foobar2000 v1.6.1+
Сообщение #1 VEG » 02.09.2020, 15:09
Вышла финальная версия foobar2000 v1.6.1! Предыдущая версия: foobar2000 v1.6.0. Версия для Windows XP: foobar2000 v1.5.6+.
  • Added support for HLS: HTTP Live Streaming. To use, add internet M3U8 file through Add Location dialog.
  • Enabled icy-metadata support for Ogg FLAC internet radio streams.
  • Updated Properties / ReplayGain page layout if editing a single file.
  • Improved Properties dialog performance, list of autocomplete entries is populated asynchronously.
  • Enabled embedded album art loading from raw .AAC files with ID3 tags.
  • Updated FFmpeg to 4.3.1.
  • Added support for playing Matroska A_MS/ACM content.
  • Fixes for rare AAC codec configurations that FFmpeg doesn't fully support - an add-on decoder can override the built-in one for such special cases.
  • Decoders are now made aware of output sample rate (from Windows Mixer settings) and can decode certain formats directly to the intended sample rate, skipping potential resampling steps.
  • Fixed "fade on manual track change" setting not being used since version 1.6. (beta 6)
  • Changing volume no longer affects Windows Mixer sliders; restarting foobar2000 no longer resets Windows Mixer slider to 100%. (beta 7)
  • Mitigated crash when initiating drag&drop of a very large number of songs (such as Album List "all music"). (beta 8)
  • Enabled support for 7-zip archives using PPMd compression. (beta 8)
Автор темы, Администратор
С нами: 14 лет 5 месяцев
Сообщение #81 Гармонист » 29.04.2021, 11:41
Ни в коем случае не ставьте версию 1.66 beta 6 ==> 666
Гармонист
Сообщение #82 VEG » 04.05.2021, 12:07
beta 5
  • Fixed failure to read some rare MP4/M4A files.
  • Converter: Added a toggle for FLAC seektable fix.
Сообщение #83 VEG » 05.05.2021, 12:10
beta 6
  • Fixed Default UI playlist rendering glitches with millions of items.
Сообщение #84 SergPuh.68 » 05.05.2021, 15:25
Ну прям не знаю,скачивать или нет :wink:
С нами: 7 лет 9 месяцев
Сообщение #85 str » 08.05.2021, 17:51
Миллион треков?
str M
Сообщение #86 VEG » 11.05.2021, 01:18
beta 7
  • Fixed decoding of 7-channel FLAC files.
  • Made FLAC channel mask not cleared with 'remove tags'.
  • Improved compatibility with badly configured HLS radio servers.
Сообщение #87 VEG » 12.05.2021, 17:59
beta 8
  • Fixed odd samplerate autoresampling regression from earlier betas.
Сообщение #88 LUR » 18.05.2021, 02:54
foobar2000 v1.6.6 final
LUR M Онлайн
С нами: 13 лет 10 месяцев
Сообщение #89 VEG » 18.05.2021, 10:36
Я уж думал до десятка бет дойдёт =) Давно не было такого количества бет для одного релиза.
Сообщение #90 Vittorio » 19.05.2021, 13:34
"Added support for internet radio album art." - кто-нибудь пробовал? у меня не получилось...
Vittorio
С нами: 11 лет
Сообщение #91 Azaza » 19.05.2021, 22:10
Vittorio:"Added support for internet radio album art." - кто-нибудь пробовал? у меня не получилось...
Имеется в виду, что теперь для радиопотоков, передающих обложку, плеер её отображает. Пример потока с обложками - https://stream.radioparadise.com/aac-320
С нами: 10 лет 1 месяц
Сообщение #92 SergPuh.68 » 20.05.2021, 08:25
У меня тоже не отображается,может нужно какие то настройки дополнительные сделать?
Сообщение #93 Azaza » 20.05.2021, 08:44
В Properties не отображается, да. Отображается в Album art viewer, в DUI.
foobar2000 v1.6.7
Сообщение #94 VEG » 20.05.2021, 15:21
Вышла финальная версия foobar2000 v1.6.7!
  • Built-in WASAPI exclusive output.
  • Added 'smart stop' option in Advanced Preferences; press stop key once to stop-after-current, twice to stop now.
  • Fixed WavPack lossy not working regression from 1.6.6.
  • Made Output preferences reflect output device changes made by output picker toolbar (beta 5).
  • Allowed per-track REM COMMENT in cuesheets. (beta 6)
  • HLS radio bug fixes. (beta 6)
  • Fixed crashing on failed paste operations in Properties dialog. (beta 6)
  • Fixed incorrect handling of UTF-8 file names inside ZIP archives. (beta 6)
  • Removed 8-bit output option. (beta 7)
  • Fixed inaccurate preamp decibel formatting in Converter setup dialog. (beta 7)
  • Prevented popup of Preferences page prompting for a valid output device if the audio device was unplugged with foobar2000 in background. (beta 13)
  • Added .weba (WebM audio) to recognized extensions. (beta 15)
Сообщение #95 VEG » 20.05.2021, 15:23
Для версии 1.6 изначально напрашивалась опция для выбора между Shared и Exclusive WASAPI, и вот подвезли наконец, так что отдельные плагины для этого дела больше не будут путать людей.
Сообщение #96 iPhoneSasuke » 20.05.2021, 15:56
Еще напрашивалось не навязывание только новых компонентов, особенно когда сборка повёрнута на дизайне старых) Мне вот жутко нравится энкодер из сборки Alex Realist, стилизованной под WMP. Теперь либо новые конвертеры переделывать в ручную каждый раз до неузнаваемости, либо искать способ обмануть плеер, чтоб думал, что старьё это новьё)
Как Питер обосновывает потребность в Exclusive? Конечно, формально нехорошо, что только один вариант был, но какой практический смысл к эксклюзиве...
iPhoneSasuke M
С нами: 11 лет 9 месяцев
Сообщение #97 VEG » 20.05.2021, 15:59
Ну добавить такую опцию легко, есть любители, и минус один плагин. Почему бы и нет? А так в целом рациональной нужды в эксклюзивном режиме нет. Но если кому-то для успокоения вдруг нужно, то вот будет опция.
Сообщение #98 Azaza » 20.05.2021, 17:53
Пока что новый Exclusive работает очень коряво.
Сообщение #99 Гармонист » 21.05.2021, 09:25
Встроенный WASAPI exclusive может повысить скорость запуска музыки за счет экономии времени необходимого на инициализацию плагина. Что касается опасений любителей "сборок", то давно уже сказано Питером, что Фубар предназначен только для индивидуального кофигурирования. Не превращайте Фубар в помойку! Авторы помоек-сборок получают доходы от скачиваний и идут супротив замыслу Питера.
Гармонист
Сообщение #100 iPhoneSasuke » 21.05.2021, 23:07
Azaza:Пока что новый Exclusive работает очень коряво.
Встроенный Wasapi постоянно работал так себе на момент внедрения. Слишком спешит автор.
iPhoneSasuke M
