Инструменты пользователя
Инструменты сайта
foobar2000:plugins_for_1.x:official_plugins
Официальный список плагинов
Список плагинов, которые объявлены как стабильно работающие автором плеера Foobar2000 Peter-ом Pawlowski
http://www.foobar2000.org/components
Обновлен 07.10.2012
Название плагина ТегиПоследнее обновлениеОписание
7-Zip archive support 1.8archive2011-08-14Adds support for reading files from 7-Zip archives (.7z)….
ABX Comparator 1.3.4 2009-04-25Performs a double-blind listening test between two tracks.
AC3 decoder v0.9.7 decoder 30.08.2012 Adds decoding support for ATSC A-52 bitstream files (.AC3). Also includes a packet decoder for Matroska …
ADPCM decoders 1.10 decoder, game music2011-12-15 Adds decoding support for over a dozen ADPCM formats, including CRI ADX, Game Cube ADP and DSP variants …
AdPlug decoder v1.41decoder 24.09.2012Adds decoding support for all Adlib FM chip formats supported by the AdPlug library. …
Album list panel 0.3.5 Columns UI panel, media library viewer2009-06-14 A Columns UI panel version of album list. Allows you to browse your music library in a hierarchical structure.
ASIO support 2.1.2 output 2012-06-06 Provides ASIO output support. …
Audio CD Writer 3.0.3audio cd 2011-02-24 Allows you to burn audio CDs from any of supported audio formats, through context menu commands. …
Audioscrobbler 1.4.7playback statistics 2010-06-04 foo_audioscrobbler is a Last.fm/Audioscrobbler component for foobar2000 1.0 …
Autosave & Autobackup 10backup, configuration 2010-09-23Allows periodic automatic saving of configuration and other data in foobar2000 and keeping backup copies …
AviSynth decoder 0.4decoder2012-02-19 Adds decoding support for AviSynth scripts (.AVS), audio only. Requires AviSynth 2.5 or newer. …
Binary Comparator 1.2diagnostic 2008-12-05 Performs binary comparison between two or more tracks and reports differences.
Chacon 3repair, tagging 2010-04-07 Chacon is a simple tool for fixing tags by converting them between different character sets. …
Columns UI 0.3.8.8user interface 2011-02-27 An alternative user interface. …
Console panel 0.4Columns UI panel, diagnostic 2009-08-29 A Columns UI panel version of console. Displays diagnostic messages.
Decoding Speed Test 1.1diagnostic 2008-12-31 Measures decoding speed of audio files.
Discogs Tagger 1.30album art, discogs, tagging 2011-08-12 A tagger using the Discogs (http://www.discogs.com) database …
Dolby Headphone Wrapper 1.4.1DSP, headphones2010-01-22 Dolby Headphone technology gives you the sound of a 5.1 surround system through any pair of headphones. …
DSDIFF Decoder 1.4decoder2011-05-19 Adds decoding support for DSDIFF files (.DFF). …
DTS decoder 0.3.0decoder2010-09-03 Adds decoding support for DTS Coherent Acoustics files (.DTS) and DTS WAV files (.DTSWAV). Also includes …
DUMB Module decoder v0.9.9.64decoder 20.09.2012 Adds decoding support for several sequenced music formats: MOD/MDZ, S3M/S3Z, STM/STZ, IT/ITZ, XM/XMZ …
Effect DSP 0.11DSP, reverb 2012-06-25 A collection of special effects: …
Equalizer split 0.0.1DSP2008-07-12 A meta-DSP that feeds each channel into a separate equalizer instance.
Facets 1.0Default UI element, media library viewer, search2011-08-18 Media library viewer with linked lists, multiple columns, album art, statistics, and search functions. …
Feature Watcher 1.0.7diagnostic 12-02-16 Watches available features and reports changes.
File Integrity Verifier 1.1diagnostic 2009-10-05 Checks specified media files for decoding errors. Note that with most formats, its accuracy is limited …
Foobar2000 Advanced Controls 0.6.7.4notifications, playback control, user interface 11-11-18 Control all the playback functions of Foobar2000 from icons on the Taskbar …
FooSnarl 1.0 2011-01-15 A Snarl notification extension. On playtime events (Play, Pause, Stop) FooSnarl sends your user defined …
Game Emu Player v1.152decoder, game music 05.10.2012 Adds decoding support for several game console music formats: AY, GBS, GYM, HES, KSS, NSF, SAP, SGC, …
Graphic Equalizer 0.3.7DSP 2012-02-05 A graphic equalizer featuring …
HDCD Decoder v1.15decoder 18.07.2012 This postprocessing service component will decode HDCD data in any 16-bit PCM stream passed through it …
Hively Tracker decoder 1.9decoder 2012-02-19 Adds decoding support for Hively Tracker files (.HVL) as well as Abyss' Highest eXperience files (.AHX). …
Impulse Response Convolver 0.3DSP 2006-08-04 Allows arbitrary effects to be captured and used inside foobar2000.
Infospect 1.0.3Default UI element, diagnostic 2008-02-01 Displays low level playback information.
iPod manager 0.6.9.7Columns UI panel, portable devices2011-06-28 iPod management component compatible with most Apple iPod and iPhone models. …
KDM Decoder 1.1decoder 2012-02-19 Decodes Ken Silverman's Digital Music format files. (.KDM) …
Keep Queue 0.3.5playback control, queue 2010-11-12 Prevents the playback queue from being removed when changing song manually, and saves the queue when …
Kernel Streaming support 1.2.2output 2006-08-04 Allows bit-exact playback bypassing Windows kernel mixer. Activated through playback / output preferences …
LHA archive support v1.12archive 22.09.2012 Adds support for reading from LHA and LZH archives.
Live Show Tagger 0.7.1tagging 2010-05-15 Tags files from eTree/furthur style text files describing live shows. …
Logitech LCD Display & Visualization 0.5.5display, visualization 2010-11-17 A component to display visualisations and track information on a variety of Logitech LCD screens (check …
Lyric Show Panel 3 0.3.5.2Columns UI panel, Default UI element, lyrics 2012-06-15 A UI element which can download and display both timestamped and text only lyrics. Compatible with both …
Masstagger 1.8.4tagging 2009-09-18 Automates various tag editing operations. …
MIDI decoder v1.174decoder 28.09.2012 Adds decoding support for General MIDI files (.MID) and RIFF MIDI files (.RMI) as well as several proprietary …
Monkey's Audio Decoder 2.1.6decoder 2012-06-04 Adds decoding support for Monkey's Audio files (.APE) as well as APE Link files (.APL). …
MusicBrainz Tagger v0.3MusicBrainz, tagging 24.07.2012 Allows tagging files using data from MusicBrainz. …
On-Screen Display 1.70display 2012-04-14 Adds support for an event triggered On-Screen Display overlay. This is the legacy GDI version, which …
On-Screen Display GDI+ 1.70display 2012-04-14 Adds support for an event triggered On-Screen Display overlay. …
Organya decoder 1.9decoder, game music 2012-02-19 Decodes Organya (.ORG) files. …
Pause On Lock 0.5playback control 2010-01-11 Adds the menu command "Pause On Lock" which will automatically pause playback when the desktop is locked …
Playback Statistics 3.0.2playback statistics 2011-07-13 This component collects and maintains statistics for played songs. …
Playback Statistics SQL 1.4.3.0playback statistics 2009-06-28 The plugin tracks unique combinations of artist/album/title items into a SqlServerCe local database.
Playlist Attributes v0.5.1playlist 25.08.2012 foo_playlist_attributes is a foobar2000 component for assigning various attributes to a playlist. …
Playlist History 0.1.6display, playlist management 2011-05-04 foo_playlisthistory enables playlist history in foobar2000, similar to page history in browsers. …
Playlist Organizer 2.4Columns UI panel, Default UI element, playlist management 2011-05-05 foo_plorg is a simple component that will let your organize your playlists in a treeview fashion. It …
Playlists Dropdown 0.7.6Columns UI panel, playlist management 2009-09-23 This component displays the playlists in a dropdown list. Titles of the playlists are configurable and …
Podcatcher 0.2.5Default UI element, podcast 2011-03-12 A podcatcher component for subscribing to, downloading, and playing RSS and Atom podcast feeds in foobar2000. …
Popup Panels 0.1.4Columns UI panel host 2012-01-10 This component allows displaying ColumnsUI panels in a popup window. …
Post-track silence 0.0.3DSP 2009-08-10 Inserts a configurable amount of silence after each track to help external devices like MiniDisc players …
Programmable reverb DSP 1.2DSP 2010-06-30 This is a programmable reverb effect, based on the hardware algorithm of the Sony PlayStation game console. …
PSF decoder v2.0.27decoder, game music 16.08.2012 Adds decoding support for Sony Playstation Sound Format files (.PSF/.MINIPSF) as well as Playstation …
QSF decoder 2.0.20decoder, game music 2012-02-19 Adds decoding support for Capcom QSound Sound Format files (.QSF/.MINIQSF). …
Queue Contents Editor 0.5.1Columns UI panel, Default UI element, queue 2012-03-11 foo_queuecontents enables the user to edit and view queue contents through an ui element. Both the Default …
Quick Search Toolbar 3.2Columns UI panel, Default UI element, Media Library Viewer, search 2011-05-29 Basic search toolbar that will send results of the search to a playlist of your choice. Includes various …
Quick Tagger 1.0.3tagging 2010-09-01 Adds customizable context menu commands for quickly setting tag fields to preconfigured values (for rating …
R128Norm 1.11DSP 2011-12-19 Implements a simple normalizer DSP based on gated ITU-R BS.1770 Loudness calculation. …
RAM-Disk 1.0
Random Pools 0.1.3random 2012-06-09 foo_random_pools is a foobar2000 component for creating random playlist entries selected and grouped …
Replaygain Override 0.1.3playback control 2010-01-14 Provides a way to specify which replaygain modes to use for each playback order. Track gain is probably …
Run Command 1.1 2010-01-07 Finds and executes menu commands. …
Run Services 0.3.7 2009-06-07 foo_run runs external applications from within foobar2000 0.9.x
Scheduler 4.10automation, scheduler 2012-07-03 Adds support for scheduling actions like play, stop, system shutdown/wake up etc.
Seekbox 0.0.3playback control 2010-04-21 Main menu item that pops up a box for seeking to a particular hh:mm:ss time in the current track.
Shell Link Resolver 1.3.1 2010-01-07 Adds support for shell links (.lnk files). …
Shorten Decoder 0.4.2.2decoder 2009-11-15 Adds support for decoding Shorten files and tagging them through external APEv2 tags.
Shpeck 0.3.7Columns UI panel, Default UI element, emulator, visualization, Winamp 2009-09-28 Shpeck runs Winamp visualisation plugins in a stand-alone window, a Columns UI panel or Default UI element. …
SID decoder 1.26decoder, game music 2012-02-19 Adds decoding support for Commodore 64 SID sound files (.SID, .MUS). Based on resid-fp. …
SimPlaylist 1.0Default UI element, playlist view, search 2011-08-18 Playlist view with multiple grouping levels, album art, smooth scrolling, automatic column resizing, …
SimPlaylist Manager 1.0Default UI element, playlist management 2011-08-18 Playlist manager with playback status icons, smooth scrolling, and additional statistics. …
Skip Track 1.7.4bookmark, skip 2011-07-02 Allows you to skip tracks that match a specified search query. By default the component will skip all …
Skype playing notifications 0.2notifications, Skype 2011-05-21 Sends now playing track info to Skype profile mood. …
Soft Playlists 2011-02-05playlist management 2011-02-05 Can create different Last.fm related playlists: …
SQL Tree 1.0.4Columns UI panel, media library viewer, search 2012-06-03 foo_uie_sql_tree is a foobar2000 component for viewing the media library in a tree structure using SQL …
SSF/DSF Decoder 2.0.30decoder, game music 2012-08-26 fAdds decoding support for Sega Dreamcast Sound Format (.DSF/.MINIDSF) files and Sega Saturn Sound Format …
TagBox 0.212tagging 2011-03-11 Tag editing UI element and standalone window.
Tagger Panel v1.2.10Columns UI panel, tagging 09.09.2012 foo_uie_tagger_mod is a foobar2000 component for quick tagging defined metadata fields. It can be used …
TAK Decoder v0.4.5decoder 26.09.2012 Adds support for decoding and tagging TAK files as well as reading embedded album art. …
Text Display 1.1 beta 1Default UI element 2011-05-29 UI Element for the Default User Interface v0.9.5 and newer. Displays information about the playing or …
Text Tools 1.0.5clipboard 2010-09-01 Adds customizable context menu commands for copying information about the selected tracks to Windows …
TFMX decoder 0.9decoder 2012-02-19 Decodes TFMX files (MDAT., TFMX., .MDAT, .TFM, .TFMX, .TFX). …
Timebomb 0.0.2playback control 2009-12-20 Menu item to terminate or stop playback after a configurable period of time.
Typefind panel 0.2 beta 2Columns UI panel, search 2007-10-22 Provides a Columns UI search bar to search the active playlist.
Unix archive support 1.8archive 2011-08-14 Adds support for reading from Unix Tape Archives (.TAR), gzip files (.GZ), and bzip2 files (.BZ2). …
UPnP/DLNA Renderer, Server, Control Point 0.99.40Columns UI panel, Default UI element, media library viewer, remote control, remote library, streaming 2012-05-10 UPnP/DLNA Renderer, Media Server, Control Point …
UPSE PSF Decoder v1.6game music 16.08.2012 This is a new PlayStation Sound Format (.PSF/.MINIPSF) decoder component based on William Pitcock's Unix …
USF Decoder 2.1decoder, game music 2011-06-26 This is a decoder which adds support for playing (Ultra) Nintendo 64 Sound format (.USF/.MINIUSF) files.
vgmstream decoder r1000decoder, game music 05.09.2012 This component decodes dozens of streamed ADPCM or other compressed format files extracted from various …
Vorbis Streamer 1.1DSP, network, streaming, Vorbis 2009-11-18 Streams Vorbis and associated metadata to Icecast2 and Shoutcast servers.
WASAPI output support v3.0output 02.09.2012 Adds Windows Audio Session API exclusive mode output support, allowing bit-exact output and muting all …
Waveform Seekbar v0.2.27Columns UI panel, Default UI element17.07.2012 A user interface element providing a seekbar that displays the waveform of the playing song, compatible …
YM Decoder 0.3decoder, game music 2011-03-19 Plays YM files (.YM).
Все перечисленные компоненты совместимы с foobar2000 1.1 и выше.
foobar2000/plugins_for_1.x/official_plugins.txt · Последние изменения: 2013/01/31 22:07 — Izotop
