MilkDrop 2 Visualisation v0.9.10 [13.09.2026]
Сообщение #1 foobar2000.club » 02.02.2024, 22:00
foo_vis_milk2 is a port for foobar2000 of Winamp's MilkDrop 2 music visualizer. It additionally migrates rendering from its original DirectX 9 to DirectX 11.
MilkDrop 2 takes you flying through visualizations of the soundwaves you're hearing. It uses beat detection to trigger myriad psychedelic effects, creating a rich visual journey through sound.
Features
  • Uses DirectX 11 for rendering.
  • Uses updated libraries.
  • vis_milk2 has been upgraded to use more modern C++ alongside DirectX 11. Deprecated or insecure functions have been rewritten and most unused functionality removed.
  • Configurable through foobar2000 preferences instead of INI files.
  • Supports the Default User Interface (Default UI) only.
  • Tested on foobar2000 v2.1.2 (x86 32-bit and x86 64-bit) and Microsoft Windows 11 (Build 22621).
Страница плагина: http://foobar2000.org/components/view/foo_vis_milk2
foobar2000.club
Автор темы, Робот
С нами: 14 лет 3 месяца
Сообщение #2 foobar2000.club » 14.09.2026, 07:00
Вышла новая версия плагина: MilkDrop 2 Visualisation v0.9.10 [13.09.2026]
foobar2000.club
Автор темы, Робот
