Foobar2000 v0.9.6.2 beta 1 has been released.
 This is a maintenance update, mainly introducing fixes and user interface tweaks.
не нашел такой функции.Nothing:отключение автосканирования папок случаем не добавили?
Media Library is now aware of newly installed decoder components and will re-check your folders for files that could not be indexed before.
New options to control tag fields searched by simple search queries, in Advanced Preferences.
Various bug fixes and cosmetic changes.
Новая опция, поиск тэгов по простым запросам (в Preference -> Advanced -> Tools)
Различные исправления и косметические изменения.
* Media Library is now aware of newly installed decoder components and will re-check your folders for files that could not be indexed before.
* New options to control tag fields searched by simple search queries, in Advanced Preferences.
* Improvements to startup/shutdown time with ML on slow storages (e.g. network disk over WLAN).
* Fixed $time() bug.
* Fixed IME in autocomplete edit fields.
* New style of Advanced Preferences.
черт, возвращаюсь обратно на 0.9.5.6Mr.Merak:2Nothing
и не добавят, имхо.
Nothing:черт, возвращаюсь обратно на 0.9.5.6
