foobar2000 v1.5.0
Сообщение #1 VEG » 09.07.2019, 18:42
Вышла финальная версия foobar2000 v1.5.0! Предыдущая версия: foobar2000 v1.4.8.
  • New and improved Properties dialog, with the ability to manipulate attached pictures as well as scan and modify ReplayGain values.
  • Greatly improved Selection Properties performance for large track lists.
  • Various prompts (such as delete/recycle) now come with a “do not show this again” checkbox.
  • Restored pre-1.4 behavior of main-window-hidden/notification-icon-only status being remembered after foobar2000 restart.
  • Added logging of Media Library scanning errors - “show errors” button in Media Library Preferences.
  • Added Advanced Preferences option for flushing playback queue on manual track change (default: on).
  • Made “Open containing folder” command work with tracks in archives - opens folder containing the archive.
  • Added an option to preserve last-modified timestamps of tracks when updating tags.
  • Additional safeguards against corrupted configuration in case of a system crash while saving (FlushFileBuffers).
  • File Operations: delete/recycle prompt always says “Delete” rather than “Recycle”, since not every volume supports recycle action.
  • FFmpeg 3.4.6, now compiled with MS compiler, binary size reduced due to DLL runtime.
  • FLAC 1.3.3
  • Implemented reading of cue+bin audio CD images.
  • Implemented asynchronous drag&drop, for less stalls when dragging tracks from foobar2000 to another program.
  • Removed transacted filesystem support. There are no known benefits to it and even Microsoft documentation says not to use it.
  • Improved programming interfaces for External Tags and Skip Track components.
  • Made album art loading/resizing operations in Default User Interface asynchronous. Large pictures no longer make the app momentarily unresponsive.
  • Converter: Added Opus encoder selection for –music / –speech modes.
  • Converter: New list control in various dialogs. Column sizes are remembered.
  • Improved playback position reporting with Skip Silence and similar DSP effects.
  • Made possible to check for updates of components listed but not hosted on foobar2000.org.
  • Enabled embedded cuesheet support for MP3 files.
  • Made WavPack/DSD MD5 visible - using another field so Verifier doesn't try to verify it.
Автор темы, Администратор
С нами: 14 лет 3 месяца
Сообщение #2 VEG » 10.07.2019, 19:24
В новоей версии полностью переделано окно редактирования тегов (можно на месте редактировать и обложки, и запускать ReplayGain). Для тех, кто не хочет таких перемен, старую версию окна автор обещает оформить в виде плагина. Также значительно обновлён SDK — для работы с GUI предлагается к использованию новая библиотека libPPUI.
Сообщение #3 postED » 10.07.2019, 20:05
VEG:В новоей версии полностью переделано окно редактирования тегов
Пока несколько кривовато выглядит, особенно редактор обложек с зачем-то растягиваемой до гигантских размеров кнопкой X. Все же надеюсь, что это пока не финальный вариант.
Сообщение #4 VEG » 10.07.2019, 20:42
Да, мне тоже не особо понравилось, но сомневаюсь, что это будет сильно переделано к релизу. Разве что если кто-то предложит Питеру вариант получше, и ему понравится, что он захочет его заимплементить.
Сообщение #5 LUR » 11.07.2019, 14:16
postED:Пока несколько кривовато выглядит, особенно редактор обложек с зачем-то растягиваемой до гигантских размеров кнопкой X
Учитывая склонность Петера к спартанскому отношению к интерфейсу и простоте реализации в угоду безглючности его программы, думаю это будет конечный вариант)
Сообщение #6 SpirtRoyal » 11.07.2019, 21:22
Надеюсь автоподстановку починять. Раньше стоило ввести первую букву тега и сразу предлагало варианты из библиотеки, а сейчас :silenced:
SpirtRoyal M
Сообщение #7 maniac736 » 12.07.2019, 09:44
Меня интересует будет ли в финальной версии стабильна работа CUI и PSS ? Особенно PSS потому что создатели это интерфейса забросили его поддержку.
maniac736 M
С нами: 8 лет 10 месяцев
Сообщение #8 VEG » 13.07.2019, 09:40
Все жалобы лучше сразу писать на HydrogenAudio. Только так можно повысить шансы что автор заметит и исправит.
Сообщение #9 VEG » 16.07.2019, 09:18
В ветке выше люди высказывают пожелания, и автор плеера их похоже что учитывает. Так что если у вас есть предложение как сделать красивше — не упустите шанс высказать его, пока автор плеера занимается именно этой частью.
Сообщение #10 SergPuh.68 » 16.07.2019, 12:50
Что я бы хотел видеть в foobar2000:
1.Поддержку мультиязычности или хотя бы руссификатор.
2.Поддержку анимации.
3.Поддержку не только прямоугольных форм но и округлых и других.
4.Поддержку скинов,обложек.
С нами: 7 лет 7 месяцев
Сообщение #11 VEG » 16.07.2019, 16:44
Это всё вряд ли когда-либо будет в foobar2000 по умолчанию.
Мультиязычность — это большой гемор при разработке. Более того, толку от неё в foobar2000 будет мало — слишком много специфичных терминов, которые на английском просто понятнее. Я поэтому и перестал переводить чейнжлоги после версии 1.4.0, так как оригинальные списки изменений на английском выглядят как-то понятнее =)
Что касается последних трёх пунктов — по умолчанию плеер использует стандартный системный тулкит, а красивости — плагинами.
Сообщение #12 MC Web » 16.07.2019, 17:53
VEG:Мультиязычность — это большой гемор при разработке. Более того, толку от неё в foobar2000 будет мало — слишком много специфичных терминов, которые на английском просто понятнее.
Эта сказка уже стара, насчет терминов и прочее. Во всех остальных проигрывателях поддерживающих многоязычность все эти термины похоже не используются. Все зависит от автора программы и то что этой поддержки не будет понятно. То что на английском понятнее - не знаю кому как, мне не понятно.
VEG:перестал переводить чейнжлоги после версии 1.4.0
Вот это правильно, там можно не читать - топтание на месте и исправление своих ошибок.
SergPuh.68, все что хотели бы, в данном проигрывателе никогда не будет реализовано.
Сообщение #13 VEG » 16.07.2019, 20:03
MC Web:Вот это правильно, там можно не читать - топтание на месте и исправление своих ошибок.
Вообще-то за последний год (в версиях 1.4 и 1.5) значимых изменений больше чем за 4 года до этого (в рамках версии 1.3.x). Ну а исправление ошибок — да, представьте, люди ошибаются, делают ошибки.
Сообщение #14 MC Web » 16.07.2019, 20:28
VEG:Вообще-то за последний год, в версиях 1.4 и 1.5 значимых изменений больше чем за 4 года до этого в рамках версии 1.3.x.
Занимаясь переводом начиная с версий 1.1 приходилось отслеживать все эти изменения и то что они в последних версиях значительные я бы так не сказал. Да писанины много, но это не показатель.
VEG:Ну а исправление ошибок — да, представьте, люди ошибаются, делают ошибки.
Что характерно, они стали появляться, когда автор стал распыляться на разные версии и платформы, поэтому и результат такой. Я так думаю.
Сообщение #15 Гармонист » 17.07.2019, 14:25
VEG:Я поэтому и перестал переводить чейнжлоги после версии 1.4.0, так как оригинальные списки изменений на английском выглядят как-то понятнее =)
Тогда вообще нет смысла дублировать список изменений, который и так все видят.
Гармонист
Сообщение #16 VEG » 27.07.2019, 13:08
Beta 2
  • Fixed Selection Properties panel showing blank content in some cases.
  • Properties dialog: made some column widths remembered.
  • Properties dialog: made album art import/export dialogs begin in the folder of the audio file.
  • Properties dialog: restored sanity of Details group order.
  • Properties dialog: other minor fixes.
  • Screen reader compatibility fixes for new list controls
  • File Operations: fixed disappearing windows on Windows 10 1809 and newer.
Beta 3
  • Properties dialog: fixed crashing on single CPU core machines.
  • Properties dialog: tab order sanity fix.
  • Properties dialog: made '+ add new' field list autocomplete not exclude already-present fields.
  • File Operations: fixed crash bug related to delete command.
  • Made stack overflow crashes produce a crash report instead of just making foobar2000 die quietly.
  • Amended Enter key handling in various new list controls.
  • Screen reader compatibility fixes, made checkboxes in new list controls presented properly.
  • Experimental visual style changes on various new list controls.
Beta 4
  • Fixed beta 3 regression with wrong rendering of selection in some of list controls, most notably Default UI playlist.
  • Updated enter key handling in DSP Manager.
Beta 5
  • Properties dialog: better auto sizing of columns in Metadata & Details.
  • Properties dialog: less glitchy embedding of tab content in tabs.
  • Properties dialog: re-styled '+ add new' button.
  • Restored enter key to open decoder configuration in Preferences / Decoding.
  • Fixed embedded cuesheet handling regressions (since 1.5 beta).
  • Screen reader compatibility fixes, made list group headers presented correctly.
Beta 6
  • Fixed visual glitches when scrolling various lists (beta 5 regression).
  • Fixed incorrect automatic sizing of columns in Properties dialog.
Beta 7
  • Fixed incorrect shuffle behavior
  • Fixed Album List multi-selection regression
  • Attempted fix for DirectSound lockups after PC hibernation
  • Made Album Art Viewer picture loading+resizing asynchronous.
  • Removed the much hated behavior of nulling current selection info (album art, selection properties) when nothing has focus.
  • Fixed M4A album art handling regression
Отсюда.
Сообщение #17 seriousstas » 28.07.2019, 12:03
Воз и ныне там :
https://youtu.be/GBsPtu1LEM8
С нами: 11 лет 6 месяцев
Сообщение #18 VEG » 28.07.2019, 14:54
Вы главное не забывайте это сообщать автору плеера ;) Я вот недавно просил пофиксить графический косяк в новом диалоге свойств (где мета-теги, ReplayGain и обложки собраны в одном месте) — пофиксил именно так как я просил.
Сообщение #19 seriousstas » 29.07.2019, 05:05
VEG:Вы главное не забывайте это сообщать автору плеера ;)
https://hydrogenaud.io/index.php/topic,117913.0.html
Сообщение #20 VEG » 09.08.2019, 09:16
Beta 8
  • Fixed keyboard shortcuts for Yes/No buttons etc not working in some of MessageBox-type dialogs forum thread
  • Fixed album art crash on malformed picture data (beta 7 regression).
  • Fixed selection properties not following playback when nothing is focused (beta 7 regression) forum thread
  • Improved performance of updating tags on the now-playing track.
  • Made show_preferences() and various methods accept advanced preferences item GUIDs alongside preferences page GUIDs. This means that components can now have 'configure' links/buttons open Advanced Preferences locations.
  • New programming interfaces: input_info_filter (for foo_external_tags) and input_playback_shim (for foo_skip), new SDK will be published shortly.
  • Fixed bugs in lyrics3 tag reader introduced with beta 7.
  • Converter: Added Opus encoder selection for --music / --speech modes.
Beta 9
  • Fixed beta 8 crash regression.
