foobar2000 v2.26 preview
Сообщение #1 VEG » 10.10.2025, 20:33
Вышел foobar2000 v2.26! Предыдущая версия: foobar2000 v2.25.
  • Improved recovery of malformed UTF-8 text in various tag formats.
  • Made malformed UTF-8 tags text reported in integrity verifier.
  • MP4 tagging improvements:
    • Tagtype info (Apple, Nero)
    • No longer writes Nero tags by default for single chapter files, only for multi chapter where other tagging formats can't store per track tags.
    • Added support for more rarely used Apple tag elements.
    • No longer alters binary structure of Apple tag elements which are not affected by edits.
  • Monkey's Audio decoding moved to FFmpeg, no longer including Monkey's Audio library with foobar2000 setup.
    • You can once again install Monkey's Audio decoder component to replace built-in FFmpeg decoder.
  • New info field: container (MP4, Matroska, Ogg, etc)
  • New title formatting field: %_cpu_arch%
  • Mac: made playlist view receive copy/paste from Finder
  • Mac: New icon from Apple Icon Composer
  • Mac: Built with Xcode 26, enabled macOS Tahoe looks.
  • Mac: Install components by drag&drop from Finder to components list.
  • Mac: Playlist Manager columns can be toggled.
  • Added drag&drop from Internet Radio pages to playlist.
  • Attempt to play a password-protected resource such as radio stream now shows a password prompt.
  • Converter: Better error messages when receiving unexpected data format change in mid-conversion; made discard blank chunks before checking for format match.
  • Equalizer now accepts presets via drag&drop from Explorer/Finder.
  • Workaround for foo_tags issue [being backported to 2.25.x]
  • Workaround for WAV headers claiming zero length [being backported to 2.25.x]
  • Fixed File Operations link vs portable relative paths [being backported to 2.25.x]
Автор темы, Администратор
С нами: 13 лет 11 месяцев
Сообщение #41 LUR » 18.03.2026, 06:08
2026-03-17
  • Windows: Implemented alternate, more resource-efficient method of finding radio-browser servers.
  • Improved recovery from momentarily unplugged audio device while paused.
  • Fixed missing URL-decode of WebDAV file names being shown.
  • Refactored filename sanitization code (Converter, File Operations), actual behavior should not change.
  • Fewer C++ exceptions thrown when reading file tags.
Сообщение #42 LUR » 19.03.2026, 15:33
2026-03-18
  • Attempted fix for crashing in new radio-browser server finder.
2026-03-19
  • Fixed lock up on specific album art tag update operations.
  • Mac: Included Playback Statistics v3.1.9.
Сообщение #43 LUR » 24.03.2026, 17:29
2026-03-23
  • Windows: Fixed lock up on specific playlist + album art + auto sizing column use pattern.
  • Refactored MP4/M4A tag update code, should not affect output.
Сообщение #44 VEG » 05.04.2026, 14:23
2026-03-27
  • Added experimental float8 PCM support.
Сообщение #45 LUR » 22.04.2026, 05:40
2026-04-17
  • Fixed playlist search incorrectly refocusing first item in some scenarios.
  • UPnP renderer: Made accept MP3 (audio/mpeg) streams.
  • Windows: Updated zlib to 1.3.2. Note that system-bundled zlib is used on all other platforms.
  • Mac: Fixed audio latency calculation bug that resulted in instability with smooth seeking mode.
  • Mac: Included Playback Statistics v3.1.10.
2026-04-20
  • Revised UPnP renderer code, implemented various missing methods required by the standard; made compatible with various popular UPnP remote control applications.
  • Windows: Made various DSP configuration dialogs not crash if invoked off-main-thread, which certain unmaintained old component does.
Вернуться в Новости плеера
