перенос foobar2000.cfg на другой комп
Сообщение #1 greed » 27.02.2009, 09:53
приветствую.
пожскажите, в чем может заключаться проблема с переносом файлика на другую машину? плеер вешается при подмене.
воспроизведение стоит DS, библиотеку удалял и файлы с индексом не перезаписывал.
может есть какой-то редактор cfg-файлов?
Active components (36):
Core.dll v0.9.6.3 [] - foobar2000 core
foo_ac3.dll v0.9.1 [02 June 2008] - AC3 decoder
foo_albumlist.dll v4.3 [24 February 2009] - Album List
foo_audioscrobbler.dll v1.3.16 [09 March 2008] - Audioscrobbler
foo_cdda.dll v2.1.4 [24 February 2009] - CD Audio Decoder
foo_converter.dll v1.2 [24 February 2009] - Converter
foo_cuefilter.dll v0.1.5 [27 January 2009] - CUE playlist filter
foo_dirwatch.dll v0.2 beta 3 [09 December 2007] - Directory watcher
foo_dsp_crossfader.dll v0.3.4 (Intel SSE) [01 July 2008] - Gapless Crossfader
foo_dsp_delta.dll v0.1.1 [21 March 2006] - LPCM delta-PCM converter
foo_dsp_ssrc.dll v0.57 [16 August 2006] - Resampler DSP (SSRC)
foo_dsp_std.dll v1.0 [24 February 2009] - Standard DSP Array
foo_exvar.dll v0.3.1 [14 June 2008] - Extended Variables
foo_fileops.dll v2.1.1 [24 February 2009] - File Operations
foo_freedb2.dll v0.6 [07 June 2008] - freedb Tagger
foo_input_monkey.dll v2.1.3 [31 May 2008] - Monkey's Audio Decoder
foo_input_std.dll v1.0 [24 February 2009] - Standard Input Array
foo_managedWrapper.dll v0.5 [01 August 2008] - foo_managedWrapper
foo_out_asio.dll v1.2.6 [09 February 2008] - ASIO support
foo_out_ks.dll v1.2.2 [04 August 2006] - Kernel Streaming Output
foo_prettypop.dll v1.2.4 [02 December 2008] - Pretty Popup
foo_random.dll v1.2.3 [04 May 2007] - Randomized Playlist Entry
foo_rgscan.dll v2.0.8 [24 February 2009] - ReplayGain Scanner
foo_run.dll v0.3.2 [04 May 2007] - Run services
foo_snap.dll v0.1 [27 October 2006] - Main window snapping
foo_ui_columns.dll v0.3.6.4 [27 December 2008] - Columns UI
foo_ui_std.dll v0.9.5 [24 February 2009] - Default User Interface
foo_uie_albumart.dll v0.2.7.1 [16 December 2007] - Album Art Panel
foo_uie_albumlist.dll v0.3.3 [08 November 2008] - Album list panel
foo_uie_explorer.dll v1.04.7b [11 November 2008] - Explorer Tree
foo_uie_lyrics.dll v0.3.3.9 [Dec 12 2008 - 17:39:01] [12 December 2008] - Lyric Show Panel
foo_uie_panel_splitter.dll v0.3.6.2(alpha) [08 November 2008] - Panel Stack Splitter
foo_uie_trackinfo.dll v0.8 [03 May 2006] - Track info panel
foo_utils.dll v0.6.2 beta 6 [09 February 2008] - Playlist Tools
foo_version.dll v0.3 [04 May 2007] - Components versions viewer
foo_whatsnew.dll v1.0.6 [30 August 2008] - Feature Watcher
greed M
Сообщение #2 evil » 27.02.2009, 10:39
В cfg файле находятся настройки как плеера, так и плагинов. Попробуйте перенести всю папку плеера.
Сообщение #3 greed » 27.02.2009, 10:43
в том то и засада. что копировал все, в том числе плагины, иконки и пр... кроме файлов в папке playlists, database.dat, database.fpl
greed M
Сообщение #4 evil » 27.02.2009, 11:15
greed:плеер вешается при подмене
В какой именно момент подвешивается? Сразу же при первом запуске, начале проигрывания, другое?
greed:воспроизведение стоит DS
DS: Primary Sound? Дополнительно отключите все DSP.
Если зависания продолжатся, то попробуйте исключать по одному доп. плагины. Начать можно с
foo_dsp_ssrc.dll
foo_snap.dll
foo_dirwatch.dll
foo_exvar.dll
foo_uie_lyrics.dll
foo_dsp_delta.dll
Подумалось - у разных компов процессоры и операционные системы одинаковы?
Последний раз редактировалось evil 27.02.2009, 11:25, всего редактировалось 1 раз.
Сообщение #5 greed » 27.02.2009, 11:31
процы подозреваю, что разные - ноут и домашний PC. операционки одинаковые XP_Prof_32.
greed M
Сообщение #6 evil » 27.02.2009, 11:56
Это было к тому, что некоторые из плагинов могут быть заточены под одну архитектуру, например: foo_dsp_crossfader.dll v0.3.4 (Intel SSE) [01 July 2008] - Gapless Crossfader, а процессор AMD.
Сообщение #7 B_VV2 » 27.02.2009, 13:23
А может на одном компе стоит NET Framework, а на другом нет
попробуй удали плагин:
greed:foo_managedWrapper.dll v0.5 [01 August 2008] - foo_managedWrapper
и как вариант, глянь что стоит в качестве вывода звука: output device
B_VV2 M
Сообщение #8 greed » 27.02.2009, 13:34
2evil
неее... процы оба интелловские
2B_VV2
на обоих фреймворк 3.5
вывод в DS установлен, на получателе более продвинутая карта - меняю на asio
greed M
Сообщение #9 evil » 27.02.2009, 14:00
greed:меняю на asio
Не договаривать - нехорошо. ;)
Желательно ответить на вопросы.
Сообщение #10 greed » 27.02.2009, 14:08
2evil
все честно =)
DS поддерживается по_умолчанию всеми картами. он у меня и стоит в настройках источника, потом вручную менял на компе получателе.
раньше так работало. но воды с тех пор утекло много, и видимо, какие-то плагины/настройки теперь так просто перенести не дают.
т.е. до настроек даже не добраться. плеер стартует - обновляет базу (так как ядро апдейтится в 9.6.3) и вешается.
greed M
Сообщение #11 greed » 27.02.2009, 14:10
попробую, конечно, на получателе медленно и печально отрубать один плагин за другим. скорей всего, проблемный так удастся локализовать
greed M
Сообщение #12 greed » 28.02.2009, 22:43
похоже, дело в foo_uie_panel_splitter.dll
но пока не знаю, как побороть. без плагина стартует нормально, на вопрос удалить ли настройки, если удален плагин, отвечаю утвердительно. получаю возможность кое-что поменять в настройках.
после этого вырубаю плеер, кидаю foo_uie_panel_splitter.dll назад в папку компонент - при старте плеер висит
greed M
Сообщение #13 evil » 28.02.2009, 23:00
2greed
На вопрос надо отвечать "Нет".
Вернуться в Общая информация
