Folder Open v1.0.2 [10.10.2026]
Сообщение #1 foobar2000.club » 10.10.2026, 00:00
Automatically populates the active playlist with the other playable files in the same folder when a single local audio file is opened, while keeping the originally selected track playing.
Designed primarily for opening music by double-clicking files in Windows Explorer.
Files are sorted using natural filename ordering, and metadata is loaded automatically. Supported file formats are determined by the input components installed in foobar2000.
Windows x64 only. No external helper application is required.
Страница плагина: http://foobar2000.org/components/view/foo_folderopen
foobar2000.club
Автор темы, Робот
С нами: 14 лет 4 месяца
