foobar2000 v1.0
Сообщение #1 evil » 20.11.2009, 21:04
foobar2000 v1.0
foobar2000 1.0 release notes
Download .torrent
foobar2000 change log - version 1.0:
  • New context menu structure - better out-of-the-box layout but less customizable.
  • Built-in support for Windows Media and RTSP streaming.
  • “Edit” menu operates on the currently selected object rather than always on the active playlist.
  • Improved compatibility with multimedia keyboards.
  • Improved, more customizable album art support.
  • Portable installs now remember Media Library paths relatively to the install folder.
  • Reworked Preferences: OK/Cancel/Apply buttons, new layout of standard pages.
  • New options regarding selection viewer behavior.
  • Default User Interface: new pseudo color code system for status bar and playlist view.
CD ripping improvements:
  • Results can be now checked against the AccurateRip database on-the-fly.
  • CD-TEXT reading support.
  • Ability to choose individual tracks to rip in the “Rip Audio CD” dialog.
Beta 6 list of changes:
Bug fixed: Inconsistent behaviors of the "Colors and Fonts" preferences page when importing themes or using the "Quick Appearance Setup" dialog.
Shoutcast stream titles are now parsed as UTF-8, allowing Unicode characters.
Improved compatibility with (unofficial?) FLAC multichannel specification.
Internal clean-ups and fixes.
Beta 5 list of changes:
Bug fixed: Importing themes while having Default User Interface preferences open causes inconsistent behaviors of the status bar formatting editbox.
Bug fixed: Some Windows Media streams stop playback on track change.
Bug fixed: ASX playlist parsing fails if the file contains XML comments.
Bug fixed: WMA cover art is not loaded from some files.
.WVX playlists (a variation of ASX) are now supported.
Beta 4 list of changes:
Bug fix: Having "full file buffering" feature enabled breaks Windows Media streaming over HTTP.
Bug fix: Incorrect sorting of the "Duration" column in Default UI.
Bug fix: Cannot convert to WAV+CUE.
Added support for ASX files referencing other ASX files.
Installer now forcefully removes very old components that can no longer be loaded. You will be prompted before anything gets deleted so you can back relevant files up.
Old behavior of the Converter's [...] button has been restored.
Added a hidden-by-default main menu command to access Playlist Search regardless of current focus.
Beta 3 list of changes:
* Bug: Certain ASX files fail to load when dragged from a webbrowser or added through "add location".
* Bug: Windows Media stream .WAX files can't be opened.
* Bug: Titles of certain Windows Media streams are not displayed.
Beta 2 list of changes:
New: Converter encodes to .m4a rather than to .mp4.
New: Notices for components that no longer serve any purpose.
Bug: Certain ASX playlist files are not parsed properly.
Bug: Unwanted playlist view scrolling when deleting items in certain scenarios.
Bug: cannot bind context menu commands to toolbar buttons.
Bug: "initialization failure" errors when making a clean non-portable install rather than upgrading from an earlier version.
Bug: possible unnecessary tag reloads on Media Library contents on startup.
Bug: doubleclicking the Selection Properties element no longer brings up the Properties dialog.
Beta 2a corrects the issue with foo_uie_biography being mis-detected as one of the obsolete components.
Beta 1 list of changes:
Последний раз редактировалось evil 10.01.2010, 00:25, всего редактировалось 1 раз.
С нами: 20 лет 4 месяца
Сообщение #2 Mr.Merak » 20.11.2009, 21:39
Вот это чисто стиль Пети - переписывать все плагины... ОПЯТЬ  *даун*
Mr.Merak M
Сообщение #3 evil » 20.11.2009, 21:49
Да, он только заметил, что с кнопками в настройках непорядок. Изображение
Ох, в контекстном меню теперь бардак: всё свалено в кучу в Legacy Commands.
ELPlaylist случаем не отвалился?
Последний раз редактировалось evil 20.11.2009, 21:54, всего редактировалось 1 раз.
Сообщение #4 Mr.Merak » 20.11.2009, 22:35
Кароче надо все с нуля перенастраивать... это ж теперь будет по 100 cfg-шников  *даун*
Mr.Merak M
Сообщение #5 evil » 20.11.2009, 22:52
2Mr.Merak
Да настройки-то автоматически перевелись в новый формат. Пока вижу только два неудобства: всплывающая подсказка в настройках и бардак в контекстном меню.
Но есть и плюсы: по моим ощущениям плеер стал шустрее шевелиться. :)
Сообщение #6 Fuu » 20.11.2009, 23:10
Кто-то тут недавно спрашивал, когда же будет новая версия :) 1.0 - это уже серьезно. Щас потестим...
Ух ты, появился автоскролл колесиком! И автомат битности (х/з, правда, для чего).
И какой-то непонятный "Tone/sweep sample rate" в Advanced > Decoding :o
Последний раз редактировалось Fuu 20.11.2009, 23:40, всего редактировалось 1 раз.
Fuu M
Сообщение #7 evil » 20.11.2009, 23:43
Fuu:появился автоскролл колесиком! И автомат битности
Это где и что?
Сообщение #8 Fuu » 20.11.2009, 23:59
Media library > Album List > Middle button action: [Autoscroll (default)] - зажимая среднюю кнопку мыши, можно прокручивать списки.
А про битность в Playback > Output сказано "output data format will be chosen automatically for the selected device".
Только у меня что-то 16bit для 24-битной звуковухи пишет. Или это не важно... Может из-за win7... У вас как?
Fuu M
Сообщение #9 DiJ » 21.11.2009, 00:04
Как его заставить читать куи ;)
DiJ
С нами: 18 лет
Сообщение #10 DiJ » 21.11.2009, 00:07
2Fuu
В АСИО у меня 32 ставится автоматом, звук X-Fi Extrime Music
DiJ
С нами: 18 лет
Сообщение #11 Fuu » 21.11.2009, 00:36
У меня и для ASIO пишет 16bit. А с WASAPI и KS автомат отключается и можно выбрать 24.
Fuu M
Сообщение #12 evil » 21.11.2009, 00:58
Fuu:Только у меня что-то 16bit для 24-битной звуковухи пишет. Или это не важно... Может из-за win7... У вас как?
У меня на DS и ASIO выбирает 24 бита, причём нельзя изменить. На других типах вывода выбор возможен.
Последний раз редактировалось evil 21.11.2009, 01:00, всего редактировалось 1 раз.
Сообщение #13 meDveD » 21.11.2009, 02:44
я не верю (в vlc я тоже не верил), подрыв устоев..
Последний раз редактировалось Sp1ke 21.11.2009, 02:48, всего редактировалось 1 раз.
Сообщение #14 Mr.Merak » 21.11.2009, 09:32
Fuu:Media library > Album List > Middle button action: [Autoscroll (default)] - зажимая среднюю кнопку мыши, можно прокручивать списки.
это и так было
Fuu:И какой-то непонятный "Tone/sweep sample rate" в Advanced > Decoding
а вот с этим нужно разобраться
DiJ:Как его заставить читать куи
мануал прочти про куи
evil:по моим ощущениям плеер стал шустрее шевелиться
есть такое дело
Mr.Merak M
Сообщение #15 Mr.Merak » 21.11.2009, 09:41
Петя, сволочь, убрал ссылку на Properties (вкладка Properties) и убрал фишку "не выделять файлы добавленные из Album List"
Mr.Merak M
Сообщение #16 Mr.Merak » 21.11.2009, 09:48
Some more changes:
  Added troubleshooter notice when foobar2000 wasn't correctly closed last time.
  Better error reporting for broken FLAC files.
  FLAC "native cuesheets" are removed as well when removing embedded cuesheets.
  Broken MP4 frames no longer abort decoding.
  Updated Vorbis cover art reading to the new spec.
  Converter rejects non-console executables for encoders (avoids common mistake of people using installer packages instead of the encoders themselves).
  Added MP3 gain target level configuration (advanced preferences).
  Added Ctrl+PageUp/PageDown accelerators for tab changes.
  Added bindable command which goes straight to the Output preferences page and selects the "Output device" dropdown for faster output switching e.g. using a shortcut.
  Added commands for changing DSP presets directly.
  Re-added v0.8 menu commands for direct change to a certain volume.
  Default UI splitters are thinner/less borders somewhere.
  More consistency in UI, "Vista" look everywhere.
  Album list: Removed [+] at root.
Mr.Merak M
Сообщение #17 evil » 21.11.2009, 10:40
meDveD:в vlc я тоже не верил
А чего с ним?
Сообщение #18 Jny » 21.11.2009, 10:44
2evil тоже не так давно на первую версию перешёл :)
Jny
С нами: 18 лет 3 месяца
Сообщение #19 G-Man » 21.11.2009, 12:54
Это частота дискретизации тестовых сигналов. Вроде File->Add location->tone://1000,10 (тон 1кГц длиной в 10 секунд)
Действительно не хватало
G-Man
Сообщение #20 MrGrey » 21.11.2009, 13:10
Configuration of individual components is now stored in separate files.
имхо, полезная вещь :)
