PCM/DSD PeakMeter v1.0 [16.10.2026]
Сообщение #1 foobar2000.club » Вчера, 00:00
PCM/DSD PeakMeter is a native Windows x64 peak meter component for foobar2000. It operates as a standalone window or an embedded Columns UI panel.
Main features:
  • Automatic PCM/DSD identification using validated DoP markers.
  • PCM sample-rate display and DSD64–DSD2048 format indication.
  • Stereo L/R peak meters with peak-hold indicators.
  • Per-channel peak maxima and warning statistics.
  • Horizontal, vertical, and compact display layouts.
  • Customizable dB scales, colors, fonts, and themes.
  • English and Korean preference interfaces.
  • User-adjustable DSD FAST display calibration.
DSD measurement
DSD FAST metering uses format-specific 1-bit modulation-density windows. These readings are not equivalent to reconstructed analog true-peak measurements. The calibration offset affects displayed readings only; low-pass-filtered DSD true-peak analysis is not implemented.
Audio integrity
The component is display-only. It does not alter audio samples, insert audio DSP processing, change playback gain, or switch DAC output modes.
Страница плагина: http://foobar2000.org/components/view/foo_pcm_dsd_peakmeter
foobar2000.club
Автор темы, Робот
С нами: 14 лет 4 месяца
