  • User interface updates:
  • DSP technology updates:
  • Properties dialog updates:
    • foo_benchmark
    • foo_bitcompare
    • foo_verifier
    • foo_input_monkey
    • foo_ac3
    • foo_sanitizer
    • foo_input_dts
    • foo_rgscan
    • foo_cdda
    • foo_albumlist
  • Other:
Автор темы, Администратор
С нами: 14 лет 4 месяца
Сообщение #2 VEG » 01.09.2022, 00:23
Beta 2
  • Fixed crash on old configuration import.
Beta 3
  • Component loader no longer probes menu command GUIDs, which was crashing some components. Was meant to prevent specific known incompatible components from loading.
  • Now shows CPU architecture (x86 or x64) in about box.
  • Fixed Media Library performing unnecessary tag reloads in some scenarios.
  • Crash bugs fixed.
  • Made Preferences / Output / Devices usable without a mouse.
Сообщение #3 VEG » 06.09.2022, 18:53
Beta 4
  • MP4 tagging: do not set Various Artists if itunescompilation is present but set to 0.
  • Crash bugs fixed.
  • Made installer refuse to upgrade old non-portable installs containing profile data in application folder, which is no longer supported.
  • Fixed metadb lock up with large queryInfoMulti() batches.
  • Fixed library search by rating not working.
  • Added ReFacets to library viewers list.
  • Fixed missing double click to fullscreen in Default UI visualisations.
  • Fixed disappearing live playback info on playback statistics update.
  • Fixed longer-than-necessary gap when reopening exclusive-mode output on format change.
  • Fixed seekbar & visualisation glitches when playing very short audio tracks with exclusive-mode output.
Сообщение #4 VEG » 10.09.2022, 00:20
Beta 5
  • Fixed various crash bugs.
  • Improved rendering performance of very large playlists with grouping & album art enabled.
  • Made ReFacets sorting remembered.
  • Fixed inverted titles of "Add Files" vs "Open" dialogs.
  • Reduced output reopen delay when input format (channel count etc) changes.
  • Improved dark mode rendering of checkboxes.
  • Suppressed library error log lines about folder.jpg etc inside archive files.
Beta 6
  • Fixed playlist layout glitch regression from beta 5.
Сообщение #5 George Smith » 11.09.2022, 10:13
Подскажите, а в чём смысл устанавливать 64-битную версию?
George Smith
Сообщение #6 LUR » 11.09.2022, 16:04
George Smith:Подскажите, а в чём смысл устанавливать 64-битную версию?
Вопрос неоднозначный для тех, кто не может туда поставить 32-разрядные плагины)
Сообщение #7 VEG » 11.09.2022, 17:59
Пригодится для случая, если у кого-то огромная библиотека, из-за которой текущая версия плеера просто падает (относительно недавно видел такую жалобу на HA). Ну и в целом, 32-разрядные системы уходят в прошлое, все современные процессоры 64-разрядные, при прочих равных смысла использовать устаревший 32-разрядный режим нет. Производительность вычислительных задач (типа декодирования) в 64-разрядном коде будет почти наверняка выше, что тоже небольшой, но плюсик.
Минус — все старые плагины надо будет адаптировать под 64 бита и пересобрать, плюс внести изменения в код работы с библиотекой, так как она теперь совершенно иначе устроена и не загружает сразу все метаданные в память. 32-разрядная версия foobar2000 2.0 будет совместима со старыми плагинами, но встроенный слой совместимости со старым API для работы с плей-листом медленный, так что какие-то плагины, которые сильно полагаются на старую организацию библиотеки, могут работать медленно, если их не адаптируют под новую версию. В общем, плагины всё равно надо адаптировать, а раз так, то можно сразу и на 64 бита перейти.
Ну и нативная ARM-версия, которую тоже обещают сделать, пригодится для экономии заряда аккумулятора, так как эмуляция x86 не бесплатна. Ещё ни разу не видел, чтобы кто-то такими ноутами пользовался, но если вдруг кто-то умудрился такое купить (или вдруг в будущем винда на ARM станет популярнее), то пригодится =)
Сообщение #8 iPhoneSasuke » 12.09.2022, 02:42
А можно в 1.5.1 воткнуть полезный функционал? Очень здорово редактировать актуальный список устройств.
А еще мне бы избавиться от 100500 лишних опций вывода
iPhoneSasuke M
С нами: 11 лет 7 месяцев
Сообщение #9 Гармонист » 12.09.2022, 21:37
Некоторые вычислительные процессы с большими числами могут работать быстрее. Актуальность такого перехода может быть продиктована внедрением Hi-Res и традиционным вычислительным прогрессом. Переход на 64 бита позволит отбросить гавноплагины и мейкеров так называемых "сборок" компрометирующих ФУБАР2000. Конечно интерфейсный арсенал нужно расширить, думаю что сейчас на этой волне и плагины появятся нового качества..
Гармонист
Сообщение #10 LUR » 13.09.2022, 11:58
Гармонист:и плагины появятся нового качества
а старые кто заменит? тут надо работать вширь, тем, то заинтересован в прогрессировании плеера. либо и правда, если перейдем на 64 битный JScript panel текнолоджи, тогда и в плагинах отпадет нужда.
Сообщение #11 George Smith » 13.09.2022, 16:01
Гармонист:позволит отбросить гавноплагины
Ну, думаю после перехода на версию 2 стразу будет понятно, какие плагины нужны, а какие просто лень удалить.
LUR:если перейдем на 64 битный JScript panel текнолоджи, тогда и в плагинах отпадет нужда
Будет шустрее работать?
George Smith
Сообщение #12 LUR » 13.09.2022, 22:32
George Smith:Будет шустрее работать?
Утверждать не буду, пока не пробовали, не замеряли) А в целом, 64бита уже давно данность, рано или поздно все к этому приходим, кто-то раньше, кто-то позже.
Сообщение #13 Qk3 » 14.09.2022, 08:27
LUR:64бита уже давно данность
Жду не дождусь 128-bit Windows и ПО под нее :)
Qk3
С нами: 8 лет 2 месяца
Сообщение #14 LUR » 14.09.2022, 16:56
Qk3:Жду не дождусь 128-bit Windows и ПО под нее :)
Ну да, смешно)
Сообщение #15 VEG » 14.09.2022, 17:37
Beta 7
  • libFLAC 1.4, made possible to decode 32 bits per sample FLAC files.
  • Upgrading from v1.x retains file timestamps of profile folder contents.
  • Fixed bad handling of user-components folder in upgraded legacy portable installs without a "profile" folder.
  • Playlist rendering and manipulation performance fixes.
  • DTS decode_postprocessor now works, for decoding DTS in WAV, FLAC, etc.
  • Fixed incorrect behavior after a watched media library folder disappears then reappears.
  • Allowed blank meta values in metadb.
  • Made possible to enable album art columns in Default UI playlist even without grouping enabled - the old behavior was confusing.
  • Added dark mode to Default UI toolbar buttons configuration dialog.
  • Made settings of old foo_albumlist & foo_sanitizer imported on startup, if present.
Сообщение #16 Rialto » 15.09.2022, 22:49
Beta 8
  • Fixed beta 7 regression with wrong handling of blank meta values.
  • Fixed some visual glitches in Converter.
  • Rare crash bug workarounds.
  • Improved crash log writer in 64-bit version.
Rialto
Сообщение #17 Qk3 » 20.09.2022, 08:59
VEG:все старые плагины надо будет адаптировать под 64 бита и пересобрать
Qk3
Сообщение #18 LUR » 21.09.2022, 00:18
Qk3, такие как этот собраны со старыми библиотеками, еще, которые под WinXP и т.д. Если автор ими не занимается, теперь такое может случиться.
Сообщение #19 VEG » 23.09.2022, 11:09
Beta 9
  • Updated WavPack library to 5.5.0.
  • Updated Monkey's Audio library to 8.70.
  • Fixed a regression that made it impossible to play certain M4A HE-AAC files from remote (HTTP etc) sources.
  • Various ReFacets glitches fixed.
  • Made new library search implementation more robust.
  • Crash bugs fixed.
Сообщение #20 VEG » 24.09.2022, 14:24
Beta 10
  • Fixed Ogg seeking regressions from the previous beta.
  • Made column order correctly remembered per-playlist.
  • libFLAC 1.4.1.
  • Rewritten asymmetric library search feature.
  • Library search speed optimizations, made more queries utilize search index.
  • Restored multi-folder-selection for "add folder".
