foobar2000 v0.9.6
Сообщение #1 meDveD » 19.10.2008, 23:17
foobar2000 v0.9.6 beta 1
Change Log
# Media Library now automatically keeps track of any changes made to its folders; no more need to manually rescan them.
#Improved compatibility of file type associations with Windows Vista.
# No more delay when playing/enqueuing files from Windows Explorer.
# The installer now includes “portable mode” that works in limited user contexts and doesn't make any changes to system configuration, registry, etc.
# New Converter user interface.
# Built-in Matroska support.
Release Notes:
New installer options
Foobar2000 can now be installed in two modes: standard and portable.
Standard mode
Standard mode is similar to the “install for all users” option in older versions. You need administrative privileges to install foobar2000 in this mode.
Portable mode
Installing in portable mode only extracts the installer content and creates additional files that tell foobar2000 to store any configuration data in its installation folder as well as not to alter the Windows registry. Note that it is not possible to edit file type associations with foobar2000 when using portable mode, as that would require changes in the registry.
Media Library behavior changes
Folder watching
Unlike all previous versions, the Media Library now automatically tracks changes made to the content of your Media Library folders. It is no longer necessary or even possible to manually remove dead items or refresh the content of the Media Library.
Wine incompatibility
At the time this article is being written, the foobar2000 0.9.6 Media Library does not work correctly in Wine because of bugs/limitations in Wine itself. Changes in the Media Library folders may not be noticed by foobar2000 until it is restarted.
Hidden and system files
The Media Library now respects hidden and system flags; files or folders with those flags will be ignored. This can be used to selectively hide cuesheets or files referenced by cuesheets.
Limited compatibility with outdated components on Windows Vista
To permanently address the “bad allocation” bug present in very old versions of the foobar2000 SDK (released before 2006-07-30), foobar2000 now refuses to load components built with affected SDK versions when running on Windows Vista. Affected components can be fixed by just recompiling them with an updated version of the foobar2000 SDK.
Cuesheets in added folders ignored by default
In recent years it has become a popular trend to include cuesheet files with albums in various music trading communities. Such files introduced behaviors confusing to new foobar2000 users: each track of the album was listed twice. To address this issue, cuesheets are now ignored by default when adding entire folders as well as in the Media Library. You can change this in Preferences ⇒ General and Preferences ⇒ Media Library.
http://foobar2000.org/beta/index.html
http://www.foobar2000.ru/2008/10/20/foobar2000-096-beta-1/
Скачать с нашего сервера (2.84 мегабайта)
Список изменений
Последний раз редактировалось Sp1ke 20.10.2008, 13:35, всего редактировалось 1 раз.
Сообщение #2 Elixer » 20.10.2008, 00:10
А новый конвертер теперь не удаляет прегап первого трека при конвертировании *класс*
Elixer
Сообщение #3 meDveD » 20.10.2008, 13:36
текущие версии данных плагинов больше не совместимы с foobar2000 0.9.6
(под Windows XP часть компонентов работает, на Windows Vista уже нет)
Failed to load DLL: foo_dsp_crossfeed.dll
Failed to load DLL: foo_version.dll
Failed to load DLL: foo_uie_trackinfo.dll (обновился)
Failed to load DLL: foo_infobox.dll
Failed to load DLL: foo_discogs.dll (обновился)
Failed to load DLL: foo_xm.dll (обновился)
Failed to load DLL: foo_uie_console.dll (?заработал?)
Failed to load DLL: foo_navigator.dll (?заработал?)
Failed to load DLL: foo_winamp_spam.dll
Failed to load DLL: foo_dsp_centercut.dll
Failed to load DLL: foo_bubble_coverflow.dll
Failed to load DLL: foo_dsp_bs2b.dll
Failed to load DLL: foo_skip.dll
Failed to load DLL: foo_uie_queuemanager.dll
Failed to load DLL: foo_edcast.dll
Failed to load DLL: foo_dsp_delta.dll (обновился)
Failed to load DLL: foo_amipwrapper.dll (обновился)
Failed to load DLL: foo_lnk.dll
Failed to load DLL: foo_packet_decoder_ac3.dll
Failed to load DLL: foo_random.dll
Failed to load DLL: foo_packet_decoder_wavpack.dll
Failed to load DLL: foo_vis_channelusage.dll
Failed to load DLL: foo_g15lcd.dll (обновился)
Failed to load DLL: foo_input_tta.dll (обновился)
Failed to load DLL: foo_dsp_xover.dll (обновился)
Failed to load DLL: foo_dsp_ssrc.dll
и наверняка что-то ещё..
Последний раз редактировалось Sp1ke 14.12.2008, 13:30, всего редактировалось 1 раз.
Сообщение #4 Sp1ke » 20.10.2008, 13:52
о как… Опять апи грохнул
Sp1ke M
Основатель
Сообщение #5 meDveD » 20.10.2008, 14:30
Merak
не, не рулят ни разу)
это список моих проблем + с гидрогена (там повторялись большинство),
+ я написал и "наверняка что-то ещё.."
Последний раз редактировалось meDveD 20.10.2008, 14:43, всего редактировалось 1 раз.
Сообщение #6 evil » 20.10.2008, 17:24
Обновления ради обновлений.
Сообщение #7 stalk:er » 22.10.2008, 09:17
Блин как достал этот Афтар
stalk:er M
Сообщение #8 66Sick » 23.10.2008, 17:47
Folder watching - крайне неудачная фича.
Со временем убъёт винт в хлам  :-(
66Sick M
С нами: 18 лет 6 месяцев
Сообщение #9 evil » 23.10.2008, 19:14
266Sick
Чего делает?
Сообщение #10 mgz » 23.10.2008, 19:19
266Sick
Это значит ваш комп не работает в сети 24/7 торрент клиентом и не раздаёт более 100 раздач лосслесса и двд. И скорее всего не даёт доступ к шаре в DC++ :)
Всё познаётся в сравнении. Мне, например, эта функция не кажется криминальной - наоборот, удобной.
Сообщение #11 AltTab » 24.10.2008, 09:13
Ох, опять эти сборочно-критические дни... :) Пока устаканят плагины, есть шанс на то, что полюблю все-таки foobar в дефолте :)
AltTab M
Сообщение #12 stalk:er » 24.10.2008, 09:20
2AltTab
"Не вешать нос...."
stalk:er M
Сообщение #13 Sp1ke » 24.10.2008, 10:02
2AltTab
Есть такое мнение, что именно для этого и делается.
Sp1ke M
Основатель
Сообщение #14 Mishail » 24.10.2008, 11:18
Я уже полюбил
Сообщение #15 mgz » 24.10.2008, 12:20
Не так-то и страшен чёрт... это я за дефолтный плеер.
Я уже полгода на нём сижу.
Сообщение #16 66Sick » 26.10.2008, 14:30
mgz:266Sick
Не знаю как вам, но мне не очень нравится когда фубар начинает запускаться только через минуту-две после нажатия на ярлык, а до этого времени шуршит по венику как сумашедший + к этому невозможно скопировать музыку из одной папки в другую, т.к. фубар постоянно обращается то к одной папке, то к другой :((
В будущем, надеюсь, появится хотя бы выбор((
66Sick M
Сообщение #17 mgz » 26.10.2008, 17:12
266Sick
Не знаю, что у вас там происходит, но у меня запускается почти моментально.
В скане библиотеки указана одна папка с музыкой, занимает более 90 Гб (правда у меня не треково, а образами OGG).
Ну а выбор конечно должен быть.
foobar2000 v0.9.6 beta 2
Сообщение #18 meDveD » 26.10.2008, 23:44
Последний раз редактировалось meDveD 27.10.2008, 10:27, всего редактировалось 1 раз.
Сообщение #19 meDveD » 27.10.2008, 10:28
собственно я никаких изменений не заметил по сравнению с beta 1...
будем ждать релиза
Сообщение #20 meDveD » 27.10.2008, 11:35
при нажатии на файл из проводника теперь он становится в очередь
был пункт в настройке по этому поводу, и по умолчанию стояла галочка
куда делся непонятно..
Последний раз редактировалось meDveD 27.10.2008, 11:37, всего редактировалось 1 раз.
Вернуться в Новости плеера
