// Green = $puts(|,$rgb(148,204,72)' ● '$rgb(46,48,63))
// Orange = $puts(|,$rgb(220,99,18)' ● '$rgb(46,48,63))
// Red = $puts(|,$rgb(220,110,132)' ● '$rgb(46,48,63))
// Blue = $puts(|,$rgb(120,190,240)' ● '$rgb(46,48,63))
// Black = $puts(|,$rgb(0,0,0)' ● '$rgb(46,48,63))
//$if(%is_status_pane%,%artist% - %title%$crlf(),$if(%ispaused//%,Paused,Playing) | )%codec% | %bitrate% kbps | %samplerate% Hz | $caps//(%channels%) | %playback_time%[ / %length%]
$rgb(46,48,63)
//   Левая часть
%codec%
$get(|)%bitrate%' Kbit/s'[' '%__extrainfo%]
$get(|)%samplerate%' Hz'
//Если MP3
$if($stricmp(%codec%,'mp3'),
$get(|)$caps(%__mp3_stereo_mode%),
//Если MPC
$if($stricmp(%codec%,'Musepack'),
$get(|)$replace(%__codec_profile%,'',),
//Если OGG
$if($stricmp(%codec%,'Vorbis'),,
//Если APE
$if($stricmp(%codec%,'Monkey'$char(39)'s Audio'),
$get(|)%__codec_profile%
$get(|)%__bitspersample%' Bits',
//Если FLAC
$if($stricmp(%codec%,'FLAC'),
//Если WMA v7/v8
$if($stricmp(%codec%,'Windows Media Audio v7/v8'),,
//Если WMA v9
$if($stricmp(%codec%,'Windows Media Audio V9 (Lossless Mode)'),,
//Если WAV
$if($stricmp(%codec%,'PCM'),
//Если AC3
$if($stricmp(%codec%,'ATSC A/52'),
$get(|)%__channels%' '$ifgreater(%__channels%,1,'Channels','Channel')
//ReplayGain
$if($or(%__replaygain_track_gain%,%__replaygain_album_gain%),
$get(|)$if3(%__replaygain_track_gain%,'No')' TG'
$get(|)$if3(%__replaygain_album_gain%,'No')' AG'
//типы тегов
$if(%__tagtype%,
$get(|)
$replace(%__tagtype%,'|',' & '))
//% сжатия
$get(|)
$left($muldiv(%__bitrate%,10000,1411),$sub($len($muldiv(%__bitrate%,10000,1411)),2))'.'$right($muldiv(%__bitrate%,10000,1411),2)' % Compression'
//Размер файла
$if(%_time_total%,
$get(|)$if($strstr([$upper($ext(%path%))],CUE),CUE,$div(%filesize%,1048576)','$substr($muldiv(%filesize%,100,1048576),2,3)$get(t2)' Mb')
//   Правая часть
$tab()
$rgb(0,0,0)
//Процент воспроизведения
$if(%length%,
$max(0,$left($muldiv(%playback_time_seconds%,1000,%length_seconds%),$sub($len($muldiv(%playback_time_seconds%,1000,%length_seconds%)),1)))'.'$right($muldiv(%playback_time_seconds%,1000,%length_seconds%),1)' % Played'
$get(|)
//Время проигрывания/всего/осталось
'+'$left('00:00:00',$sub(8,$len(%playback_time%)))%playback_time%
['  '$left('00:00:00',$sub(8,$len(%length%)))%length%'  ']
['-'$left('00:00:00',$sub(8,$len(%playback_time_remaining%)))%playback_time_remaining%]
//Если пауза
$get(|)
$if(%ispaused%,$rgb(128,0,0)$if(%length%,'Paused','Stoped'),
$rgb(192,192,192)$if(%length%,'Paused','Stoped'))может поискать "$allign(center)" - [я не нашёл] соответственно, центр "center", слева "left", справа "right" ?,integrum:а какая строка отвечает за выравнивание по центру?
