Частная конфигурация CepiPerez’s Dark config v1.1
Сообщение #1 Sp1ke » 28.03.2007, 06:46
Времени на перевод пока нет.
Version 1.1:
  • Languages English and Spanish availables
  • Possibility to select between ulimited backgrounds
  • New player buttons
  • Use Artist picture as background
  • Use small artist image / small album cover
  • Show/hide big album cover
  • Button to get lyrics using lyricsDB
  • Link to Artist website
  • Rating buttons
  • Artist images
  • Album covers
Components needed:
Download my images from here
Download my PUI file from here
Installation:
Copy the PUI file in PanelsUI folder (C:\Program files\foobar2000\PanelsUI)
Unzip images in your foobar install folder (C:\Program files\foobar2000). Be sure you get this folder: C:\Program files\foobar2000\dark1. If you get C:\Program files\foobar2000\dark1\dark1 or C:\Program files\foobar2000\images\dark1 folder then the skin won’t work.
After install:
- Go to Preferences (Ctrl+P) -> Media Library. Delete my folders and add yours.
- Go to Preferences (Ctrl+P) -> Tools -> Playcount and add this to appended information: %W %D/%M/%y
How to use the artist website link button:
It works when you have a metadata called “WWW” in the mp3 tags.
Go to Preferences -> Run services and add a new one labeled “web”, in Path put “iexplore.exe %WWW%”.
How to use backgrounds:
Just put your backgrounds images in %foobarInstall%\Dark1\walls folder.
Rename the image using correlative numbers (1.jpg, 2.jpg, 3.jpg, etc.)
How to use artists images:
Artist images must be in %foobarInstall%\Artists folder or in the mp3 folder in JPG format
The name of the image must be the same of the artist (Metallica.jpg)
How to use album covers:
Album covers can be in %foobarInstall%\Covers folder (Artist - Album.jpg) or in the mp3 folder (folder.jpg)
Enjoy it.
Sp1ke M
Автор темы, Основатель
Сообщение #2 sergiyakov » 22.04.2007, 21:33
Вот эти ссылки не работают
Пишет:
Not Found
The requested URL /dark1/1.1/Dark1.pui was not found on this server.
sergiyakov M
Сообщение #3 Rialto » 23.04.2007, 09:00
sergiyakov:Вот эти ссылки не работают
Пишет:
Not Found
Блин, ну что гуглом пользоваться не умеешь что ли ?
За 30 секунд находится эта тема на гидре.
Держи:
http://www.hydrogenaudio.org/forums/index.php?showtopic=53703
Rialto
Сообщение #4 litr konyaka » 23.05.2007, 11:41
Судя по скринам это то, что мне нужно )) но вчера пробовал качать с гидры, часть ссылок уже не работает, хотя пост вроде не такой уж древний. Кроме того я только думаю перейти на foobar и не уверен что смогу собрать все правильно. Есть где-то инструкции по сборке таких конфигов? И можно ли выложить эту сборку в полноценном виде? Ну, "скачал и вперед" )) Буду очень признателен, и, думаю, не один я )
litr konyaka
Сообщение #5 Rialto » 23.05.2007, 18:17
litr konyaka:Судя по скринам это то, что мне нужно )) но вчера пробовал качать с гидры, часть ссылок уже не работает, хотя пост вроде не такой уж древний. Кроме того я только думаю перейти на foobar и не уверен что смогу собрать все правильно. Есть где-то инструкции по сборке таких конфигов? И можно ли выложить эту сборку в полноценном виде? Ну, "скачал и вперед" )) Буду очень признателен, и, думаю, не один я )
Только что сходил по ссылке на гидру.
Всё качается отлично.
Rialto
Сообщение #6 litr konyaka » 23.05.2007, 18:49
Ну, возможно тогда это зависит от времени суток )) там все в разных местах выложено. Я не первый день в интернете )
Жалко только что это ответ на самый малоинтересующий вопрос ) Короче, не видать мне foobar как своих ушей ((
И на том спасибо.
litr konyaka
Сообщение #7 elektroniki » 17.06.2007, 11:26
товарищи, обьясните пожалуйста что и как делать чтобы были видны обложки альбомов в Cepiperez's Dark.
в файле точно забита абложка и вдругих плеерах видна.
буду признателен.
Последний раз редактировалось Sp1ke 17.06.2007, 21:56, всего редактировалось 1 раз.
elektroniki
Сообщение #8 Skaarj » 10.08.2007, 21:06
Шикарная просто сборочка я в восторге.
Господа можно вас попросить кто на hydrogenaudio.org зарегистрерован, попросите у Cepi кириллицу с отражениями, пускай выложит отдельно. :)  а может кто ещё и русский язык добавит  в меню :)
Вот только библиотека по рейтингу или году не раскрывается, надеюсь поправит.
и ещё может кто спросит, может реально сделать плееру прозрачный фон :) мне кажется так шикарно бы смотрелось на чистом рабочем столе :)
elektroniki так вроде фубар не понимает обложки из тегов, приходится все внешние использовать, по крайней мере я такого компонента незнаю.
Последний раз редактировалось Skaarj 10.08.2007, 21:09, всего редактировалось 1 раз.
Skaarj
Сообщение #9 burin » 12.08.2007, 18:41
можно как-то попдробней написать чего как настроить чтобы было как у автора, теже images - где пути прописывать?
burin
Сообщение #10 Lite » 12.08.2007, 22:36
2burin
сходи на гидроген (ссылка приводилась выше), там написано как настраивать конфиг
Lite M
Сообщение #11 burin » 13.08.2007, 17:13
2Lite
был я там, там:
Copy the Settings, Help and PUI files in PanelsUI folder (C:\Program files\foobar2000\PanelsUI)
Unzip images in your foobar install folder (C:\Program files\foobar2000). Be sure you get this folder: C:\Program files\foobar2000\dark1. If you get C:\Program files\foobar2000\dark1\dark1 or C:\Program files\foobar2000\images\dark1 folder then the skin won't work. You must to set the images folder if you want to use your own images location).
After install:
- Go to Preferences (Ctrl+P) -> Display -> Panels UI and press "Reset Page" button
Enjoy it.
все скопирова и распаковал картиники в C:\Program Files\foobar2000\images\dark1\
при старте выбрал то что надо и сбросил все настройки страницы, но где прописывать картинки так и не понял и вид у фубара не такой как на скринах автора, у меня все белое и названия песен в ряд через полосочку, need help *sorry*
burin
Сообщение #12 Lite » 13.08.2007, 17:45
2burin
читай внимательнее:
Lite M
Сообщение #13 burin » 13.08.2007, 18:43
2Lite
распаковал изобр. в папку C:\Program Files\foobar2000\dark1\
все равно ничего не поменялось %)
burin
Сообщение #14 Lite » 13.08.2007, 20:49
Lite M
Сообщение #15 burin » 14.08.2007, 15:52
2Lite
спасибо за то что выложил
сразу несколько вопросов
1) в сборке компонент больше чем требует автор (м.б. из-за отсутствия этих компонент у меня не работало?, хотя то что просил автор поставил+весь комплект из установки фубара)
2) анлийская версия запускается, но при попытки что-то проиграть просто закрывается
3) сверху накатываю русскую версию - при попытке что-то проиграть - секунд через 5 вылезают ошибки c++ (куча окошек) и фубар закрывается (vcredist_x86_sp1.exe - сразу установил)
burin
Сообщение #16 burin » 14.08.2007, 16:56
2Lite
все отпадывало из-за foo_uie_wsh_panel, его удалил все работает :) (кроме него конечно, правда зачем он нужен в этой сборке незнаю)
еще хотел спрсить, если надо изменить шрифт в плейлисте или добавить (убрать) колонки, то где копать
зы просто чего то PanelsUI для меня маленько запутанный какой-то, с ui_columns вроде попроще был, хотя здесь видимо и возможностей побольше
Последний раз редактировалось burin 14.08.2007, 17:28, всего редактировалось 1 раз.
burin
Сообщение #17 Lite » 16.08.2007, 21:30
burin:еще хотел спрсить, если надо изменить шрифт в плейлисте
Ctrl+P->Panels UI->Edit Layout
Lite M
Сообщение #18 pois22ple » 17.08.2007, 19:20
Господа!
Последнюю версию CepiPerez’s Dark config v.1.5c автор убрал со своего сайта, о чем сообщил на гидрогене. Причина - автор плагина foo_ui_panels.dll terrestial из-за критики в его адрес со стороны разработчиков foobar200 скорее всего прекратил дальнейшую разработку и поддержку этого плагина.
Просьба, если кто-нибудь успел скачать Dark config v.1.5c, поделитесь ею пожалуйста, ну очень нужна!
pois22ple
Сообщение #19 mgz » 17.08.2007, 19:26
Ох, плохая новость. :(
Отличный и почти не заменимый компонент...
Сообщение #20 Lite » 17.08.2007, 19:53
Separate UI forum ребят с гидрогена видимо поддушивало, что топики форума занимали темы панелек terrestial, но а критика местами справедлива, лучше исправлять старые баги, чем вводить новые фичи с выходом новой версии компонента. а так конечно жаль, если terrestial прекратит разработку плагина, много народу стали переходить на фубар, увидев скриншоты с Panels UI, можно посмотреть на топик рассела  :)
Lite M
Вернуться в Частные конфигурации
