Инструменты пользователя
Инструменты сайта
foobar2000:plugins_for_0.9.x:command_playlist_foo_cmd_playlist
Command Playlist (foo_cmd_playlist)
Описание
Добавляет в поддержку командной строки foobar2000 новый ключ /playlist-activate:”Name”. Данный ключ активирует плейлист с названием “Name”.
command line arguments:
  • /playlist-find:"name" activate playlist "name", create if necessary
  • /playlist-new:"new pls" create and activate playlist "new pls"
  • /playlist-activate:"name" activate playlist "name"
  • /playlist-activate#N activate playlist in position N
  • /playlist-activate#playing activate playlist currently playing
  • /playlist-rename:"new name" rename active playlist to "new name"
  • /playlist-move:N set active playlist's list position to N
  • /playlist-move#N move active playlist's list position by N
The index number N may have a sign, a negative index is interpreted as right-/bottom-offset. Thus the top list position is 0, the last position is -1. Double quotes around names are only required if the name contains spaces.
Сcылки
foobar2000/plugins_for_0.9.x/command_playlist_foo_cmd_playlist.txt · Последние изменения: 2007/03/22 04:05 — Spike
