нами: 6 лет 3 месяца
Сообщение #28 VEG » 19.01.2026, 14:24
2026-01-18
  • Fixed MP4/M4A files not being played completely if their tags contain malformed Apple Gapless information.
  • File Operations: Fixed erratic behavior if empty folders can't be removed.
  • Mac: Built in Playback Statistics internal fixes.
  • Workaround for Media Library crash when filesystem returns nonsensical folder contents (sighted with Wine).
Сообщение #29 VEG » 19.01.2026, 14:26
MOSSHIFI:The 32-bit plugin is not compatible. Is there a way to convert it to 64-bit.
No, the plugin needs to be recompiled for 64-bit foobar2000.
Сообщение #30 VEG » 21.01.2026, 20:05
2026-01-21
  • Fixed holiday-coding bug in LargeFieldsConfig handling which resulted in Properties dialog not loading complete info in some cases (partial info not flagged as partial).
  • Mac: Disabled out-of-process loading of Audio Units which caused display glitches.
  • Mac: Fixed various issues with Audio Unit panel resizing.
  • Windows: Made recover better from fooHelper.exe crash/termination (system file dialogs).
  • Windows: Mitigation for "error 380" bug in latest Windows update, which caused specific file manipulations to fail in cloud-synced folders such as OneDrive folder.
Сообщение #31 VEG » 29.01.2026, 20:02
2026-01-29
  • ReplayGain scanner: Added option to write REPLAYGAIN_ALGORITHM tag.
  • ReplayGain scanner: Default mode is now more accurately named "ITU-R BS.1770".
  • Speex resampler code updated.
  • Windows: Fixed portable relative path handling bug affecting having portable foobar2000 itself as indexed music folder.
  • Windows: Converter: Fixed regression with high Unicode characters in output path.
  • Windows: Restored Gdiplus rendering of album art viewers by default to workaround problems on Wine.
    • It's recommended to enable all "Direct2D" options in Advanced if running on modern Windows, for better performance.
  • Windows: Added check for known Wine C++ exception handling problem causing stability issues, a notice is shown in Console on each startup if bad behavior is detected.
    • Affected systems will not auto submit crash reports, as they're of very little help now.
    • See Console output for further details.
Сообщение #32 LUR » 03.02.2026, 11:54
2026-02-03
  • Mac: Fixed loss of Audio Unit settings when Audio Unit panel replaces whole parameter tree.
  • Windows: Fixed unintended reliance on undocumented Gdiplus behavior, resulting in issues when running on Wine (mainly Properties dialog crashing).
Сообщение #33 LUR » 04.02.2026, 16:34
2026-02-04
  • Windows: Fixed album art drawing regressions in non-Direct2D mode.
  • Fixed default AccurateRip log save location not being reliably set to scanned album folder.
Сообщение #34 LUR » 06.02.2026, 22:34
2026-02-06
  • Windows: Removed Direct2D album art toggle - new default Direct2D code should work correctly everywhere, including Wine.
  • Mac: Fixed Properties dialog bottom controls not being disabled during ReplayGain scan.
  • Mac: Fixed Properties dialog ReplayGain scan not being cancellable.
  • Mac: Attempted workaround for window order bugs if opened Properties dialog via context menu without activating foobar2000 application.
  • ReplayGain scanner internal fixes, added new interface for components to access ReplayGain scanning options.
Сообщение #35 VEG » 11.02.2026, 20:10
2026-02-11
  • Updated FFmpeg to latest git.
  • Windows: Rebuilt FFmpeg without MSVC /fp:fast, which fixes a mis-compilation bug that resulted in crashing on Wine.
  • Mac: Fixed window focus tracking bug which made playlist "remove"/"crop" menu command block incorrectly grayed after cycling windows.
  • Mac: Mitigation for bugs in Apple's SMB support & folder watching. Moving folders with specific Unicode characters around no longer results in duplicate library items.
  • Fixed WMA album art reader being not disabled if WMA decoder is disabled in Preferences.
  • Fixed Direct2D visualization race condition bug resulting in random instability.
Сообщение #36 LUR » 16.02.2026, 16:12
2026-02-16
  • Fixed horrible regression in FPL serialization code that caused nonsensical output when copying or drag&dropping playlist contents between foobar2000 instances using relative paths.
  • Windows: Updated SQLite to the latest version.
  • Made report video codec for H.266 and VP9 in MP4.
  • Improved behavior of Advanced Limiter, made sure it resumes outputting bit identical signal after attenuation.
  • Internet Radio: Worked around radio-browser site not working as documented, all tags get fetched again.
  • Windows: Disabled delayload of ws2_32.dll, makes no sense on most configs.
Сообщение #37 LUR » 18.02.2026, 21:31
2026-02-18
  • Fixed a regression causing crashes when trying to sort a large playlist that is currently playing.
  • Windows: Restored GDI rendering of album art & visualizations by default, Direct2D is opt-in, to prevent GPU driver bugs breaking default foobar2000 settings.
  • Fixed a bug in SMB code that prevented password-less user logins (other than guest user) from working.
Сообщение #38 VEG » 25.02.2026, 21:25
2026-02-25
  • Improved M4A Apple tag compatibility, made recover tags containing null bytes in UTF-8 content.
  • Smarter "remove duplicates" code, made aware of various scenarios where different perceived paths point to same file, made non case sensitive on Windows.
  • Windows: Album List fixed repaint glitches when using multi selection mode.
  • Windows: Upgraded toolchain from VS2019 to VS2022.
  • Mac: Cosmetic changes in Preferences.
Сообщение #39 LUR » Вчера, 20:45
2026-03-03
  • Made write more compatible genre tags to MP4/M4A files.
  • Made ignore duplicate genre tag values in MP4/M4A files.
  • Windows: Made show better error message for ERROR_LOGON_FAILURE.
  • Windows: Fixed incorrect dark mode checkbox rendering of "do not ask again" in various popups.
  • Windows: Album List worked around Wine bug #59448, made multi-selection visible on Wine.
  • Converter: Added %source_list_index% & %source_list_total%, only for multi track image naming pattern use, to allow use of list indexes in the pattern.
  • Converter: Restored remembering of last-used output folder per preset
  • Converter: Restored ability to use .bat/.cmd files as external encoders.
  • Converter: Restored console logging of external encoder parameters.
Вернуться в Новости плеера
