Сообщение #221 SanJose » 17.09.2015, 22:16
@Gary
Ok next Vu's will be without unnecessary parts :) But personally I like when you have "right" and "left" channel labels.
The Pioneer VU are moving the same in real world, I checked the rise up speed and the 0.08 is the best for analog.
What (19 30 38) mean? You mean the rgb pallette?
SanJose
Сообщение #222 Gary » 17.09.2015, 23:12
@SanJose
agree! apparently, I am under the influence of minimalism "B&O (5500)"..) it's hard to choose, I'd offer both options (whole and cut (do not consider for impudence))
about QX, no doubt.. this is only my personal impression :toothless:
Yes it is RGB in the Assembly DarkOne v.4. I have built a VU in the left panel.. sometimes, I use as an additional panel at the bottom.
Gary
Сообщение #223 SanJose » 18.09.2015, 00:39
@Gary
I will make Beocord 5000 or 8000, those are the easiest to make. :wink:
GRUNDIG CN1000
http://sharemods.com/mpepcg373ny6/GRUNDIG_CN1000.zip.html
SanJose
Сообщение #224 Gary » 18.09.2015, 01:01
@SanJose
fantastic! I'll be very, very grateful! :pray:
everything else takes a back seat :silenced: :smile:
Добавлено спустя 6 минут 29 секунд:
(thank! CN1000 - class! backlit ..))
Добавлено спустя 15 минут 26 секунд:
6j5meg
Beocord 8000 - Beautiful, but I'm the owner of Beomaster 5000 :think: :smile:
Добавлено спустя 4 минуты 26 секунд:
I chose 5000 :cry: :smile:
Добавлено спустя 40 минут 51 секунду:
I was referring to this model
https://youtu.be/WTT0lmsONcI
:smoke:
Gary
Сообщение #225 Gary » 18.09.2015, 11:38
GRUNDIG CN1000 - lifelike! :clap: :yes:
Gary
Сообщение #226 SanJose » 20.09.2015, 18:16
Bang & Olufsen BEOCORD 5000 Type 4921(22, 23, 24, 25)
0 1 light system.
BEOCORD 5000.zip
SanJose
Сообщение #227 Gary » 20.09.2015, 18:48
@SanJose
Hooray! :dance:
Gary
Сообщение #228 Гость » 20.09.2015, 20:00
I love B&O, I would be very happy with any of them, but 5000 is certainly especially good for me..
thank you very much! Don't know how to thank you..
here is my work, you can listen to once :wink: :
https://www.jamendo.com/en/list/a104719/authentic
Сообщение #229 Gary » 21.09.2015, 19:58
@SanJose
there was a small problem. I have a monitor with glass and it gives the reflection and the indicator static reflection. you had in the development version without reflection? if Yes and You don't mind, please, share :help:
Gary
Сообщение #230 macarych » 21.09.2015, 20:38
Сообщение #231 Gary » 21.09.2015, 21:05
macarych, мир вашему дому! И Cпасибо, за индикаторы!
Я тут один, по ходу.. беседую сам с собой.. да ещё, через транслит..)
У меня такое впечатление, что товарищ уже с трудом понимает, что я имею в виду..
А я, на самом деле, от чистого сердца.. :weirdface:
Вот теперь не знаю, извиняться и за что или лучше мне вообще помолчать :biggrin:
А может и нормально всё.. и я напридумывал себе, шут знает чего..
В общем, совет бы не повредил :smile:
Gary
Сообщение #232 macarych » 21.09.2015, 21:34
И вам всего наилучшего! Честно говоря, я не понимаю о чем речь, я хоть и переводил посты на лету в хроме, но суть куда то улетучилась ) если не затруднит изложите на русском, мне будет понятно и что то мне подсказывает что SanJose то же.
Сообщение #233 SanJose » 21.09.2015, 22:06
@Gary
No problem, here's the version without reflection :wink:
BEOCORD 5000 No reflection.zip
SanJose
Сообщение #234 Gary » 21.09.2015, 22:55
Хорошо.) Начну с того, что разобрался c PeakMeter методом "тыка", давно уже и основательно, но Analog VU meter оказался покрепче..я не понимаю на сколько это трудоёмкий процесс и в праве ли я просить автора о каких-либо переделках (может это не принято и я получается навязываюсь) или это нормально? Вот собственно и весь вопрос :smile: По индикаторам я пытался сказать, что было бы намного интересней, как мне кажется, если бы не было этих вырезанных кусков передней панели, а был бы только сам прибор, если не на фоне для DarkOne, то на универсальном чёрном фоне и когда изображения левого и правого отличаются друг от друга, тоже здорово(!) и с подсветкой классно смотрятся(!) и движение реальное сложно уловить, но возможно(!) А тени стрелок и явные отражения, по моему, атрибут излишний, поскольку свет у всех по разному падает и у меня вот, например, монитор со стеклом и статическое явное отражение на индикаторе смотрится, как то по дурацки. А ещё, "как нарочно", именно на Beo 5000 здорово расфокусировано изображение.. но тут уж, что уж.. я реально боюсь огорчить SanJose и молчать не могу.. вот такая у меня ситуация. Ну, а то что я в восторге от светодиодных и люминесцентных.. это и так понятно.) Не думал, что удивлюсь стрелочным, однако от CN1000, до сих пор под впечатлением(привет, SanJose :smile: ) Макарыч, добираясь до Weston 506 и не только, вспоминаю добрым словом (у меня окно и лампа от монитора по правую руку) :smile:
Добавлено спустя 2 минуты 1 секунду:
@SanJose
:yes: :beer:
Добавлено спустя 16 минут 13 секунд:
Макарыч, "отбой тревоги" :smile:
Благодарю, за совет!
Gary
Сообщение #235 Гость » 03.10.2015, 00:59
Here is my modded version of DENON VU that someone has posted on the forums. Hope you like it.
https://dl.dropboxusercontent.com/u/414891/%5BAnalog%5D%20%5BLED%5D%20DENON_V3%20%5BGOLD%5D%20%5BSILVER%5D.zip
Сообщение #236 Gary » 03.10.2015, 01:32
thank! interesting thing :smile:
Gary
Сообщение #237 SanJose » 04.10.2015, 15:09
SanJose
Сообщение #238 sega72 » 04.10.2015, 18:33
SanJose, будьте так добры - залейте архив на другой ресурс - mail или google
sega72
С нами: 11 лет 10 месяцев
Сообщение #239 Gary » 04.10.2015, 21:15
@SanJose
Спасибо, за Marantz 5020!
BC5000, как нельзя лучше, вписался в дисплей :drunk:
https://yadi.sk/d/v5twTt93jWRLN
Добавлено спустя 22 минуты 16 секунд:
@sega72
держите;)
https://yadi.sk/d/szjpglGYjWTNd
Gary
Сообщение #240 Gary » 05.10.2015, 01:00
@SanJose
Я понимаю, что "хорошего" должно быть "понемножку", но так и хочется обратить Ваше внимание на BC5000 (4705).
Эти "децибелы" меня притягивают, как магнит :smile:
Gary M
С нами: 11 лет
