Инструменты пользователя
Инструменты сайта
foobar2000:plugins_for_0.9.x:bookmarks_foo_uie_bookmarks
Bookmarks (foo_uie_bookmarks)
Описание
Помогает запомнить позиции и громкость в песнях.
Возможности
  • Instant Save: bookmarks data file is written to immediately whenever a change in listview data takes place except when a column is clicked
  • context menu Save performs writing to bookmarks data file
  • Delete key removes items
  • Keyboard Shortcuts: Clear Bookmarks, Bookmark
  • Inline editable Comment column
  • Auto mode:
    • Bookmarks: activated bookmarks are automatically updated on stop, user starting another bookmark or nonbookmark, or shutdown; if playback reaches the end of the track, the bookmark is automatically deleted
    • Nonbookmarks: captures playing nonbookmarks on shutdown/user starting another for no/all/specified playlists; starting another capturing can be disabled for interplaylist/intraplaylist tracks; can capture a cache playlist that's been cleared
    • Queue: captures playback queue on shutdown, user stop, and user starting another
  • Field for global title formatting: %bookmarks_auto_mode%, the values are: auto bookmarks, auto nonbookmarks [sa|sd|cccp], auto queue; when queue is active w/either of the other modes, "& queue" is appended
  • Cache: captures entire playlist for a bookmark
Измнения
+ добавлено- - убрано ~ изменено ! исправлено
0.2.4.1
  • - redundant & unused code
  • ~ grayed out logic completed for auto bookmarking s.a. & cache prefs
  • ~ optimizations
  • ! if auto bookmarking s.a. was active and "Capture cleared…" pref was disabled, track was still captured for cleared cache playlist
0.2.4
  • + individual bookmark properties: Auto Mode, Volume, Prestart, Added On, Last Played On; default can be set in prefs
  • + columns: Flags, Prestart, Last Played On
  • + auto bookmarking (formerly auto nonbookmarks) pref "All playlists except"
  • + playlist selector for playlists prefs
  • ~ %bookmarks_auto_mode% changed to %bookmarks%, values also changed
  • ~ do not capture volume when bookmarking if playback is inactive
  • ~ cache playlists pref is now like those for auto bookmarking
  • ~ auto bookmarking sa mode now also applies to playlistless tracks
  • ~ prefs layout is now tabbed
  • ~ optimizations
  • ~ internal changes
  • ! visual glitches
0.0.2
  • ~ оптимизации
  • ~ улучшены описания некоторых настроек "Use this playlist:"
  • ! режим auto nonbookmarks не активировался, если букмарки были очищены при воспроизведении nonauto-букмарка
  • ! previous playing auto bookmark state was not cleared in some cases which prevented the current playing auto bookmark from updating (0.2.1)
Ссылки
foobar2000/plugins_for_0.9.x/bookmarks_foo_uie_bookmarks.txt · Последние изменения: 2007/05/10 03:33 (внешнее изменение)
