foobar2000 v2.26 preview
Сообщение #1 VEG » 10.10.2025, 20:33
Вышел foobar2000 v2.26! Предыдущая версия: foobar2000 v2.25.
  • Improved recovery of malformed UTF-8 text in various tag formats.
  • Made malformed UTF-8 tags text reported in integrity verifier.
  • MP4 tagging improvements:
    • Tagtype info (Apple, Nero)
    • No longer writes Nero tags by default for single chapter files, only for multi chapter where other tagging formats can't store per track tags.
    • Added support for more rarely used Apple tag elements.
    • No longer alters binary structure of Apple tag elements which are not affected by edits.
  • Monkey's Audio decoding moved to FFmpeg, no longer including Monkey's Audio library with foobar2000 setup.
    • You can once again install Monkey's Audio decoder component to replace built-in FFmpeg decoder.
  • New info field: container (MP4, Matroska, Ogg, etc)
  • New title formatting field: %_cpu_arch%
  • Mac: made playlist view receive copy/paste from Finder
  • Mac: New icon from Apple Icon Composer
  • Mac: Built with Xcode 26, enabled macOS Tahoe looks.
  • Mac: Install components by drag&drop from Finder to components list.
  • Mac: Playlist Manager columns can be toggled.
  • Added drag&drop from Internet Radio pages to playlist.
  • Attempt to play a password-protected resource such as radio stream now shows a password prompt.
  • Converter: Better error messages when receiving unexpected data format change in mid-conversion; made discard blank chunks before checking for format match.
  • Equalizer now accepts presets via drag&drop from Explorer/Finder.
  • Workaround for foo_tags issue [being backported to 2.25.x]
  • Workaround for WAV headers claiming zero length [being backported to 2.25.x]
  • Fixed File Operations link vs portable relative paths [being backported to 2.25.x]
Автор темы, Администратор
С нами: 13 лет 10 месяцев
Сообщение #2 VEG » 13.10.2025, 09:29
2025-10-12
  • Windows: Fixed missing winsock init for SMB operations, causing all SMB access to fail if no other network features have been used first.
  • Fixed bad interaction between WebDAV filesystem and media library.
Сообщение #3 VEG » 17.10.2025, 09:15
2025-10-16
  • Mac: Changed remove-item-from-playlist selection behavior, now selects next item so keyboard navigation doesn't move selection to top of the playlist.
  • Fixed LD & ELD AAC not being reliably sent to alternate packet decoders.
  • Fixed Decoding Speed Test not remembering last used DSP chain.
Сообщение #4 VEG » 17.10.2025, 20:01
2025-10-17
  • Windows: Attempted workaround for repaint glitches in multiline editboxes introduced in latest Windows 11 update. Note that this is a bug in Windows not foobar2000.
  • Windows: Workaround for stuck visualizations if playback ends while foobar2000 is invisible.
Сообщение #5 VEG » 26.10.2025, 03:46
2025-10-24
  • Fixed very old race condition bugs in decoder merit management, potentially causing decoder to be listed twice.
  • Fixed regression turning playback file open errors to "critical errors", incorrectly halting playback instead of playing next file.
  • Added support for decoding TrueHD & MLP streams in Matroska.
  • Removed both extremely inefficient and inaccurate probing of Matroska track bitrate. Only bitrates reported by decoders (that is all AC3 bitrates) are shown, as well as live bitrates while playing.
  • Fixed missing info reload when changing stream via toolbar dropdown.
  • Added support for M4A "long description" tag.
  • Enabled experimental memory-mapped SQLite reading for configuration and metadb.
  • Made manual metadb garbagecollect always perform sqlite vacuum.
  • Mac: Fixed File Operations destination being editable in "rename" mode.
Сообщение #6 VEG » 29.10.2025, 20:47
2025-10-29
  • Replaced built-in SSRC resampler with ARDFTSRC.
  • Cleaned up resampler settings, removed pointless "exclude rates" checkboxes, added explicit hints about formatting.
  • Fixed TrueHD & MLP being shown as lossy.
Сообщение #7 VEG » 30.10.2025, 16:14
2025-10-30
  • Resampler fixes.
  • Suppressed specific slow Matroska integrity checks when opening file for both playback and integrity verification.
Сообщение #8 VEG » 31.10.2025, 20:15
2025-10-31
  • Resampler fixes.
  • Made resampler priority setting accept short names of resamplers, e.g. "retroarch;ardftsrc".
  • Windows: Fixed certain DSP setting pages being impossible to navigate if DSP manager was created as a modal popup.
Сообщение #9 VEG » 01.11.2025, 20:42
2025-11-01
  • Updated title formatting help with some recent and some not-really-recent additions.
  • Fixed one more obscure resampler bug.
Сообщение #10 VEG » 05.11.2025, 04:35
2025-11-04
  • Resampler settings update.
  • Removed decades old hack for MP3 radio without content-type - should work as before and get recognized by content checks.
  • Title formatting help updated again.
Сообщение #11 VEG » 05.11.2025, 20:46
2025-11-05
  • Fixed accidentally insane default resampler settings.
  • Windows: Added console output to troubleshoot specific portable mode bug.
Сообщение #12 VEG » 14.11.2025, 20:01
2025-11-07
  • Windows: Enabled reading of EXIF orientation info from album cover pictures.
  • Fixed a regression that prevented shortwindow AAC from being bounced to add-on decoder if available.
  • Fixed more accidentally insane resampler behaviors.
2025-11-14
  • Experimental Windows Imaging Component / Direct2D album art rendering in Default User Interface.
2025-11-15
  • Various fixes in new album art rendering routines.
Сообщение #13 VEG » 18.11.2025, 20:14
2025-11-18
  • Windows: Fixed crashing when a picture cannot be decoded for whatever reason.
  • Windows: Added Gdiplus fallback when Windows Imaging can't decode some image, so systems without Windows Imaging codecs can again show album art.
  • Mac: Implemented album art downscale-on-load, lowering memory usage of album art viewers etc (full size image is not loaded in contexts that will never show it).
Сообщение #14 VEG » 22.11.2025, 08:45
2025-11-21
  • Added advanced preferences toggle to turn off all subsong support. Use carefully, might have unwanted side effects or work partially.
Сообщение #15 VEG » 24.11.2025, 21:20
2025-11-24
  • Refined workaround for foo_tags (M-Tags) component bugs. No longer hammers all subsongs when starting playback.
  • Addressed properties dialog info reload glitch inflicted by disabling multi-subsong support.
  • Made M3U playlists referencing multi subsong files show all subsongs, restoring behavior of past foobar2000 versions.
  • Made entering blank incoming item sort pattern preserve original track order handed by app interacting with foobar2000, restoring behavior of old foobar2000 versions.
Сообщение #16 VEG » 01.12.2025, 21:59
2025-11-25
  • Fixed lockup regression with default-sorted autoplaylists when no default sort pattern is specified.
2025-12-01
  • Restored out-of-the-box APL link support.
  • Improved subsample offset behavior with retroarch resampler.
Сообщение #17 VEG » 02.12.2025, 21:15
2025-12-02
  • Fixed an issue with yesterday's changes in retroarch resampler that could cause glitches near the end of processed stream.
Сообщение #18 VEG » 04.12.2025, 08:52
2025-12-03
  • Quality/bugfix updates to both resamplers.
  • Converter: Made "no DSP reset" explicitly shown in overview, as it's dangerous if enabled unintentionally.
Сообщение #19 VEG » 09.12.2025, 20:51
2025-12-09
  • ARDFTSRC resampler fixed incorrect flush behavior on seek.
  • Retroarch resampler reduced sample offset.
Сообщение #20 VEG » 12.12.2025, 20:42
2025-12-12
  • Ported "Play on" feature from foobar2000 mobile - currently accessible from playlist context menu - internet radio stations and other http links can be sent directly to any UPnP renderer device.
  • Default User Interface: made cycling tabs by keyboard shortcuts cancel tab rename in progress.
  • Default User Interface: made playlist sort operations recognize %queue_index% and other playlist specific fields. This change is experimental and not currently available to add-on components. SDK update documenting how to do this will be made available shortly.
  • Fixed Skip Track vs Playback Statistics interaction regression, skipped tracks are no longer marked as played.
Вернуться в Новости плеера
