foobar2000 v2.25
Сообщение #1 VEG » 10.05.2025, 00:51
Вышел foobar2000 v2.25! Предыдущая версия: foobar2000 v2.24.
  • Built-in UPnP media renderer, both client (play to another device) and server (be controlled by another device).
    • Other foobar2000 instances on your local network, with UPnP remote control feature active, will be listed as output devices.
    • foobar2000-to-foobar2000 playback shows tags with album covers on the other end, using Ogg FLAC as stream container.
  • Media Library improvements, most notably:
    • Can natively index FTP/WebDAV/SMB network shares.
    • Improved response to enabling/disabling/installing/uninstalling decoders - only reloads info from affected music files.
  • Codecs, most notably:
    • FFmpeg updated to 8.0, added native support for xHE-AAC decoding.
    • Rewritten Ogg FLAC tag handling, properly implemented embedded album art.
    • Fixed ReplayGain tags not being saved in multichapter Ogg/Opus files.
  • Portable install improvements
    • Changed the way relative paths are handled, so cached tags are no longer forgotten after relaunching from a different path.
    • Made possible so specify no-cover pics as relative path to install location.
  • Converter:
    • Enabled RF64 writing.
    • Fixed Converter failing to function until foobar2000 restart after removal of %TEMP%\foo_converter.
  • Other
    • Added preferences page for network share credentials so you don't have to place them in URLs anymore.
    • Made editing DSP settings momentarily lower output latency to make DSPs appear more responsive.
    • Fixed Properties 'rewrite tags' not working if nothing has been edited.
    • Installer is now hi-DPI friendly.
    • Made system file dialogs invoked out-of-process, to avoid stability issues.
  • See release notes for full list of changes.
Автор темы, Администратор
С нами: 14 лет 3 месяца
Сообщение #2 VEG » 12.05.2025, 20:05
2025-05-12
  • Fixed unintended capture of ctrl+shift+left/right by tab containers.
  • Internet radio album art lookup regression fix.
  • Amended handling of dynamic info (live bitrate etc), the behavior in previous build was causing OpenMPT visualization to malfunction.
  • Monkey's Audio updated to 11.10.
Сообщение #3 VEG » 14.05.2025, 20:01
2025-05-14
  • Made live playback info manipulation match behaviors of old foobar2000 versions better, should fix Internet radio issues.
  • Windows: Removed dotted lines from various treeviews, refreshed Album List tree looks.
  • Windows: Fixed bad import of relative library paths when upgrading from portable install of old version.
  • Windows: More verbose output on "open containing folder" errors.
Сообщение #4 VEG » 19.05.2025, 21:01
2025-05-19
  • Mac: Fixed keyboard shortcuts page glitches.
  • Mac: Handle forward delete key in properties, playlist, etc.
  • Windows: Fixed "save all playlists" crash.
  • Windows: Various bug fixes in dark mode listview substitution code.
  • Windows: New VC runtime.
  • Windows: Made converter properly resolve redirected relative paths.
Сообщение #5 VEG » 20.05.2025, 21:32
2025-05-20
  • FFmpeg 7.1 updated to 7.1.1, fixed xHE-AAC bugs.
  • Windows: Fixed wrong default folder in Quick Convert in portable installs.
Сообщение #6 VEG » 22.05.2025, 20:17
2025-05-22
  • Fixed playing track info possibly becoming out of sync when using seekbar near track switch.
  • Windows: Fixed initial directory not being set correctly in folder picker regression.
Сообщение #7 VEG » 27.05.2025, 20:10
2025-05-27
  • FFmpeg updated to current git master, fixed more xHE-AAC decoding bugs.
  • Windows: Made internal cover art reading routines respect embedded color profiles.
  • Windows: Fixed failure to negotiate playback format on some exotic audio devices.
Сообщение #8 LUR » 31.05.2025, 10:32
2025-05-31
  • Made Media Library not touch files with .bak, .bk, .off extensions, in addition to .tmp and .temp which were already ignored before.
  • Fixed UPnP streaming crash.
  • Added an option to suppress detection of renamed files, overriding new v2.0+ behavior of recognizing common music formats with wrong extension.
  • Fixed startup crash if importing malformed foobar2000 v1.x configuration.
  • Windows: Made ARM reported correctly in crash report OS version field (was "x64" before).
  • Windows: Fixed "add files" not remembering last used folder.
  • Windows: New VC runtime again.
  • Mac: Slightly refreshed FFmpeg adapter settings page.
С нами: 13 лет 8 месяцев
Сообщение #9 VEG » 05.06.2025, 22:50
2025-06-05
  • Playback prebuffering logic update, should fix stuttering with high-res internet radio streams.
  • Windows: Slightly updated Album List search box, made delay setting take immediate effect; previous behavior required reopening Album List to take effect.
  • Re-enabled decoding of xHE-AAC thru alternate decoders, as FFmpeg decoder is still buggy. This means aac_at decoding on Mac OS.
  • Mac: Cleaned up external FFmpeg decoder preferences.
  • Media Library made properly keep track of enabled decoders list; made remember which decoder was used for each file, so only affected files will be reloaded after uninstalling or disabling of specific decoder.
  • Media Library added 'clean flag' to know if a rescan of specific folder actually completed; fixes upgrading from foobar2000 v1.x with no scan-on-startup folders becoming empty.
  • Mac: Properties dialog properly allows multi-line fields.
  • Windows: Properties dialog no longer garbles lyrics etc with Unix style line endings.
  • Mac: Album List preferences allows multi-line patterns.
Сообщение #10 VEG » 06.06.2025, 20:01
2025-06-06
  • Amended prebuffering code, no longer outputs very large chunks, which caused some DSPs to behave erratically.
  • Fixed regression from the last build causing very short music files not to be played.
  • Mac: Fixed erratic behavior of Properties dialog on multi line tags with Windows style line endings.
Сообщение #11 VEG » 14.06.2025, 07:21
2025-06-13
  • Fixed ID3 tags in AAC radio stream causing playback to stop.
  • Fixed "wrong URL format" error trying to list SMB server root folder without slash after hostname.
  • Windows: Improved screen reader behavior in Verify Integrity results dialog.
  • Made "Edit Chapters" show progress dialog when manipulating files, avoid unresponsive UI when rewriting large MP4.
  • Tweaked MP4 tag padding to rewrite large files less.
Сообщение #12 VEG » 17.06.2025, 13:21
2025-06-16
  • Fixed a bug that made exotic FLAC configurations unplayable if muxed into Ogg/Matroska/MP4.
  • Fixed failure to resume internet radio streams after specific patterns of connection issues.
  • Made Verifier detect multichapter files with FLAC-style audio MD5, now prompts to scan as whole.
  • Improved interaction between Verifier and built-in FFmpeg decoders; more errors get reported.
Сообщение #13 VEG » 18.06.2025, 20:14
2025-06-18
  • Enabled RF64 writing in Converter.
  • Amended WavPack in Matroska interaction with Verifier.
  • Added advanced preferences toggle for alternate multi-value MP4 tag storage - more compatible with specific apps but less compatible with others. Old versions of foobar2000 read both schemes.
Сообщение #14 VEG » 23.06.2025, 00:36
2025-06-22
  • Restored ability to list HTTP folders via "Add Location".
  • Fixed saved network credentials not being used for HTTP/WebDAV resources.
  • SMB bugs fixed.
Сообщение #15 VEG » 23.06.2025, 21:56
2025-06-23
  • Fixed a problem with yesterday's HTTP bug fix that broke adding whole local folders, by drag&drop etc.
Сообщение #16 VEG » 27.06.2025, 18:54
2025-06-27
  • Mac: Visualizations - fixed falling peaks for blank bars not being drawn.
  • Cleaned up various inconsistent behaviors of filesystem API, correct read-ahead option is once again used for SMB.
  • Reverted 2024 change breaking titles in local M3U playlists referencing internet radio M3U.
  • Fixed extreme memory usage of visualizations with specific file types.
  • Made title formatting date functions not throw C++ exceptions when fed input they can't process.
  • Improved handling of AAC radio streams that have both ID3 tags and icy metadata.
Сообщение #17 VEG » 06.07.2025, 20:13
2025-07-06
  • Fixed disappearing internet radio covers for specific Ogg streams.
Сообщение #18 VEG » 11.07.2025, 07:37
2025-07-10
  • Various HLS & radio dynamic info issues fixed.
  • Added 5s timeout to SMB network operations.
Сообщение #19 LUR » 26.07.2025, 03:33
2025-07-25
  • Fixed crash on malformed Ogg FLAC metadata.
  • Windows: Obscure dark mode bugs fixed.
2025-07-26
  • Windows: Dark mode main window title bar regression fixed.
Сообщение #20 VEG » 28.07.2025, 20:00
2025-07-28
  • Fixed a regression preventing optimal audio device bit depth from being detected, was always reported as 16-bit.
  • Prevented file-relative:// and mac-volume:// paths being saved in M3U playlists.
  • Less aggressive audio prebuffering.
