foobar2000 v2.24
Сообщение #1 VEG » 09.02.2024, 18:29
Вышел foobar2000 v2.24! Предыдущая версия: foobar2000 v2.1.
  • New version numbering scheme: 2.24 for planned stable release year of 2024.
  • Internet radio bug fixes & reliability improvements.
  • Codec & audio format fixes, most notably:
    • Implemented Ogg chapter support.
    • MP4/M4A/M4B tagging & chapter manipulation fixes.
    • WAV compatibility fixes; made zero-length WAV files reported as broken.
    • Cuesheet compatibility improvements - allowed absolute path, allowed playback over network.
  • Usability improvements, most notably:
    • Fixed inconsistent drag&drop behavior when dragging items between playlists.
    • Made current console backlog saved when toggling logging on.
    • Prevented Media Library search from clearing other playlists with enter key if library selection playlist feature is active.
  • General improvements, most notably:
    • New major revision of bitcompare code, improved performance of 64-bit build.
    • Improved stability of hardware-accelerated visualizations.
    • Improved recovery of corrupted configuration data.
  • Converter:
    • Mitigation for Converter failures when writing to a Google Drive volume.
    • More detailed error messages for specific file creation errors.
    • Can write multichapter Ogg files after disabling Ogg chaining support.
  • File Operations:
    • Suppressed useless secondary progress bar if renaming files.
    • Defer info reload to prevent bugged display of cuesheets after moving whole folder.
    • Added an option to overwrite existing files.
    • Updated recycle bin detection logic, mitigating lag/lockup occurring for some users.
  • Third party code libraries updated.
  • Various other tweaks & fixes, see release notes for full list of changes.
Автор темы, Администратор
С нами: 14 лет 1 месяц
Сообщение #41 LUR » 15.11.2024, 04:17
2024-11-14
  • Updated Monkey's Audio to 10.80.
С нами: 13 лет 6 месяцев
Сообщение #42 VEG » 25.11.2024, 20:46
А вот и релиз! =)
Сообщение #43 VEG » 16.12.2024, 20:05
2.24.1 released on 2024-12-16
  • Fixed 2.24 regression causing certain visualizations, most notably VST adapter, to be jumpy.
  • Corrected some cases of unnecessary UI flickering on resize/redraw.
  • Made "sanitize tags" command respect "preserve file times" option.
Сообщение #44 LUR » 18.02.2025, 22:55
2.24.2 released on 2024-02-18
  • FLAC/WavPack/Monkey decoder update.
  • Fixed Album List crash on specific patterns or too many nested folders.
  • Made certain low-latency output configurations stutter less.
  • Updated Visual C++ runtime.
  • Installer now code-signed with Illustrate certificate.
Сообщение #45 VEG » 07.03.2025, 20:00
2.24.3 released on 2025-03-07
  • Fixed a bug that caused HLS radio streams to start playing past segments instead of current live segment.
  • Dark mode: fixed checkboxes not being drawn correctly with specific custom themes.
  • Dark mode: fixed specific icons being drawn in wrong size.
  • Fixed incorrect seeking in chained Ogg streams.
  • Fixed specific instances of crashing with malformed configuration data.
Сообщение #46 VEG » 01.05.2025, 20:11
2.24.4 released on 2025-05-01
  • Fixed multiple configuration file handling bugs.
  • Fixed setlocale() misuse breaking specific components after using Converter.
  • Additional safeguards against mixing program files from different incompatible foobar2000 versions.
  • Fixed foobar2000 v2.0 regression mangling multi line Album List patterns.
Сообщение #47 VEG » 10.05.2025, 20:12
2.24.5 released on 2025-05-09
  • Changed mapping of channels when playing 7.1 material on 5.1-rear setup; side channels no longer play on front+rear in such scenario.
  • Fixed incorrect handling of quotation marks in certain search queries.
  • Cleaned up error handling of Album List & ReFacets autoplaylist creation; no autoplaylist is created if entered search pattern isn't valid.
Сообщение #48 VEG » 06.07.2025, 20:14
2.24.6 released on 2025-07-06
  • Fixed excessive memory usage of visualizations in certain conditions.
  • Restored old behavior of M3U loader, local playlists referencing internet radio can again specify station names.
  • Improved compatibility with AAC radio streams that mix different metadata encoding types.
  • Made HTTP folders possible to load again.
  • Fixed erratic behavior when seeking back from near end of track.
  • Fixed safe mode (triggered after app crash) failing to start up.
  • Made respect embedded color profiles of JPEG & PNG album covers.
  • Fixed WASAPI shared mode audio stream format negotation bug.
Вернуться в Новости плеера
