foobar2000 v2.24
Сообщение #1 VEG » 09.02.2024, 18:29
Вышел foobar2000 v2.24! Предыдущая версия: foobar2000 v2.1.
  • New version numbering scheme: 2.24 for planned stable release year of 2024.
  • Internet radio bug fixes & reliability improvements.
  • Codec & audio format fixes, most notably:
    • Implemented Ogg chapter support.
    • MP4/M4A/M4B tagging & chapter manipulation fixes.
    • WAV compatibility fixes; made zero-length WAV files reported as broken.
    • Cuesheet compatibility improvements - allowed absolute path, allowed playback over network.
  • Usability improvements, most notably:
    • Fixed inconsistent drag&drop behavior when dragging items between playlists.
    • Made current console backlog saved when toggling logging on.
    • Prevented Media Library search from clearing other playlists with enter key if library selection playlist feature is active.
  • General improvements, most notably:
    • New major revision of bitcompare code, improved performance of 64-bit build.
    • Improved stability of hardware-accelerated visualizations.
    • Improved recovery of corrupted configuration data.
  • Converter:
    • Mitigation for Converter failures when writing to a Google Drive volume.
    • More detailed error messages for specific file creation errors.
    • Can write multichapter Ogg files after disabling Ogg chaining support.
  • File Operations:
    • Suppressed useless secondary progress bar if renaming files.
    • Defer info reload to prevent bugged display of cuesheets after moving whole folder.
    • Added an option to overwrite existing files.
    • Updated recycle bin detection logic, mitigating lag/lockup occurring for some users.
  • Third party code libraries updated.
  • Various other tweaks & fixes, see release notes for full list of changes.
Автор темы, Администратор
С нами: 14 лет 1 месяц
Сообщение #2 VEG » 14.02.2024, 15:57
2024-02-05
  • Implemented Ogg chapter support. Converter can write multichapter Ogg files after disabling Ogg chaining support.
  • Allow local M3U referencing remote M3U to be both read as playlists, prevent HLS reader being used on non-HLS content.
  • Updated File Operations recycle bin detection logic, mitigating lag/lockup occurring for some users.
  • Made network encryption error messages more useful.
  • Stop decoding ADTS AAC when running into APE tags, instead of reporting errors.
  • Report zero-length WAV files as broken.
  • Wine compatibility fixes.
2024-02-12
  • Improved ReFacets performance.
  • Fixed erratic behavior if ID3v2 tag contains multiple date fields.
  • Suppressed advancing to the next playlist item if internet radio playback stops due to a network error.
  • File Operations: Added an option to overwrite existing files.
  • Suppressed repeating console messages about decoder shims used.
  • More thorough error reporting for blank WAV files.
  • Added video_codec info for Windows Media Video.
  • Added stream_count info for formats that support multiple streams.
Сообщение #3 VEG » 19.02.2024, 22:38
2024-02-19
  • Fixed regression preventing internet radio album covers from being shown.
  • Applied dark mode to component license popup.
  • Updated zlib to 1.3.1.
Сообщение #4 LUR » 29.02.2024, 12:07
2024-02-28
  • Playback CPU usage optimizations.
  • Small chunks returned by decoder are merged into one to reduce amount of wakeup cycles during playback.
  • Made possible to store peak information in Opus files.
С нами: 13 лет 7 месяцев
Сообщение #5 VEG » 04.03.2024, 21:53
2024-03-04
  • Worked around audio glitches with very low output buffer size introduced in previous build.
  • Fixed glitchy seekbar movement in certain scenarios.
  • Prevented nonsensical video codec names from being reported for certain MP4 files.
  • Fixed regressions in ASX playlist loader.
  • Converter: More detailed error messages for specific file creation errors.
Сообщение #6 Miner » 08.03.2024, 09:25
Сайт недоступен. Невозможно скачать
Miner
С нами: 2 года 3 месяца
Сообщение #7 LUR » 08.03.2024, 16:17
Miner:Сайт недоступен. Невозможно скачать
Подтверждаем, официальный сайт лежит. Наберитесь терпения.
Сообщение #8 VEG » 08.03.2024, 23:21
2024-03-08
  • Mitigation for Converter failures when writing to Google Drive volume.
  • Opus decoder updated to 1.5.1
  • WavPack decoder updated to 5.7.0; made WavPack library version shown in components list.
  • Monkey's Audio decoder updated to 10.52
  • Cleaned up and bugfixed detection of MP4 video codec names.
  • Prevented nonsense sample rate & channel count from being shown on MP4 files with no audio track.
  • File Operations: Defer info reload to prevent bugged display of cuesheets after moving whole folder.
Сообщение #9 LUR » 14.03.2024, 18:03
2024-03-14
  • Playback CPU usage reduced.
  • Fixed exclusive output lagging in specific scenarios.
  • Add Location now strips extra non-text characters from the entered URL.
  • Made Ogg chapters beginning from CHAPTER001 recognized.
  • Allowed absolute paths in cue sheets.
  • Extended MP4 chapter manipulation commands to work with other formats that support chapterizer interface, such as Ogg or Musepack.
Сообщение #10 LUR » 18.03.2024, 21:10
2024-03-18
  • Fixed foobar2000 v2.0 regression causing folder watch events to be dropped without triggering full rescan if there's too many of them pending.
Сообщение #11 mik » 19.03.2024, 16:47
Так, инфа. Обновил до этой версии...и cd-rom в mode-RIP CD во Flac и WAV, перестал работать, как раньше. Виснит, блокирует foobar, с окном ошибки и больше не открывается. Приходится обновлять переустановкой.
Так и не смог сделать рипы. На предыдущих версиях работало без проблем. Откачу назад.
mik
С нами: 10 лет 7 месяцев
Сообщение #12 VEG » 22.03.2024, 21:37
2024-03-21
  • Made stream selector show long codec names.
  • Media Library: made track add & remove events triggered in groups, resulting in much faster autoplaylist updates.
Добавлено спустя 59 секунд:
mik, если это на чистом foobar2000 без сторонних доработок, то имеет смысл сообщить автору на Hydrogen Audio.
Сообщение #13 LUR » 28.03.2024, 05:03
2024-03-27
  • Create "disable-foocrash" in install folder to kill crash reporting (dump files still get written).
  • Run with /nocrashinfo to suppress generation of crash reports.
  • File Operations: Suppressed useless secondary progress bar if renaming files.
Сообщение #14 LUR » 30.03.2024, 00:22
2024-03-28
  • Fixed 2024-03-21 regression causing unnecessary Media Library disk access.
Сообщение #15 Rialto » 09.04.2024, 21:06
2024-04-07
  • Fixed very old and very rare Album List lock up bug.
  • Pause / resume playback on system sleep / resume.
  • Installer script update.
Rialto
Сообщение #16 VEG » 12.04.2024, 18:42
2024-04-10
  • ReFacets playlist interaction bug fixes.
  • ReFacets added "Last Modified" stats column.
  • Removed system sleep / resume handlers, didn't properly suppress errors with internet radio.
  • Made disconnected internet radio streams resumed quietly, without showing error popups.
  • 32-bit build: Removed tone generator assembly optimizations, tone:// should produce identical output in all versions now.
  • Updated to NSIS 3.10.
Сообщение #17 VEG » 15.04.2024, 22:11
2024-04-13
  • Fixed crash if freedb/gnudb server returns more tracks than asked for (regression since 2.0).
2024-04-15
  • Fixed stuck drag&drop scrolling mode in various list controls after receiving external drag&drop.
  • Made list control obey system drag threshold values, making it easier to register clicks if mouse moves slightly between mouse down and mouse up events.
  • Opus decoder updated to 1.5.2.
Сообщение #18 VEG » 28.04.2024, 11:48
2024-04-26
  • Cleaned up interaction with what's left of freedb.
    • Made more apparent which freedb-compatible service is in use.
    • If there are multiple providers configured, you can specifically choose one from CD Ripper dialog.
    • Discarded malformed server replies.
  • Fixed WASAPI Exclusive timing glitches with exotic settings.
  • Fixed regression in File Operations recycle bin detection, causing unwanted delete prompts when recycling.
  • Converter: Fail harder if "don't reset DSP between tracks" is on and one of files can't be converted - output past the point of failure wasn't valid anymore anyway.
2024-04-27
  • Fixed WASAPI exclusive regression from last build.
Сообщение #19 VEG » 01.05.2024, 22:16
2024-05-01
  • Removed gnudb from default online tagger settings, as gnudb now demands users to input their actual email addresses.
  • If you wish to use gnudb, you can configure it manually, but we strongly recommend against it.
  • Online tagger now defaults to freedb.dbpoweramp.com which works once again.
  • Changed storage of freedb server list settings, to a text file in profile folder.
  • Added toggle to disable tooltips in Album List.
Сообщение #20 VEG » 15.05.2024, 09:13
2024-05-13
  • Prevented all MP4 tag fields prefixed with replaygain_ from being treated as technical information, only actual ReplayGain fields are now such.
  • Workaround for ReplayGain scanner attempting to scan Audio CD in multiple threads.
  • Removed arbitrary denial of reading of cuesheets over FTP/HTTP/etc.
