Скриншоты:
Ссылки:
/// DarkOne v2.1 Additional Buttons Panel
// Code by T.P Wang and tedGo
// @import "%fb2k_path%themes\DarkOne\Others\WSH Scripts\DO Global Script.js"
// @import "%fb2k_path%themes\DarkOne\Others\WSH Scripts\DO Global Button Script.js"
window.MinWidth = window.MaxWidth = 268;
// ----- CREATE BUTTONS ---------------------------------------------
var imgPath = fb.foobarPath + "themes\\DarkOne\\Buttons\\Control\\";
var btn_font = gdi.Font("tahoma", 12, 0);
Buttons.a = new Button(00, 12, 60, 14, {normal: imgPath + "AddOnAlone.png", hover: imgPath + "AddOnAloneMH.png"}, function(){fb.RunContextCommand("Службы/Last.fm Artist Info");});
Buttons.b = new Button(80, 12, 60, 14, {normal: imgPath + "AddOnAlone.png", hover: imgPath + "AddOnAloneMH.png"}, function(){fb.RunContextCommand("Службы/Google Artist");});
Buttons.c = new Button(160, 12, 60, 14, {normal: imgPath + "AddOnAlone.png", hover: imgPath + "AddOnAloneMH.png"}, function(){fb.RunContextCommand("Службы/Google Artist + title");});
Buttons.d = new Button(240, 12, 60, 14, {normal: imgPath + "AddOnAlone.png", hover: imgPath + "AddOnAloneMH.png"},  function(){fb.RunContextCommand("Службы/CoverFetcher");});
Buttons.e = new Button(320, 12, 60, 14, {normal: imgPath + "AddOnAlone.png", hover: imgPath + "AddOnAloneMH.png"},  function(){fb.RunContextCommand("Службы/Discogs");});
// ----- DRAW -------------------------------------------------------
   if (!window.IsTransparent) {
    gr.FillSolidRect(0, 0, window.Width, window.Height, ui_backcol);
    gr.FillGradRect(0, 0, window.Width, 90, 90, RGBA(151, 180, 202, 28), 0);
buttonsDraw(gr);
   gr.GdiDrawText("Last.fm Art.", btn_font, ui_btntxtcol, 00, 0, 70, 12, 33);
   gr.GdiDrawText("Google Art. ", btn_font, ui_btntxtcol, 84, 0, 60, 12, 32);
   gr.GdiDrawText("GArt.+title", btn_font, ui_btntxtcol, 154, 0, 60, 12, 34);
   gr.GdiDrawText("Rezerv", btn_font, ui_btntxtcol, 240, 0, 60, 12, 34);
   gr.GdiDrawText("Discogs", btn_font, ui_btntxtcol, 320, 0, 60, 12, 34);
// Maxim Terpilovsky's script
// http://terpilovsky.ru
// Buttonbar Panel / Updated 28-08-2011
MF_SEPARATOR = 0x00000800;
MF_ENABLED = 0x00000000;
MF_GRAYED = 0x00000001;
MF_DISABLED = 0x00000002;
MF_UNCHECKED = 0x00000000;
MF_CHECKED = 0x00000008;
MF_STRING = 0x00000000;
function RGB(r, g, b) {
// Config variables
// Variables
var my_ini_values = new Array;
var default_values = {"AAD_path" : "c:\\Program Files\\AlbumArtDownloaderXUI\\AlbumArt.exe"};
   var g_font = gdi.Font("Segoe UI", 12);
   var g_font2 = gdi.Font("Segoe UI", 10);
   var g_font = gdi.Font("Tahoma", 11);
   var g_font2 = gdi.Font("Tahoma", 9);
var mode;
var g_move = null;
var show_buttons;
var Active_array = [];
var Sup_Buttons = [{name:"Last.fm"}, {name:"Google"}, {name:"Discogs"}, {name:"Allmusic"}, {name:"Selection"}, {name:"Others"}];
var g_button_down = null;
tooltip.SetMaxWidth( 200 );
// Script functions
mode = parseInt( utils.ReadINI( fb.FoobarPath + 's7e.ini', 'buttonbar-settings', 'buttonbar_mode', 1) );
// Metadb
OutputMetadb = function() {
    if ( mode == 2 ) return ( fb.GetFocusItem(true) ? fb.GetFocusItem(true) : false );
    else return ( fb.IsPlaying ? fb.GetNowPlaying() : ( fb.GetFocusItem(true) ? fb.GetFocusItem(true) : false ));
function my_ini_write(text) {
   var fso, f, r, write = text;
   var ForWriting = 2;
   fso = new ActiveXObject("Scripting.FileSystemObject");
   var filename = fb.FoobarPath + "s7e.data";
   try {
      f = fso.OpenTextFile(filename, ForWriting, true)
      f.Write(write);
      f.Close();
   } catch(e) {
      fb.trace(e.message);
function object2string(obj) {
    var val, output = "";
    if (obj) {
        for (var i in obj) {
            val = obj[i];
            switch (typeof val) {
                case ("string"):
                    output += i + "=" + val + "\r";
                default:
        output = output.substring(0, output.length-1);
    return output;
function my_ini_read() {
   var fso, f, r, b;
   var ForReading = 1, ForWriting = 2;
   if ( fso.FileExists(filename) ) {
      f = fso.OpenTextFile(filename, ForReading);
      r =  f.ReadAll();
      var a = r.split("\n");
      for (key in a) {
         b = a[key].split("=");
         my_ini_values[b[0]] = b[1];
      return my_ini_values;
   else return false;
if ( !my_ini_read() ) my_ini_write(object2string(default_values));
buttons = {
//   reset: new Button( "..", "All", function() { show_buttons = null; update(); window.Repaint(); })
   lastfm_song: new Button( "Song", Sup_Buttons[0].name, function() { if ( OutputMetadb() ) WshShell.run("http://last.fm/music/" + encodeURIComponent(encodeURIComponent( fb.TitleFormat("%artist%").EvalWithMetadb(OutputMetadb()) ).replace(/%20/g,'+')) + "/_/" + encodeURIComponent(encodeURIComponent( fb.TitleFormat("%title%").EvalWithMetadb(OutputMetadb()) ).replace(/%20/g,'+') )); }),
   lastfm_album: new Button( "Album", Sup_Buttons[0].name, function() { if ( OutputMetadb() ) WshShell.run("http://last.fm/music/" + encodeURIComponent(encodeURIComponent( fb.TitleFormat("%artist%").EvalWithMetadb(OutputMetadb()) ).replace(/%20/g,'+')) + "/" + encodeURIComponent(encodeURIComponent( fb.TitleFormat("%album%").EvalWithMetadb(OutputMetadb()) ).replace(/%20/g,'+') )); }),
   lastfm_artist: new Button( "Artist", Sup_Buttons[0].name, function() { if ( OutputMetadb() ) WshShell.run("http://last.fm/music/" + encodeURIComponent(encodeURIComponent( fb.TitleFormat("%artist%").EvalWithMetadb(OutputMetadb()) )).replace(/%20/g,'+') ); }),
   lastfm_group: new Button( "Group", Sup_Buttons[0].name, function() { if ( OutputMetadb() ) WshShell.run("http://www.last.fm/community/groups/search?q=" + encodeURIComponent( fb.TitleFormat("%artist%").EvalWithMetadb(OutputMetadb()) ).replace(/%20/g,'+')); }),
   lastfm_images: new Button( "Images", Sup_Buttons[0].name, function() { if ( OutputMetadb() ) WshShell.run("http://last.fm/music/" + encodeURIComponent(encodeURIComponent( fb.TitleFormat("%artist%").EvalWithMetadb(OutputMetadb()) ).replace(/%20/g,'+')) + "/+images" ); }),
   lastfm_events: new Button( "Events", Sup_Buttons[0].name, function() { if ( OutputMetadb() ) WshShell.run("http://www.last.fm/events/search?q=" + encodeURIComponent( fb.TitleFormat("%artist%").EvalWithMetadb(OutputMetadb()) ).replace(/%20/g,'+') ); }),
   lastfm_search: new Button( "Search by Artist", Sup_Buttons[0].name, function() { if ( OutputMetadb() ) WshShell.run("http://www.last.fm/search?q=" + encodeURIComponent( fb.TitleFormat("%artist%").EvalWithMetadb(OutputMetadb()) ).replace(/%20/g,'+') + "&type=all" ); }),
   google_artist: new Button( "Artist", Sup_Buttons[1].name, function() { if ( OutputMetadb() ) WshShell.run("http://www.google.com/search?q=" + encodeURIComponent( fb.TitleFormat("%artist%").EvalWithMetadb(OutputMetadb()) ).replace(/%20/g,'+') + "&ie=utf-8"); }),
   google_album: new Button( "Album", Sup_Buttons[1].name, function() { if ( OutputMetadb() ) WshShell.run("http://www.google.com/search?q=" + encodeURIComponent( fb.TitleFormat("%artist% %album%").EvalWithMetadb(OutputMetadb()) ).replace(/%20/g,'+') + "&ie=utf-8"); }),
   google_title: new Button( "Song", Sup_Buttons[1].name, function() { if ( OutputMetadb() ) WshShell.run("http://www.google.com/search?q=" + encodeURIComponent( fb.TitleFormat("%artist% %title%").EvalWithMetadb(OutputMetadb()) ).replace(/%20/g,'+') + "&ie=utf-8"); }),
    discogs_artist: new Button( "Artist", Sup_Buttons[2].name, function() { if ( OutputMetadb() ) WshShell.run("http://www.discogs.com/search?q=" + encodeURIComponent( fb.TitleFormat("%artist%").EvalWithMetadb(OutputMetadb()) ).replace(/%20/g,'+') + "&type=artists&btn=Search"); }),
   discogs_album: new Button( "Album", Sup_Buttons[2].name, function() { if ( OutputMetadb() ) WshShell.run("http://www.discogs.com/search?q=" + encodeURIComponent( fb.TitleFormat("%album%").EvalWithMetadb(OutputMetadb()) ).replace(/%20/g,'+') + "&type=releases&btn=Search"); }),
   discogs_all: new Button( "Artist - Album", Sup_Buttons[2].name, function() { if ( OutputMetadb() ) WshShell.run("http://www.discogs.com/search?q=" + encodeURIComponent( fb.TitleFormat("%artist% %album%").EvalWithMetadb(OutputMetadb()) ).replace(/%20/g,'+') + "&type=all&btn=Search"); }),
   allmusic_artist: new Button( "Artist", Sup_Buttons[3].name, function() { if ( OutputMetadb() ) WshShell.run("http://www.allmusic.com/search/artist/" + encodeURIComponent( fb.TitleFormat("$ascii(%artist%)").EvalWithMetadb(OutputMetadb()) )); }),
   allmusic_album: new Button( "Album", Sup_Buttons[3].name, function() { if ( OutputMetadb() ) WshShell.run("http://www.allmusic.com/search/album/" + encodeURIComponent( fb.TitleFormat("$ascii(%album%)").EvalWithMetadb(OutputMetadb()) )); }),
   allmusic_title: new Button( "Song", Sup_Buttons[3].name, function() { if ( OutputMetadb() ) WshShell.run("http://www.allmusic.com/search/song/" + encodeURIComponent( fb.TitleFormat("$ascii(%title%)").EvalWithMetadb(OutputMetadb()) )); }),
    undo: new Button( "Назад", Sup_Buttons[4].name, function() { fb.RunMainMenuCommand("Edit/Undo"); }),
   redo: new Button( "Вперед", Sup_Buttons[4].name, function() { fb.RunMainMenuCommand("Edit/Redo"); }),
   sort_by_3d: new Button( "Сортировка", Sup_Buttons[4].name, function() { fb.RunMainMenuCommand("Edit/Selection/Sort/Sort by..."); }),
   sort_by_fields: new Button( "Sort by fields", Sup_Buttons[4].name, function() { fb.RunMainMenuCommand("Edit/Selection/Sort/Sort by fields..."); }),
   select_all: new Button( "Выбрать всё", Sup_Buttons[4].name, function() { fb.RunMainMenuCommand("Edit/Select All"); }),
   copy_to: new Button( "Копировать в...", Sup_Buttons[4].name, function() { fb.RunContextCommand("File operations/Copy to..."); }),
   reverse_selection: new Button( "Reverse", Sup_Buttons[4].name, function() { fb.RunMainMenuCommand("Edit/Selection/Sort/Reverse"); }),
   remove_selection: new Button( "Remove", Sup_Buttons[4].name, function() { fb.RunMainMenuCommand("Edit/Selection/Remove"); }),
   copy_to: new Button( "Копировать в...", Sup_Buttons[4].name, function() { fb.RunContextCommand("File operations/Copy to"); }),
    wiki_artist: new Button( "Wikipedia Artist", Sup_Buttons[5].name, function() { if ( OutputMetadb() ) WshShell.run("http://en.wikipedia.org/wiki/Special:Search?search=" + encodeURIComponent(fb.TitleFormat("$replace(%artist%, ,_)").EvalWithMetadb(OutputMetadb()))); }),
   mb_artist: new Button( "MusicBrainz Artist", Sup_Buttons[5].name, function() { if ( OutputMetadb() ) WshShell.run("http://musicbrainz.org/search?query=" + encodeURIComponent(fb.TitleFormat("%artist%").EvalWithMetadb(OutputMetadb())) + "&type=artist"); }),
   //aad_album: new Button( "Album Art", Sup_Buttons[5].name, function() { WshShell.run('"c:\\Program Files\\AlbumArtDownloaderXUI\\AlbumArt.exe" /ar "' + fb.TitleFormat("%album artist%").Eval(true) + '" /al "' + fb.TitleFormat("%album%").Eval(true) + '" /path "' + fb.TitleFormat("$replace(%path%,%filename_ext%,)folder.jpg").Eval(true) + '"'); }),
   reset: new Button( "..", "All", function() { show_buttons = null; buttons_num = null; update(); window.Repaint(); })
if ( fso.FileExists( my_ini_values["AAD_path"] ) ) {
   buttons.aad_album = new Button( "Album Art", Sup_Buttons[5].name, function() { if ( fb.GetFocusItem() ) WshShell.run('"' + my_ini_values["AAD_path"] + '" /ar "' + fb.TitleFormat("%album artist%").EvalWithMetadb(fb.GetFocusItem()) + '" /al "' + fb.TitleFormat("%album%").EvalWithMetadb(fb.GetFocusItem()) + '" /path "' + fb.TitleFormat("$replace(%path%,%filename_ext%,)folder.jpg").EvalWithMetadb(fb.GetFocusItem()) + '"'); });
else if ( fso.FileExists( default_values.AAD_path ) ) {
   buttons.aad_album = new Button( "Album Art", Sup_Buttons[5].name, function() { if ( fb.GetFocusItem() ) WshShell.run('"' + default_values.AAD_path + '" /ar "' + fb.TitleFormat("%album artist%").EvalWithMetadb(fb.GetFocusItem()) + '" /al "' + fb.TitleFormat("%album%").EvalWithMetadb(fb.GetFocusItem()) + '" /path "' + fb.TitleFormat("$replace(%path%,%filename_ext%,)folder.jpg").EvalWithMetadb(fb.GetFocusItem()) + '"'); });
var MyButtons = new Array(
   buttons.reset,
   buttons.lastfm_song,
   buttons.lastfm_album,
   buttons.lastfm_artist,
   buttons.lastfm_group,
   buttons.lastfm_events,
   buttons.lastfm_images,
   buttons.lastfm_search,
   buttons.google_artist,
   buttons.google_album,
   buttons.google_title,
   buttons.discogs_artist,
   buttons.discogs_album,
   buttons.discogs_all,
   buttons.allmusic_artist,
   buttons.allmusic_album,
   buttons.allmusic_title,
   buttons.undo,
   buttons.redo,
   buttons.sort_by_3d,
   buttons.sort_by_fields,
   buttons.select_all,
   buttons.random_selection,
   buttons.coy_to,
   buttons.reverse_selection,
   buttons.remove_selection,
   buttons.mb_artist,
   buttons.wiki_artist,
   buttons.aad_album
var buttons_num = MyButtons.length;
function Button(name, sup, func) {
   this.name = name;
   this.sup = sup;
   this.func = func;
   this.onClick = function () {
      this.func && this.func();
function update() {
   if ( show_buttons ) {
      Active_array = [];
      for (var i in MyButtons ) {
         if ( show_buttons != MyButtons[i].sup && MyButtons[i].sup != "All" ) continue;
         else {
            Active_array.push(MyButtons[i]);
   else Active_array = Sup_Buttons;
update();
function on_paint(gr){
   gr.SetTextRenderingHint(5);
   gr.SetSmoothingMode(2);
   var ww = window.Width;
   var wh = window.Height;
   var n;
   var t_color;
   try {
      arrow_image = gdi.Image( fb.FoobarPath + "\\s7e_files\\images\\arrow_down_black.png" );
   } catch(e) { fb.trace(e.message); }
   if ( g_move != undefined ) {
      gr.FillGradRect(1+g_move*ww/Active_array.length, 1, ww/Active_array.length - 2, (wh-1)/2, 90, RGB(248,251,254), RGB(237,242,250));
      gr.FillGradRect(1+g_move*ww/Active_array.length, wh/2, ww/Active_array.length - 2, (wh-3)/2, 90, RGB(215,228,244), RGB(193,210,232));
      gr.DrawRoundRect(1+g_move*ww/Active_array.length, 1, ww/Active_array.length - 3, wh - 3, 4, 4, 1, RGB(255,255,255));
      gr.DrawRoundRect(g_move*ww/Active_array.length, 0, ww/Active_array.length-1, wh-1, 4, 4, 1, RGB(170,190,210));
   if ( g_button_down != undefined ) {
      gr.FillGradRect(1+g_button_down*ww/Active_array.length, 1, ww/Active_array.length - 2, (wh-1)/2, 90, RGB(225,235,245), RGB(216,228,241));
      gr.FillGradRect(1+g_button_down*ww/Active_array.length, 0, ww/Active_array.length - 2, 3, 90, RGB(201,212,228), RGB(221,232,241));
      gr.FillGradRect(1+g_button_down*ww/Active_array.length, (wh-1)/2, ww/Active_array.length - 2, (wh-3)/2, 90, RGB(207,219,236), RGB(207,220,237));
      gr.DrawRoundRect(g_button_down*ww/Active_array.length, 0, ww/Active_array.length-1, wh-1, 4, 4, 1, RGB(170,190,210));
   for ( n=0; n<Active_array.length; n++ ) {
         if ( n == g_move ) t_color = RGB(0,0,0);
         else t_color = Active_array[n].name == '..' ? RGB(160,160,160) : RGB(30,50,90);
            gr.GdiDrawText( Active_array[n].name == '..' ? '(' + show_buttons + ')\n' + Active_array[n].name : Active_array[n].name, Active_array[n].name == '..' ? g_font2 : g_font, t_color, 2 + n * ww / Active_array.length, 0, ww / Active_array.length - 4, wh, 0x00000001 | 0x00000004 | 0x00040000 | 0x00000400);
            var string = gr.MeasureString(Active_array[n].name, g_font, 2 + n * ww / Active_array.length, 0, ww / Active_array.length - 4, wh, 0x00000001 | 0x00000004 | 0x00040000 | 0x00000400);
            if ( show_buttons == null && arrow_image ) gr.DrawImage( arrow_image, n * ww / Active_array.length + ( ww / Active_array.length / 2 ) + string.Width / 2 + 5, (wh - 10)/2, 14, 10, 0, 0, 16, 16, 0, 255);
    g_move = null;
   g_button_down = Math.floor( x / (window.Width/Active_array.length) );
   var i = Math.floor( x / (window.Width/Active_array.length) );
    if ( i < Active_array.length ) {
        try {
            if ( show_buttons ) Active_array[i].onClick();
            else {
                show_buttons = Sup_Buttons[i].name;
                update();
        catch(e) { }
function on_mouse_move(x,y){
   window.SetCursor(32649);
   //if ( !g_button_down && g_move != Math.floor( x / (window.Width/Active_array.length) ) ) {
        if ( x < window.Width ) {
            g_move = Math.floor( x / ( window.Width/Active_array.length ) );
            //fb.trace( 'x=' + x + '| g_move=' + g_move + ' | Active_array.length=' + Active_array.length + ' | window.Width=' + window.Width + ' | Active_array[g_move].name=' + Active_array[g_move].name);
            try {
                if ( g_move < Active_array.length ) {
                    tooltip.Text = Active_array[g_move].name;
                    tooltip.Activate();
            catch(e) { }
   if ( delta > 0 && show_buttons ) {
      update();
   g_move = null;
   window.SetCursor( 32512 );
    tooltip.Deactivate();
   var i = 1;
   var ret;
   _menu.AppendMenuItem(MF_STRING, i++, "Playing item");
   _menu.AppendMenuItem(MF_STRING, i, "Current selection");
   _menu.EnableMenuItem( mode, 1 );
   _menu.CheckMenuRadioItem( 1, i, mode );
   if (ret >= 1 && ret <= i) {
      utils.WriteINI( fb.FoobarPath + 's7e.ini', 'buttonbar-settings', 'buttonbar_mode', ret);
      mode = ret;
   return true;
// Config variables
// Variables
var mode;
var g_move = null;
var show_buttons;
// Script functions
// Metadb
   var ForWriting = 2;
   try {
      f.Write(write);
      f.Close();
   } catch(e) {
    if (obj) {
            val = obj[i];
                case ("string"):
                default:
    return output;
   var fso, f, r, b;
      r =  f.ReadAll();
      for (key in a) {
   else return false;
buttons = {
    undo: new Button( "Undo", Sup_Buttons[4].name, function() { fb.RunMainMenuCommand("Edit/Undo"); }),
   redo: new Button( "Redo", Sup_Buttons[4].name, function() { fb.RunMainMenuCommand("Edit/Redo"); }),
   sort_by_3d: new Button( "Sort by...", Sup_Buttons[4].name, function() { fb.RunMainMenuCommand("Edit/Selection/Sort/Sort by..."); }),
   select_all: new Button( "Select All", Sup_Buttons[4].name, function() { fb.RunMainMenuCommand("Edit/Select All"); }),
   crop: new Button( "Crop", Sup_Buttons[4].name, function() { fb.RunMainMenuCommand("Edit/Selection/Crop"); }),
   random_selection: new Button( "Randomize", Sup_Buttons[4].name, function() { fb.RunMainMenuCommand("Edit/Selection/Sort/Randomize"); }),
   buttons.reset,
   buttons.undo,
   buttons.redo,
   buttons.sort_by_3d,
   buttons.select_all,
   buttons.crop,
   buttons.mb_artist,
   buttons.aad_album
   this.name = name;
   this.sup = sup;
   this.func = func;
function update() {
      Active_array = [];
         else {
update();
   var n;
   var t_color;
   try {
    g_move = null;
        try {
            else {
                update();
        catch(e) { }
            try {
                    tooltip.Activate();
            catch(e) { }
      update();
   g_move = null;
   var i = 1;
   var ret;
      mode = ret;
   return true;
Так вроде бы можно сделать Автоплейлист из библиотеки.ponomart:Офтоп: может кто знает, есть ли возможность, что бы media library сама по себе являлась плейлистом? Может в какой сборке.
Если музыка в порядке и хочется дерева, но не медиабиблиотеки, для этого существует Tree Explorer. Которому можно при необходимости прописать в качестве root-а свой каталог с музыкой и запускать из него воспроизведение хоть потреково, хоть папками. Он и будет два в одном - и деревом, и плейлистом.ponomart:vladj, музыка конечно в порядке, и в ней легко все находится. Попытаюсь объяснить откуда вопрос. Посмотрите на второй скриншот в шапке: плейлист уже выглядит как развернутый эксплорер. Если бы плейлист был в виде дерева со всей музыкой, то ты просто находишь трек и его запускаешь обходясь без библиотеки.
У меня он что, неправильно настроен ? Потреково я из него запустить не могу, видны только альбомыonv:и запускать из него воспроизведение хоть потреково
