foobar2000 v1.6.1+
Сообщение #1 VEG » 02.09.2020, 15:09
Вышла финальная версия foobar2000 v1.6.1! Предыдущая версия: foobar2000 v1.6.0. Версия для Windows XP: foobar2000 v1.5.6+.
  • Added support for HLS: HTTP Live Streaming. To use, add internet M3U8 file through Add Location dialog.
  • Enabled icy-metadata support for Ogg FLAC internet radio streams.
  • Updated Properties / ReplayGain page layout if editing a single file.
  • Improved Properties dialog performance, list of autocomplete entries is populated asynchronously.
  • Enabled embedded album art loading from raw .AAC files with ID3 tags.
  • Updated FFmpeg to 4.3.1.
  • Added support for playing Matroska A_MS/ACM content.
  • Fixes for rare AAC codec configurations that FFmpeg doesn't fully support - an add-on decoder can override the built-in one for such special cases.
  • Decoders are now made aware of output sample rate (from Windows Mixer settings) and can decode certain formats directly to the intended sample rate, skipping potential resampling steps.
  • Fixed "fade on manual track change" setting not being used since version 1.6. (beta 6)
  • Changing volume no longer affects Windows Mixer sliders; restarting foobar2000 no longer resets Windows Mixer slider to 100%. (beta 7)
  • Mitigated crash when initiating drag&drop of a very large number of songs (such as Album List "all music"). (beta 8)
  • Enabled support for 7-zip archives using PPMd compression. (beta 8)
Автор темы, Администратор
С нами: 14 лет 4 месяца
Сообщение #121 postED » 23.06.2021, 15:26
Beta 13
  • Prevented popup of Preferences page prompting for a valid output device if the audio device was unplugged with foobar2000 in background.
  • Re-added Advanced Preferences setting to override exclusive-mode hardware buffer length.
  • Added a special fix for FOSTEX cards that do not work with system-default buffer length.
  • Fixed missing remapping of 5.1 vs 5.1-side channel configurations with exclusive mode.
На ветке Support оффорума долгожданное затишье :biggrin:
Сообщение #122 VEG » 24.06.2021, 13:08
Может кто-то сохранил beta 5 и beta 6? Было бы интересно найти пасхалочку =)
Сообщение #123 Azaza » 24.06.2021, 13:23
VEG:Может кто-то сохранил beta 5 и beta 6? Было бы интересно найти пасхалочку =)
https://www.foobar2000.org/getfile/foobar2000_v1.6.7_beta_5.exe
https://www.foobar2000.org/getfile/foobar2000_v1.6.7_beta_6.exe
https://www.foobar2000.org/getfile/foobar2000_v1.6.7_beta_7.exe
С нами: 9 лет 11 месяцев
Сообщение #124 VEG » 24.06.2021, 13:26
Хех, точно =) На досуге может гляну, если никто другой не найдёт.
Сообщение #125 VEG » 28.06.2021, 21:37
Beta 14
  • Worked around glitched playback after a buffer underrun.
Сообщение #126 VEG » 29.06.2021, 16:12
Beta 15
  • Added .weba (WebM audio) to recognized formats.
  • Attempted WASAPI exclusive compatibility fixes (timed polling instead of event, 50ms default hardware buffer).
Сообщение #127 VEG » 02.07.2021, 12:19
Кажется, у нас рекордсмен по количеству бета-версий =)
Сообщение #128 postED » 02.07.2021, 16:36
VEG, в 1.6 вроде больше было. Не меньше 17, насколько я помню. Но вот для минорной версии наверняка рекорд)
Сообщение #129 VEG » 02.07.2021, 23:51
Beta 16
  • WASAPI compatibility fixes. Defaults are equivalent to well-behaved beta 13 (event instead of polling). You can override if your device doesn't agree.
Сообщение #130 iPhoneSasuke » 17.07.2021, 17:41
Да что ж всё так сложно с этим WASAPI? Мой допотопный Parasound жуёт всё, что ему плеер даст, а тут современные умные девайсы еще и капризничают?
iPhoneSasuke M
С нами: 11 лет 7 месяцев
Сообщение #131 VEG » 27.07.2021, 17:54
Beta 17
  • Refactored exclusive mode overrides in Advanced Preferences.
  • Added a specific workaround for Intel SST Audio, so exclusive mode works without manual tweaks.
  • Prevented foobar2000 from starting up with foo_dsp_std.dll missing, or else normal playback fails. Note that this can only happen as a result of tampering with the installation, as foo_dsp_std.dll is always installed.
Сообщение #132 Гармонист » 10.08.2021, 14:23
Вышла новая версия. 1.6.7
Вот что я сделал....
1. Удалил компонент WASAPI output support 3.4
2. В Output - выбрал аппаратное имя моего ЦАПА с припиской [exclusive]
Вроде все работает. При включении Foobara отключается другой плеер. Значит режим exclusive работает. Таким образом можно избавится от компонента WASAPI output support 3.4. Наверно обработка сигнала стала проще. Верно?
Гармонист
Сообщение #133 VEG » 10.08.2021, 22:19
Final
  • Removed startup popups about old WASAPI component being outdated.
  • Improved exclusive mode compatibility with audio drivers that incorrectly report supported format list.
Сообщение #134 OlolOшник » 13.08.2021, 07:05
Не понял, что означает галочка в настройках "Exclusive output overrides".
Что с установленной галкой, что без нее, звука в других приложениях нет.
Как правильно-то?
OlolOшник
С нами: 5 лет
Сообщение #135 Azaza » 13.08.2021, 17:43
OlolOшник:Не понял, что означает галочка в настройках "Exclusive output overrides".
Как правильно-то?
При использовании режима exclusive в фубаре звука из других приложений и не должно быть. Включать "Exclusive output overrides" и вручную устанавливать размер буфера следует только в том случае, когда с настройками по умолчанию есть какие-то проблемы с работой режима exclusive.
Сообщение #136 Гармонист » 13.08.2021, 18:53
Как правильно-то?
У меня эта галочка вообще исчезла. Эксклюзив работает и без неё. Скорее всего у вас какой то компонент у которого есть эта галка. Думаю его можно уже удалить для распрямления пути сигнала.
Гармонист
Сообщение #137 Azaza » 13.08.2021, 19:41
Гармонист:У меня эта галочка вообще исчезла. Эксклюзив работает и без неё. Скорее всего у вас какой то компонент у которого есть эта галка.
Эта галка относится не к компоненту, а к встроенному режиму exclusive, появившемуся в 1.6.7.
Сообщение #138 OlolOшник » 13.08.2021, 20:54
Azaza:При использовании режима exclusive в фубаре звука из других приложений и не должно быть. Включать "Exclusive output overrides" и вручную устанавливать размер буфера следует только в том случае, когда с настройками по умолчанию есть какие-то проблемы с работой режима exclusive.
Хотелось бы понять, что за что отвечает...
Нижняя галочка - включает Event mode, ее снятие включает Push mode - это ясно.
Средний параметр задает значение буфера в ms, однако, почему-то, в моем случае, увеличение буфера даже до больших значений не приводит к "заторможенности анимации" спектроанализаторов, как это всегда было при использовании старого компонента wasapi exclusive; при использовании ASIO, при максимальном буфере в 50 ms, тоже есть "заторможенности анимации", а тут сколько ни поставь - нету тормозов.
Значит ли это, что настройка просто не работает и всегда остается значение по-умолчанию? - Без понятия...
Причем "заторможенности" нет как при выключенной опции "Exclusive output overrides", так и при включенной.
Объясните, пожалуйста, подробно, очень хочу понять, какой параметр за что отвечает!
OlolOшник
С нами: 5 лет
Сообщение #139 Гармонист » 13.08.2021, 20:57
Я вот здесь выбрал Эксклюзив
Гармонист
Сообщение #140 Azaza » 13.08.2021, 21:35
OlolOшник:Хотелось бы понять, что за что отвечает...
Когда галка "Exclusive output overrides" снята, то галка Use event ни на что не влияет и заданное значение буфера тоже ни на что не влияет, т.к. при снятой галке "Exclusive output overrides" используются оптимальные параметры по умолчанию.
При установленной галке "Exclusive output overrides" можно переключать режим режим Event или Push галкой Use event mode и задавать размер буфера.
Просто так без надобности менять эти настройки не рекомендуется, а то при кривых драйверах можно и BSOD получить. Пример - https://hydrogenaud.io/index.php?topic=121356.0
Этот новый встроенный режим exclusive был написан с нуля, так что сравнивать его поведение с поведением старого компонента нет особого смысла.
