foobar2000 v2.26 preview
Сообщение #1 VEG » 10.10.2025, 20:33
Вышел foobar2000 v2.26! Предыдущая версия: foobar2000 v2.25.
  • Improved recovery of malformed UTF-8 text in various tag formats.
  • Made malformed UTF-8 tags text reported in integrity verifier.
  • MP4 tagging improvements:
    • Tagtype info (Apple, Nero)
    • No longer writes Nero tags by default for single chapter files, only for multi chapter where other tagging formats can't store per track tags.
    • Added support for more rarely used Apple tag elements.
    • No longer alters binary structure of Apple tag elements which are not affected by edits.
  • Monkey's Audio decoding moved to FFmpeg, no longer including Monkey's Audio library with foobar2000 setup.
    • You can once again install Monkey's Audio decoder component to replace built-in FFmpeg decoder.
  • New info field: container (MP4, Matroska, Ogg, etc)
  • New title formatting field: %_cpu_arch%
  • Mac: made playlist view receive copy/paste from Finder
  • Mac: New icon from Apple Icon Composer
  • Mac: Built with Xcode 26, enabled macOS Tahoe looks.
  • Mac: Install components by drag&drop from Finder to components list.
  • Mac: Playlist Manager columns can be toggled.
  • Added drag&drop from Internet Radio pages to playlist.
  • Attempt to play a password-protected resource such as radio stream now shows a password prompt.
  • Converter: Better error messages when receiving unexpected data format change in mid-conversion; made discard blank chunks before checking for format match.
  • Equalizer now accepts presets via drag&drop from Explorer/Finder.
  • Workaround for foo_tags issue [being backported to 2.25.x]
  • Workaround for WAV headers claiming zero length [being backported to 2.25.x]
  • Fixed File Operations link vs portable relative paths [being backported to 2.25.x]
Автор темы, Администратор
С нами: 14 лет 4 месяца
Сообщение #61 LUR » 25.07.2026, 01:23
2026-07-23
  • Windows: Reverted & frozen UPnP output DLL to build 2026-06-18, as newer versions crash on Wine due to missing C++ runtime functions.
  • Improved SMB read throughput over high-latency connections.
  • Fixed ARDFTSRC resampler integer overflow if fed extreme sample rates.
Сообщение #62 LUR » 07.08.2026, 14:37
2026-08-05
  • Fixed certain malformed MP4/M4A/M4B files being presented with thousands of chapters.
  • Improved reading of RAR archives on network shares.
  • Faster opening of MP4/M4A files on network shares.
  • Fixed missing AAC codec details on specific internet radio stream.
  • ARDFTSRC: Prevented insane mode being invoked programmatically
  • Windows: Updated SQLite to the latest version.
Сообщение #63 LUR » 29.08.2026, 12:21
2026-08-28
  • Fixed longtime Null Output bug causing playback position jitter when paused.
  • Worked around wrong MP3 sample rate shown with specific internet radio station due to server sending conflicting data.
  • Fixed "Verify with AccurateRip" command not showing if your tracknumbers don't strictly match most common numbering scheme.
  • Mac: Fixed Album Art Viewer in "fixed size" mode feeding downscaled image to full-size view on double click.
Сообщение #64 LUR » 13.09.2026, 23:48
2026-09-12
  • Added ui_element_subclass_playback_information section to View menu.
  • Added console notice why Properties doesn't autocomplete stuff if secret low memory mode is active.
  • Mac: Cleaned up 'add location' and 'choose playlist format' dialogs.
  • Increased accepted HTTP reply line length because some sites tripped the old limit in legitimate responses.
Сообщение #65 VEG » 14.09.2026, 20:18
2026-09-14
  • Made print name of file format handler used to console, after "opening track for playback".
  • Fixed multiple bugs in smooth seeking implementation.
Сообщение #66 VEG » 16.09.2026, 23:03
2026-09-16
  • Improved compatibility with specific UPnP renderers.
  • UPnP output is built against static VS runtime because normal build crashes on Wine.
Сообщение #67 VEG » Вчера, 23:00
2026-09-18
  • Refined on_playback_dynamic_info() timing fix again.
