foobar2000 v2.26
Сообщение #1 VEG » 10.10.2025, 20:33
Вышел foobar2000 v2.26! Предыдущая версия: foobar2000 v2.25.
  • Converter changes
    • New preset format, presets stored as .ini files in profile subfolder. Old presets imported on first run.
    • Better error messages when receiving unexpected data format change in mid-conversion; made discard blank chunks before checking for format match.
    • Added extensible post-conversion actions which can be used for ReplayGain scanning, integrity testing, etc.
    • On conversion error, encoder's stderr output is forwarded to foobar2000 console.
    • Ogg chaining is now off by default, Ogg chapters written by default instead.
    • Added %source_list_index% & %source_list_total%, only for multi track image naming pattern use, to allow use of list indexes in the pattern.
    • Made file name preview recognize newly added %source_list_index%.
    • Made show output of command-line encoder program in error popup if conversion has failed.
    • Made "no DSP reset" explicitly shown in overview, as it's dangerous if enabled unintentionally.
  • ReplayGain Scanner changes
    • Added new interface for components to access ReplayGain scanning options.
    • Added option to write REPLAYGAIN_ALGORITHM tag.
    • Default mode is now more accurately named "ITU-R BS.1770".
  • Resampler technology updates
    • New resamplers: ARDFTSRC and Speex, replacing SSRC and libretro from previous versions. New resamplers provide better quality at comparable speeds / better speeds at comparable quality.
    • Cleaned up resampler settings, removed pointless "exclude rates" checkboxes, added explicit hints about formatting.
    • Made resampler priority setting accept short names of resamplers, e.g. "speex;ardftsrc".
  • Playback & file format handling changes
    • Added support for decoding TrueHD & MLP streams in Matroska.
    • New info field: container (MP4, Matroska, Ogg, etc).
    • Improved handling of Matroska Segment Title field.
    • Improved recovery of malformed UTF-8 text in various tag formats.
    • Made print name of file format handler used to console, after "opening track for playback".
    • More accurate on_playback_dynamic_info() timing, restored correct operation of OpenMPT visualizations.
    • Added advanced preferences toggle to turn off all subsong support, forcibly present 1 file as 1 playlist entry.
    • Faster opening of Matroska files.
    • Monkey's Audio format is now handled via FFmpeg.
  • MP4/M4A/M4B improvements
    • Tagtype info (Apple, Nero).
    • No longer writes Nero tags by default for single chapter files, only for multi chapter where other tagging formats can't store per track tags.
    • Added support for some rarely used Apple tag elements.
    • No longer alters binary structure of Apple tag elements which are not affected by edits.
    • More robust handling of unusual Apple tag fields.
  • General usability changes
    • New title formatting field: %_cpu_arch%.
    • Added drag&drop from Internet Radio pages to playlist.
    • Attempt to play a password-protected resource such as radio stream now shows a password prompt.
    • Equalizer now accepts presets via drag&drop from Explorer/Finder.
    • Added "Play on" feature from foobar2000 mobile - accessible from playlist & internet radio context menu .
    • Made playlist sort operations recognize %queue_index% and other playlist specific fields.
    • Added "Playback Information" section to View menu, meant for components.
    • Made "Verify with AccurateRip" command available if your tracknumbers don't strictly match most common numbering scheme.
    • Added Help / Search Query Syntax.
    • Smarter "remove duplicates" code, made aware of various scenarios where different perceived paths point to same file.
    • Restored LargeFieldsConfig feature - https://www.foobar2000.org/LargeFieldsConfig-v2.
    • Updated title formatting help with some recent and some not-really-recent additions.
    • File Operations: Made gracefully refuse to rename archive contents.
  • Networking
    • Improved reading of RAR archives on network shares.
    • Improved SMB read throughput over high-latency connections.
  • Windows specific changes
    • Advanced Preferences: Disabled Wine treeview workarounds if running Wine newer than 11.12.
    • Default User Interface: made render album art using Windows Imaging Component / Direct2D.
    • Enabled reading of EXIF orientation info from album cover pictures.
  • Libraries updated to newer versions: FFmpeg, Opus, zlib, RAR, 7-zip, SQLite.
VEG M Онлайн
Автор темы, Администратор
С нами: 14 лет 5 месяцев
Сообщение #61 LUR » 25.07.2026, 01:23
2026-07-23
  • Windows: Reverted & frozen UPnP output DLL to build 2026-06-18, as newer versions crash on Wine due to missing C++ runtime functions.
  • Fixed ARDFTSRC resampler integer overflow if fed extreme sample rates.
С нами: 13 лет 10 месяцев
Сообщение #62 LUR » 07.08.2026, 14:37
2026-08-05
  • Fixed certain malformed MP4/M4A/M4B files being presented with thousands of chapters.
  • Faster opening of MP4/M4A files on network shares.
  • Fixed missing AAC codec details on specific internet radio stream.
  • ARDFTSRC: Prevented insane mode being invoked programmatically
  • Windows: Updated SQLite to the latest version.
Сообщение #63 LUR » 29.08.2026, 12:21
2026-08-28
  • Fixed longtime Null Output bug causing playback position jitter when paused.
  • Worked around wrong MP3 sample rate shown with specific internet radio station due to server sending conflicting data.
  • Fixed "Verify with AccurateRip" command not showing if your tracknumbers don't strictly match most common numbering scheme.
  • Mac: Fixed Album Art Viewer in "fixed size" mode feeding downscaled image to full-size view on double click.
Сообщение #64 LUR » 13.09.2026, 23:48
2026-09-12
  • Added ui_element_subclass_playback_information section to View menu.
  • Added console notice why Properties doesn't autocomplete stuff if secret low memory mode is active.
  • Mac: Cleaned up 'add location' and 'choose playlist format' dialogs.
  • Increased accepted HTTP reply line length because some sites tripped the old limit in legitimate responses.
Сообщение #65 VEG » 14.09.2026, 20:18
2026-09-14
  • Fixed multiple bugs in smooth seeking implementation.
VEG M Онлайн
Сообщение #66 VEG » 16.09.2026, 23:03
2026-09-16
  • Improved compatibility with specific UPnP renderers.
  • UPnP output is built against static VS runtime because normal build crashes on Wine.
VEG M Онлайн
Сообщение #67 VEG » 18.09.2026, 23:00
2026-09-18
  • Refined on_playback_dynamic_info() timing fix again.
VEG M Онлайн
Сообщение #68 LUR » 20.09.2026, 03:26
2026-09-19
  • Improved compatibility with specific UPnP renderers again.
Сообщение #69 VEG » 22.09.2026, 20:51
2026-09-22
  • Fix for specific untaggable M4A file with trailing garbage.
  • Refined on_playback_dynamic_info() timing fix again. It's fixed properly now. I mean it.
  • Mac: Fixed jumpy seekbar on short tracks.
VEG M Онлайн
Сообщение #70 VEG » 23.09.2026, 08:17
Зачастил Peter с маленькими апдейтами. Кажется, дело ближется к финальной версии 2026 года :)
VEG M Онлайн
Сообщение #71 LUR » 24.09.2026, 07:33
VEG:Кажется, дело ближется к финальной версии 2026 года :)
Ну да, один чейнджлог SDK чего стоит.
Сообщение #72 LUR » 01.10.2026, 16:07
Вышел финальный релиз foobar2000 v2.26
2.26 released on 2026-10-01
  • Converter changes
  • Networking
Сообщение #73 VEG » 01.10.2026, 17:12
Дождались 😊
VEG M Онлайн
Сообщение #74 LUR » Сегодня, 15:23
2.26.1 preview 2026-10-08
  • Fixed a regression that prevented automatic crash report submissions from working.
  • Mitigated startup crash caused by specific buggy components.
