Раскрывающиеся альбомы исполнителей
Сообщение #1 RoxMarty » 18.07.2009, 13:29
Использую foobar 0.9.6.8.
Плагины:Core (2009-06-07 16:28:34)
    foobar2000 core 0.9.6.8
foo_abx.dll (2008-05-24 19:23:50)
    ABX Comparator 1.3.3
foo_ac3.dll (2009-05-09 17:27:36)
    AC3 decoder 0.9.3
foo_albumlist.dll (2009-06-07 16:26:58)
    Album List 4.3.1
foo_cdda.dll (2009-06-07 16:26:40)
    CD Audio Decoder 2.1.4
foo_converter.dll (2009-06-07 16:26:38)
    Converter 1.2.1
foo_covers.dll (2009-04-27 16:19:55)
    Locate Covers 0.03
foo_cuefilter.dll (2009-03-02 19:04:42)
    CUE playlist filter 0.1.6
foo_customdb.dll (2009-05-09 19:17:06)
    Custom Database 0.0.9a
foo_dsp_std.dll (2009-06-07 16:26:54)
    Standard DSP Array 1.0
foo_dumb.dll (2009-02-07 19:23:20)
    DUMB module decoder 0.9.8.4
foo_fileops.dll (2009-02-24 03:06:12)
    File Operations 2.1.1
foo_freedb2.dll (2009-02-24 03:07:04)
    freedb Tagger 0.6.1
foo_gep.dll (2009-02-07 18:31:20)
    Game Emu Player 1.6
foo_input_dts.dll (2008-10-26 15:15:26)
    DTS decoder 0.2.2
foo_input_monkey.dll (2009-05-01 14:40:52)
    Monkey's Audio Decoder 2.1.4
foo_input_std.dll (2009-06-07 16:26:30)
    Standard Input Array 1.0
foo_jesus.dll (2009-01-09 21:41:10)
    Autosave 0.0.2
foo_masstag.dll (2008-11-29 21:46:18)
    Masstagger 1.7.1
foo_masstag_addons.dll (2009-02-10 23:54:08)
    Masstagger Addons 0.3.5 (SSE)
foo_midi.dll (2009-02-07 18:38:38)
    MIDI synthesizer host 1.7
foo_osd.dll (2007-01-25 14:58:30)
    On-Screen Display 1.52
foo_out_ks.dll (2006-08-04 22:54:58)
    Kernel Streaming Output 1.2.2
foo_prettypop.dll (2008-12-01 20:48:22)
    Pretty Popup 1.2.4
foo_psf.dll (2009-02-07 19:04:32)
    Highly Experimental 2.0.6
foo_rgscan.dll (2009-06-07 16:26:22)
    ReplayGain Scanner 2.0.8
foo_texttools.dll (2009-01-31 15:23:38)
    Text Tools 1.0.3
foo_ui_columns.dll (2009-05-22 01:15:16)
    Columns UI 0.3.7.3
foo_ui_std.dll (2009-06-07 16:27:04)
    Default User Interface 0.9.5
foo_uie_albumart.dll (2007-12-16 00:22:24)
    Album Art Panel 0.2.7.1
foo_uie_biography.dll (2009-06-05 20:56:52)
    Biography View 0.2.9.0
foo_uie_tabs.dll (2006-10-17 22:54:32)
    Tabbed panel modified 0.2.5
foo_unpack.dll (2009-02-24 03:05:58)
    RAR reader 1.2
    ZIP/GZIP reader 1.0
foo_verifier.dll (2009-01-30 20:54:44)
    File Integrity Verifier 1.0.4
В качестве плэйлиста использую NG Playlist
Вот так выглядит мой foobar в данный момент:
Задача: нужно сделать так, чтобы можно было альбомы исполнителя (в данном скриншоте, к примеру, это C.C. Catch) показывались свёрнутыми (естественно, вместе с треками в альбоме). Чтобы плэйлист отображал только исполнителя и список альбомов в хронологическом порядке (по годам), чтобы можно было раскрыть нужный альбом и выбрать нужный трек.
P.S. Если имеются треки вне альбома, можно их просто списком прикрутить...
Короче, хочу, чтобы было примерно так (на примере моего текущего скриншота):
- Исполнитель -
- Список альбомов (в виде разворачивающихся/сворачивающихся "спойлеров" в столбик)-
Вроде пытался объяснить понятно. Если что надо уточнить - спрашивайте.
RoxMarty
Сообщение #2 Izotop » 18.07.2009, 15:10
Ваш запрос реализовать лучше с помощью ELPlaylist v0.6.5.3.3b(2009/06/05), а не NG.
NG не умел (насколько я знаю) сворачивать группы файлов.
Сообщение #3 RoxMarty » 18.07.2009, 19:23
Ух ты! Классно!
Будем экспериментировать! (Интересно, как сделать сворачивающиеся... попробуем...)
Поистине, чтобы перетестировать все существующие плагины с ума можно сойти :)
Спасибо
RoxMarty
Сообщение #4 Izotop » 18.07.2009, 20:03
Переведённая с японского инструкция к foo_uie_elplaylist.dll v0.6.5.3.3beta
Сообщение #5 RoxMarty » 18.07.2009, 23:08
Спасибо за ссылку, но боюсь, что в этой инструкции я совсем потеряюсь :)
Сложновато это для меня.
А пока что я полазил в дефолтовских параметрах и накрутил что смог, чтобы было хоть немного похоже на тот вариант, что на скриншоте от NG Playlist.
Прикладываю вложение elp-файла. Это максимум, что я смог сделать.
Помогите мне пожалуйста его подкорректировать, чтобы:
1) Все параметры (как на скриншоте в шапке темы) перенести в EL playlist. А именно столбцы: Performer, tracknumber, title (уже есть в дефолте), lenght (тоже есть), Codec, Ext, Rate (рейтинг от Custom database, который уже настроен для корректной работы в NG Playlist)
2) Сделать так, чтобы можно было все альбомы одного исполнителя свернуть под него.
В дефолтовских настройках только можно свернуть треки в альбоме, а как сами альбомы под исполнителя?
Если не трудно, отредактируйте приложенный мной elp-файл.
Если нужно ещё какие параметры добавить помимо этого - укажите что и куда, пожалуйста.
my_elp_playlist.zip
RoxMarty
Сообщение #6 mans » 19.07.2009, 11:26
скачал бы лучше  сборку например x-change или kameleon, лучше чем там не сделаешь.
mans
С нами: 19 лет
Сообщение #7 Izotop » 19.07.2009, 11:38
mans:скачал бы лучше  сборку например x-change или kameleon, лучше чем там не сделаешь.
Если кто-то задаётся целью что-то сделать самостоятельно -- то не нужно ему препятствовать в этом.
Прогрессу и совершенствованию мешает именно -- лень человека и такие выражения:
mans:лучше чем там не сделаешь.
Если Вам нравится как там -- пользуйтесь. Но других не нужно отговаривать сделать самостоятельно, по-своему, на свой вкус!
И давайте не будем засорять тему ненужными полемиками - для этого есть раздел Флейм ;)
