foobar2000 v0.9.5
Сообщение #1 Киря2 » 20.10.2007, 17:37
New Default User Interface
  • Allows embedding of Album List and other components in the main window
  • Quick setup dialog on first startup allowing easy UI customization
  • Theme import/export support for transferring appearance-related settings easily
  • Built-in playlist view supports columns and grouping
  • New Playlist Search dialog
  • Embedded album art support
  • New built-in spectrum visualisation
New Album List component
  • Updates automatically with Media Library content changes (“Refresh” command no longer needed)
  • Embeddable in the main window
  • Supports direct creation of autoplaylists from Album List tree branches
Properties dialog improvements
  • New commands: “Format from Other Fields”, “Capitalize”, “Clean Up”
  • Improved “Automatically Fill Values” functionality
  • Improved Windows Clipboard interaction - now you can use copy/paste to transfer values between fields or between different sets of tracks
Converter component improvements
  • Replaced “show output directory when done” functionality with a new dialog showing a list of created tracks
  • Built-in support for writing AU/SND and AIFF files
  • Updated FLAC support - FLAC encoding now requires FLAC encoder 1.2.0 or newer
  • Improved handling of hung command-line encoder processes
Audio format decoding updates
  • Updated libFLAC to 1.2.0
  • Rewritten support for AU/SND and AIFF audio formats
New “File Operations” component, for moving, copying and deleting audio files
Old Masstagger component no longer included with the installer (available for download separately)
Windows XP or newer is now required
[ скачать ]
:o
Киря2
Сообщение #2 mgz » 20.10.2007, 19:20
Ух, а ничего так версия. :)
С нами: 20 лет 5 месяцев
Сообщение #3 Киря2 » 20.10.2007, 21:07
бомба.. гидроген всколыхнулся :) С выходом нового SDK начнут переводить ui panels в ui elements
Киря2
Сообщение #4 Lite » 20.10.2007, 22:14
был приятно удивлен новой бетой
Lite M
Сообщение #5 mgz » 20.10.2007, 23:36
ДА-ДА-ДА !!!! Я уже этого жду :)
А то щас смотрю на новый UI - всё класс, но опять вернуться в эпоху Columns_UI как-то не хочеться. Но новый UI красавеЦЦ :)
Сообщение #6 Lite » 21.10.2007, 00:14
mgz:Но новый UI красавеЦЦ :)
это точно! *ок*
конструктор из ui elements - круто, правда хотелось бы добавлять свои колонки не только в плейлист
Lite M
Foobar2000 0.9.5 b3
Сообщение #7 deff » 21.10.2007, 16:57
foobar2000 0.9.5 beta 3 — скачать с файлового архива foobar2000.ru
Кто ещё не юзал советую! новый дефолт интерфейс вызывает восхищение, питер молодец!!!!
http://www.foobar2000.org/beta/index.html
сам дистрибутив стал в разы больше весить
Последний раз редактировалось Sp1ke 06.11.2007, 10:59, всего редактировалось 1 раз.
deff M
Сообщение #8 mgz » 21.10.2007, 17:28
2deff
Ну это ты преувеличил :) 2,7 против 1,6 (у 0.9.4.5)
Это да. Взято лучшее из прошлых вариаций интерфейсов и компонентов. В частности ОЧЕНЬ порадовала возможность залочить высоту и ширину плеера (по кнопке максимайз плеер просто смещается на 0,0, но ширина и высота не меняется) - этого мне очень не хватало. Также упростилась настройка сплиттеров/табов. Но можно по ошибке и порушить всё. Чтобы не испортить интерфейс появилась возможность "учиться" в специальном окне Скрейтбокс. Нехватает только гибкого кастомайза через TAGZ.
Сообщение #9 Sma11erM1nd » 21.10.2007, 22:04
А куда дели Title Formating?(
UPDATE:
Нашёл в релиз нотах:
The title formatting strings previously located on the Display > Title Formatting can now be found on the Advanced preferences page in the Display / Legacy title formatting settings branch. These strings are no longer used by the new Default User Interface.
Но пункта такого всё равно не нашёл)
Последний раз редактировалось Sma11erM1nd 21.10.2007, 22:25, всего редактировалось 1 раз.
Sma11erM1nd M
Сообщение #10 akuma » 22.10.2007, 08:31
интересно, цветовая схема "forum" очень напоминает мою сборку :)
а что за скрейтбокс и где его взять? не сказал бы, что настройка упростилась... скорее наоборот - добавилась игра "угадай где нужно нажать правую кнопку"
akuma M
Сообщение #11 akuma » 22.10.2007, 08:40
да, до columnsUI пока ещё как до луны...
akuma M
Сообщение #12 deff » 22.10.2007, 08:58
да, чувствуется что интерфейс совсем ещё сырой, хочу отметить что плейлист не полноценно поддерживает TAGZ, но ведь это ещё бета1 а до фулл я думаю ещё далеко. думаю со временем все изменится, интерфейс стал более расширяемый и панели к нему уже во всю пишутся :)
deff M
Сообщение #13 mgz » 22.10.2007, 09:03
2dark-demon
Прошу прощение за "очепятку" - скрейтчбокс (Scratchbox). Включить это счастье можно так: View / Layout / Create Scratchbox. Вот в новом окне уже можно экспериментировать. Чтобы скопировать вид плеера нужно сначала включить Layout Editing Mode. ну а далее игра в правую кнопку :) Главное словить главный сплиттер (тогда подсветиться весь плеер) и нажать Copy UI Element. В окне Scratchbox жмём Paste UI Element, далее начинаем "шаманить" :)
Удачи.
Последний раз редактировалось mgz 22.10.2007, 09:06, всего редактировалось 1 раз.
Сообщение #14 mgz » 22.10.2007, 09:06
2deff
Можно пример ? Правда, пока багов не видел. Хотя не копался особо :)
Сообщение #15 deff » 22.10.2007, 09:14
недостаток настроек ты сам подметил, я думаю в следущей версие будет много изменений.
ну про плейлист - он не знает %playback_time*%.
deff M
Сообщение #16 z0rr0 » 22.10.2007, 16:13
Колонка в плейлисте с кодом $if(%isplaying%,%playback_time%'/'%length%,%length%) не отображает проигранное время (хотя статус бар с таким же кодом пашет отлично).
z0rr0
Сообщение #17 Lite » 22.10.2007, 18:35
2Sma11erM1nd
Lite M
Сообщение #18 Turbid » 24.10.2007, 12:42
А у меня какие-то траблы с отрисовкой GUI - в панелях появляются пробелы с фоном из приложения, расположенного за окном фубара.
А так очень порадовали нововведения.
Turbid
Сообщение #19 Sma11erM1nd » 24.10.2007, 20:46
Turbid:А у меня какие-то траблы с отрисовкой GUI - в панелях появляются пробелы с фоном из приложения, расположенного за окном фубара.
Ну будем считать что это проблема бетки...
Sma11erM1nd M
Сообщение #20 meDveD » 28.10.2007, 13:09
при запуске фубара новой версии не появляется значка в трее с часами,
соответственно невозможность свернуть фубар в фоновый режим..
это так и должно быть пока, или у меня что то не так?
Последний раз редактировалось meDveD 28.10.2007, 13:11, всего редактировалось 1 раз.
