  • 22
Скриншоты
Примечания
Album list panel
ASIO support
Channel Spectrum panel
Columns UI
CUE fixer
Discogger
DR Meter
DSD Processor
DVD-Audio Decoder
ELPlaylist
EsPlaylist
Explorer Tree
HDCD decoder
Lyric Show Panel
Masstagger
MIDI Player
Multi-source lyrics
Panel Stack Splitter
Playback Statistics
Pretty Popup
Quick Search Toolbar
Run services
Skip Track
Spider Monkey Panel
Stop After Queue
Super Audio CD Decoder
Text Tools
vgmstream plugin
VST 2.4 adapter
VU Meter
Waveform seekbar
Дата сборки: 14.10.2026
Модифицировал: kutuzof
Версия плеера: 2.26.1 [x86]
История изменений: 14.10.2026
- foobar2000 v2.26.1 [x86]
- foobar2000 v1.6.20
- Album list panel v2.2.0
- Columns UI v3.7.0
05.07.2026
Старые версии плеера
Скриншоты
С нами: 10 лет 2 месяца
Сообщение #321 slovak » 05.01.2021, 22:22
slovak, так она и не переключится. Сикбар, это отдельная панель и она видна только в режиме View 3 и View 4.
Ok :smile:
slovak
С нами: 6 лет 9 месяцев
Сообщение #322 idro » 08.01.2021, 14:15
Hi Kutuzof,
always speaking about the web links buttons on the right-up corner, is it possible to add the italian wikipedia artist link next to the english wikipedia web link button?
I tried to find out the wikipedia link into the panel properties code but i didn't find it.
idro
С нами: 5 лет 10 месяцев
Сообщение #323 kutuzof » 08.01.2021, 14:55
idro, вы можете в настройках скрипта заменить "en" на "it".
Сообщение #324 idro » 10.01.2021, 19:43
Great, always thank you for your support.
Today I'm enjoying to change some weblinks buttons about my personal flavours.
I'd like to add the link to whosampled.com site and as icon I tried to add the record vinyl icon that has the code 63705.
But when I use this code, the icon into foobar2000 is a generic rectangular icon.
Maybe foobar support some icons only of font-awesome?
idro
Сообщение #325 Zephyroth » 12.01.2021, 23:20
i've done my first Vu Meter skin to DarkOne4Mod v1.0 (kutuzof edition), simple but nice (?)
You can watch in action here.
Zephyroth
С нами: 6 лет
Сообщение #326 robertospeed » 13.01.2021, 13:20
где я могу найти эти вю-метры с логотипом foobar?
robertospeed M
С нами: 9 лет 3 месяца
Сообщение #327 Zephyroth » 13.01.2021, 21:33
i've edited/created 2 new color variants.
:smoke:
Zephyroth
С нами: 6 лет
Сообщение #328 idro » 17.01.2021, 12:46
Hello,
I'd like to know if there is a chance for this portable foobar2000 version to use the icons for every file type (flac, mp3, ogg, m4a, etc.) as it happens for standard version.
Honestly I don't like the same icon (white with the foobar alien face, I use winodws as os) for all the music file type.
idro
Сообщение #329 slovak » 17.01.2021, 16:09
Hi, i' ve noticed in the "peakmeter panel 6" if peakmeter is enabled the panel size is not correct.
slovak
Сообщение #330 robertospeed » 21.01.2021, 13:55
Zephyroth:i've edited/created 2 new color variants.
:smoke:
I would like to have these vu meters, can you let me download them please?
robertospeed M
Сообщение #331 slovak » 13.02.2021, 13:51
Hi guys, just to ask you how can i add the coverflow to the "view 2" in the 1.5.6 version? Thank you.
slovak
Сообщение #332 kutuzof » 13.02.2021, 16:20
slovak, see screenshots...
[Расширение js было запрещено, вложение больше недоступно.]
Right Panel 2.txt
Сообщение #333 slovak » 14.02.2021, 15:37
kutuzof, thank you!
slovak
Сообщение #334 Gipopotam » 28.02.2021, 17:10
Доброго времени суток. Помогите пожалуйста найти решение.После установки, спустя пару дней Фубар начинает постоянно виснуть. О себе Вин 7 х64. TLS_1.2 установлен.
вот скрин отчёта об ошибках
Gipopotam M
С нами: 6 лет
Сообщение #335 kutuzof » 06.03.2021, 16:44
В папку "themes\DarkOne4Mod" добавил три конфига с цветовыми темами (GREEN, RED, YELLOW), а так же к ним картинки, иконки (только придется менять самим в настройках) и ву метры.
Скриншоты
Сообщение #336 slovak » 08.03.2021, 16:31
kutuzof what' s the difference between the 1.5.7 and 1.6.4? Thank you.
slovak
Сообщение #337 kutuzof » 08.03.2021, 18:08
slovak, well, first of all, these are different versions of the player. Visulally, there is no difference. You can unpack version 1.5.7 anywhere and everything will work. And version 1.6.x is partially incompatible with "UI Hacks" (the virtual disk (B:) does not work).
Сообщение #338 slovak » 08.03.2021, 19:04
Ok, i use the 1.5.7 but can i update it? I did it adding the 2 missing fonts, is it correct? Thank you.
slovak
Сообщение #339 kutuzof » 08.03.2021, 19:16
Yes. Only everywhere you need to change the paths to the files.
Сообщение #340 slovak » 08.03.2021, 22:50
kutuzof Thank you!
slovak
