foobar2000 v1.6.0
Сообщение #1 VEG » 30.06.2020, 14:07
Вышла финальная версия foobar2000 v1.6.0! Предыдущая версия: foobar2000 v1.5.5.
  • Changed system requirements: Windows 7 and a processor with SSE2 instruction set. Windows XP is no longer supported.
  • Default output mode is now WASAPI shared.
  • New fading capability that works with alternate output modes.
  • Default archive reader now supports 7-zip format.
  • Added support for WebP album covers (Default UI, Properties dialog). Settings need to be changed to look for folder.webp instead of folder.jpg.
  • Removed mixer volume sync feature due to bugs.
  • Cleaned up foo_rgscan alter-file-content & alter-opus-header methods.
  • Removed obsolete edit-replaygain-info menu command since Properties dialog does the same now.
  • Added an option to disregard mouse back/forward buttons (by default mapped to previous/next track).
  • Double clicking a line in Properties album art tab now opens a fullsize image viewer.
  • Fileops & Converter: Added alternate handling of invalid filename characters, toggled in Advanced Preferences.
  • Freedb component updated: now queries all configured servers and displays results grouped by server.
  • Updated File Operations & Converter file name pattern picker dialog, now auto selects current pattern on open if possible.
  • CDDA reading no longer requires admin privileges on Windows Server.
  • Updated autoplaylist editing dialogs, made resizable.
  • Standard DSP Array is no longer an optional component, as it's required for new WASAPI output to work correctly.
  • Converter: Added a toggle for encoding thru temp folder to custom command-line encoder setup, required for some encoders that don't support Unicode.
  • Added alternate menu commands for opening Properties dialog with specific tab open, for mapping keyboard shortcuts only.
  • Improved recovery from unplugged audio output device.
  • Additional editable Properties ReplayGain tab summary fields.
  • Fixed crash when trying to alter gain on a Matroska file with no recognized audio track.
  • Fixed incorrect handling of folder/file.ext relative paths in playlists served over HTTP/HTTPS/FTP.
  • New portable install puts all configuration data in 'profile' subfolder of install folder instead of saving in the installation folder directly. Doesn't affect upgraded installs or non-portable.
  • Fixed 'remove tags' not correctly stripping tags from raw AAC files.
  • Fixed ZIP reader memory leak.
  • Improved handling of last modification times in ZIP and RAR archives.
  • Fixed a bug causing high CPU usage with autoplaylists that are force-sorted but with no pattern specified.
  • Fixed installer incorrectly labelling some components as incompatible, if they have been installed by copying DLLs manually.
  • Fixed incorrect handling of ID3 itunescompilation=0.
  • Fixed a bug causing files with very long names inside ZIP archives to be unplayable.
Автор темы, Администратор
С нами: 14 лет 3 месяца
Сообщение #61 iPhoneSasuke » 01.08.2020, 20:21
Что за баги с WASAPI пофиксили в 9,10 бетах?
iPhoneSasuke M
С нами: 11 лет 7 месяцев
Сообщение #62 Azaza » 01.08.2020, 20:53
iPhoneSasuke:Что за баги с WASAPI пофиксили в 9,10 бетах?
https://hydrogenaud.io/index.php?topic=119596.0
https://hydrogenaud.io/index.php?topic=119606.0
С нами: 9 лет 11 месяцев
Сообщение #63 iPhoneSasuke » 06.08.2020, 21:33
Когда Beta 12?
Надо как-то Питеру сообщить, что Output нужно немного переработать: всё прекрасно влезает в окно и без прокрутки, нужно просто сдвинуть элементы вверх и окошко увеличить немного по высоте.
iPhoneSasuke M
Сообщение #64 Azaza » 07.08.2020, 17:26
iPhoneSasuke, оно, как бы, и так всё влезает. Вероятно, у Вас в системе установлен очень крупный масштаб.
Сообщение #65 Azaza » 08.08.2020, 11:53
Azaza:При этом по умолчанию используется ресемплер PPHS
Как выяснилось, по умолчанию выбор используемого ресемплера происходит случайным образом при каждом запуске плеера :biggrin:
Сообщение #66 iPhoneSasuke » 09.08.2020, 04:11
Azaza:Вероятно, у Вас в системе установлен очень крупный масштаб.
Масштаб штандартный. Скорее, дело в разных операционках. У меня десятка. Возможно, несколько по-разному шрифты встраиваются. Кстати, мой скрин в масштабе 1:1.
Azaza:по умолчанию выбор используемого ресемплера происходит случайным образом при каждом запуске плеера
Безобразие... Пусть уже Питер причешет самые горячие плагины и принципиально важный функционал. Кстати, тот же WASAPI Shared активно обновляется и якобы (судя по описанию) плавнее переключает... встроил бы, что ли...
iPhoneSasuke M
Сообщение #67 Azaza » 10.08.2020, 19:54
iPhoneSasuke:Скорее, дело в разных операционках.
Выше в этой теме есть скрин с семёрки, на котором тоже не влезает:
https://foobar2000.club/forum/viewtopic.php?p=77320#p77320
Странно, почему же у меня всё влезает :think:
Видимо, дело в системных настройках шрифтов, которые у меня не по умолчанию.
Сообщение #68 postED » 10.08.2020, 20:16
У меня тоже не влезает, десятка с дефолтными шрифтами и масштабом.
Сообщение #69 iPhoneSasuke » 10.08.2020, 20:21
Я проверял — можно передвинуть интерфейс вверх + расширить окошко со списком, всё прекрасно влезает и не наплывает друг на друга. Но лучше пусть разработчик это реализует, чем каждый раз в ручную править при обновлении.
iPhoneSasuke M
Сообщение #70 Azaza » 18.08.2020, 09:00
Beta 12
Removing tags from raw AAC files now works properly.
Changed automatic resampling behaviors. Choice of output method no longer affects the visualisations.
The default output now works properly if fed sample rate different from what it expects, resamples on its own if needed (otherwise ABX component would not work).
If not overridden by user, the default resampler for automatic conversions is SSRC.
File Operations, Converter: Fixed file name sanitizer removing additional dots before the file extension.
Сообщение #71 postED » 18.08.2020, 22:54
И сразу же beta 13
* Fixed ZIP reader memory leak bug.
* Improved behavior when audio output device is in exclusive use by another application.
Сообщение #72 iPhoneSasuke » 19.08.2020, 10:31
В общем, новых багов больше, чем улучшений.
iPhoneSasuke M
Сообщение #73 VEG » 19.08.2020, 12:44
Бета-версии и выпускают, чтобы находить баги. Не бывает такого, чтобы программа дорабатывалась, и не было новых ошибок.
Сообщение #74 iPhoneSasuke » 20.08.2020, 00:17
Да, но прикол сводится к тому, что если откатиться на 1.5.1, то получится всё то же самое, но без багов :toothless:
iPhoneSasuke M
Сообщение #75 LUR » 20.08.2020, 00:19
iPhoneSasuke:Да, но прикол сводится к тому, что если откатиться на 1.5.1
А кто вас заставляет сидеть на версиях старше и с багами?
Сообщение #76 iPhoneSasuke » 20.08.2020, 02:21
LUR:А кто вас заставляет сидеть на версиях старше и с багами?
Никто не заставляет. Но в сравнении с версиями 0.х есть прогресс налицо, в т.ч. по плагинам. Вот и от новья теперь жду улучшений.
iPhoneSasuke M
Сообщение #77 VlaKor » 20.08.2020, 22:56
iPhoneSasuke:В общем, новых багов больше, чем улучшений.
Вам хоть один из багов бета версий реально встретился?
Думаю что как и мне и большинству пользователей о них стало известно только из change log.
VlaKor
С нами: 8 лет 11 месяцев
Сообщение #78 iPhoneSasuke » 21.08.2020, 01:42
VlaKor:Вам хоть один из багов бета версий реально встретился?
Я, например, писал, что именно в 1.6 столкнулся с затыками при перемотки треков, которые возникают рандомно.
iPhoneSasuke M
Сообщение #79 VlaKor » 21.08.2020, 12:01
iPhoneSasuke:Я, например, писал, что именно в 1.6 столкнулся с затыками при перемотки треков, которые возникают рандомно.
Это которое:
"Changes in beta 5
Fixed incorrect behavior when repeatedly hitting prev/next with fading enabled." ?
VlaKor
Сообщение #80 iPhoneSasuke » 21.08.2020, 13:51
VlaKor:Changes in beta 5
Не знаю. Я из любопытства на beta 2 сижу. Новые беты постоянно выпускаются и когда читаешь их логи, кажется: «О, ужас!». Поэтому жду релиза.
А вот в 1.5.5 для себя вообще позитивных моментов не заметил.
iPhoneSasuke M
