foobar2000:plugins_for_0.9.x:playlist_dropdown_foo_uie_playlists_dropdown
Playlist Dropdown (foo_uie_playlists_dropdown)
Описание
Показывает плейлист в виде выпадающего меню.
Возможности
Различные иконки для нормального / заблокированного / активного / воспроизводимого плейлиста (также, иконки можно отключить).
Настраиваемая сортировка.
Настраиваемые заголовки плейлистов.
Настраиваемый шрифт.
Настраиваемый шрифт и фоновые цвета.
Простое контекстное меню.
The list can display various information about playlists (through formatting strings):
%title% Name of the playlist.
%lock% Present if the playlist is locked (returns name of the lock, for example Autoplaylist or Read-only).
%size% Number of items (songs) the playlist contains.
%length% Playlist's length (duration), formatted as [HH:]MM:SS.
%filesize% Total filesize of the playlist (in bytes → use e.g. $div(%filesize%,1048576) to retrieve size in
MB).
%isplaying% Present if the playlist is currently being played (to be used as a switch for $if()).
%isactive% Present if the playlist is active (to be used as a switch for $if()).
%index% Index of the playlist.
%total% Total number of playlists.
%id% Original index of the playlist (when the list is sorted).
Скриншоты
Изменения
20060528 (v0.5.7)
Added Load…, Save as… and Save all as… to context-menu.
Added middle-click action: Activate now playing playlist
Added simple separator lines
Removed Set max height option
Fixed bad filesize on CUEs
20060521 (v0.5.6)
Fixed mouse-wheel support
Added %filesize% field
Improved preferences page
Configurable action for Middle click
(Hopefully) got rid of 'metadb_handle leaks' that occasionally occured (was that really me?…)
20060519 (v0.5.5)
Added custom-sorting
Added customizable colors
Added top/right/bottom/left padding
Added Rename and Preferences… context-menu items
Added %length% field
Keyboard commands: F2 (Rename), DEL (Remove)
Various bug-fixes
20060517 (v0.5)
Дополнительно
Ссылки
foobar2000/plugins_for_0.9.x/playlist_dropdown_foo_uie_playlists_dropdown.txt · Последние изменения: 2007/03/12 09:44 (внешнее изменение)
