Сборка FoobarRELAX by dav
Сообщение #1 dav1977 » 27.09.2014, 15:43
Дата сборки: 27.09.2014
Автор: неизв + remix by dav
В основе лежит полная версия плеера: foobar2000 v1.3.3
Длительно эксплуатировалась на Win8.1 работает стабильно
Читает DTS SACD FLAC Matr ALAC и др.
Core (2014-07-16 13:32:52 UTC)
foobar2000 core 1.3.3
foo_abx.dll (2009-06-07 12:25:26 UTC)
ABX Comparator 1.3.4
foo_ac3.dll (2010-04-13 02:00:12 UTC)
AC3 decoder 0.9.5
foo_adpcm.dll (2011-12-16 01:27:37 UTC)
kode's ADPCM decoders 1.10
foo_albumlist.dll (2014-07-16 13:29:06 UTC)
Album List 4.5
foo_audioscrobbler.dll (2010-06-04 06:27:04 UTC)
Audioscrobbler 1.4.7
foo_benchmark.dll (2013-06-15 17:27:27 UTC)
Decoding Speed Test 1.2.2
foo_bitcompare.dll (2008-12-05 17:08:02 UTC)
Binary Comparator 1.2
foo_bpm.dll (2010-04-20 12:35:07 UTC)
BPM Analyser 0.2.4.1
foo_cdda.dll (2014-07-16 13:28:50 UTC)
CD Audio Decoder 3.0
foo_channel_mixer.dll (2011-08-07 11:54:54 UTC)
Channel Mixer 0.9.6.7
foo_converter.dll (2014-07-16 13:29:00 UTC)
Converter 1.5
foo_crystalizer.dll (2010-01-04 18:09:50 UTC)
Crystalizer v1
foo_cuefilter.dll (2010-02-05 15:31:52 UTC)
CUE Playlist Filter 0.1.7.0
foo_discogs.dll (2011-08-21 06:01:28 UTC)
Discogs Tagger 1.30
foo_dsp_bs2b.dll (2009-12-13 10:42:30 UTC)
bs2b 3.1.0
foo_dsp_continuator.dll (2007-04-11 04:29:04 UTC)
Continuator 0.4.1
foo_dsp_convolver.dll (2011-11-18 17:12:42 UTC)
Convolver (gapless) 0.4.2
foo_dsp_crossfader.dll (2010-01-13 23:46:10 UTC)
Gapless Crossfader 1.3.4.1
foo_dsp_delta.dll (2008-10-24 12:57:16 UTC)
Noise Sharpening DSP 1.0.0
foo_dsp_dolbyhp.dll (2010-01-24 19:56:04 UTC)
Наушники Dolby 1.4.1
foo_dsp_downmix.dll (2012-06-16 12:03:26 UTC)
Downmix AC3/DTS to PL2 0.2
foo_dsp_effect.dll (2011-08-21 06:09:02 UTC)
Effect DSP 0.9.2
foo_dsp_eq.dll (2014-07-16 13:29:12 UTC)
Equalizer 1.0
foo_dsp_eqsplit.dll (2008-07-12 23:49:10 UTC)
Split equalizer v0.0.1
foo_dsp_force48kHz.dll (2008-08-18 20:54:46 UTC)
force 48kHz 2008.08.18
foo_dsp_freeverb.dll (2010-02-04 14:04:30 UTC)
Freeverb 0.3
foo_dsp_fsurround.dll (2011-01-31 22:56:46 UTC)
FreeSurround 0.8.1
foo_dsp_loudspeakereq.dll (2009-07-02 05:52:58 UTC)
Loudspeaker Equalizer 1.0.1
foo_dsp_lowpass.dll (2010-04-07 15:04:30 UTC)
SoX Lowpass filter 0.0.2
foo_dsp_midside.dll (2011-04-30 13:12:19 UTC)
Mid/Side Stereo Converter 0.1
foo_dsp_mm.dll (2009-12-23 17:39:04 UTC)
Matrix Mixer 0.3
foo_dsp_muleteer.dll (2013-03-24 21:33:10 UTC)
Muleteer DSP 0.78
foo_dsp_noise.dll (2009-06-28 17:28:32 UTC)
Add Noise DSP 0.0.4
foo_dsp_resampler.dll (2013-06-15 17:27:11 UTC)
SoX Resampler 0.8.3
foo_dsp_resampler_mod.dll (2011-11-18 17:12:34 UTC)
SoX Resampler mod 0.7.6 mod
foo_dsp_resampler_mod2.dll (2013-06-15 17:27:19 UTC)
SoX Resampler mod2 0.8.3 mod2
foo_dsp_skip_silence.dll (2011-08-07 12:42:30 UTC)
Skip Silence 1.0
foo_dsp_soundtouch.dll (2010-01-14 23:08:06 UTC)
SoundTouch DSP 1.1
foo_dsp_span.dll (2009-04-07 11:35:31 UTC)
Surround Pan 1.3
foo_dsp_spxresample.dll (2011-08-20 14:03:22 UTC)
Speex Resampler 0.1
foo_dsp_srcresample.dll (2011-08-24 17:59:44 UTC)
Secret Rabbit Code Resampler 0.1
foo_dsp_ssrc.dll (2011-04-27 19:50:39 UTC)
Resampler DSP (SSRC) 0.57
foo_dsp_ssrcX.dll (2011-02-25 23:34:35 UTC)
Resampler DSP (SSRC X) 0.57
foo_dsp_std.dll (2014-07-16 13:28:58 UTC)
Standard DSP Array 1.3
foo_dsp_xfeed.dll (2011-09-21 14:49:31 UTC)
Crossfeed 0.1.3
foo_dsp_xgeq.dll (2012-05-28 08:31:07 UTC)
Graphic Equalizer 0.3.7
foo_dumb.dll (2013-06-15 17:17:41 UTC)
DUMB module decoder 1.0.30
foo_fileops.dll (2014-07-16 13:28:26 UTC)
File Operations 2.2.1
foo_freedb2.dll (2014-07-16 13:28:38 UTC)
Online Tagger 0.7
foo_hdcd.dll (2012-08-18 07:09:09 UTC)
HDCD decoder 1.15
foo_input_avs.dll (2014-09-24 15:26:09 UTC)
AVS input 0.4
foo_input_dts.dll (2014-09-24 15:27:06 UTC)
DTS decoder 0.3.3
foo_input_dvda.dll (2012-03-16 14:30:28 UTC)
foo_input_exe.dll (2012-10-17 21:28:49 UTC)
Command-Line Decoder Wrapper 0.4
foo_input_monkey.dll (2009-05-01 08:40:52 UTC)
Monkey's Audio Decoder 2.1.4
foo_input_msl.dll (2010-01-13 21:12:00 UTC)
mslive 1.4.9.2
foo_input_sacd.dll (2012-08-25 16:03:10 UTC)
Super Audio CD Decoder 0.5.11
foo_input_std.dll (2014-07-16 13:32:52 UTC)
Standard Input Array 1.0
foo_input_tak.dll (2013-06-15 17:27:36 UTC)
TAK Decoder 0.4.6 beta 4
foo_input_tta.dll (2010-10-30 11:24:31 UTC)
TTA Audio Decoder 3.2
foo_input_wmx.dll (2010-01-13 21:00:46 UTC)
Acro WMA decoder 1.1.7.2
foo_masstag.dll (2007-08-20 11:01:20 UTC)
Masstagger 1.6
foo_midi.dll (2013-05-01 19:47:48 UTC)
MIDI synthesizer host 1.201
foo_musical_spectrum.dll (2012-11-21 04:00:00 UTC)
Musical Spectrum 0.9.1
foo_musicbrainz.dll (2012-07-24 22:23:28 UTC)
MusicBrainz Tagger 0.3
foo_out_asio.dll (2012-06-08 19:42:43 UTC)
ASIO support 2.1.2
foo_out_ks.dll (2006-08-04 19:54:58 UTC)
Kernel Streaming Output 1.2.2
foo_playcount.dll (2011-08-07 11:44:01 UTC)
Playback Statistics 3.0.2
foo_popupplus.dll (2008-04-24 23:24:18 UTC)
PopUp Plus 20080424
foo_rgscan.dll (2014-07-16 13:31:50 UTC)
ReplayGain Scanner 2.2.1
foo_run.dll (2009-06-07 12:15:18 UTC)
Run services 0.3.7
foo_runcmd.dll (2010-01-07 21:32:34 UTC)
Run Command 1.1
foo_scheduler.dll (2012-09-08 10:22:02 UTC)
Scheduler 4.10
foo_softplaylists.dll (2011-02-10 19:50:41 UTC)
Soft Playlists 2011-02-05
foo_texttools.dll (2010-09-01 16:45:46 UTC)
Text Tools 1.0.5
foo_ui_columns.dll (2011-02-27 23:22:58 UTC)
Columns UI 0.3.8.8
foo_ui_std.dll (2014-07-16 13:32:52 UTC)
Default User Interface 0.9.5
foo_uie_elplaylist.dll (2010-10-30 16:51:16 UTC)
ELPlaylist 0.6.9.1.2(beta)
foo_uie_explorer.dll (2010-02-22 16:51:29 UTC)
Explorer Tree 2.04.8
foo_uie_panel_splitter.dll (2011-03-07 08:34:42 UTC)
foo_uie_playlists_dropdown.dll (2007-02-08 13:26:16 UTC)
Playlists Dropdown 0.6 alpha 3
foo_uie_trackinfo_mod.dll (2012-10-30 20:48:12 UTC)
Track info panel mod 0.8.0 beta [Jan 5 2007 - 13:36:12]
foo_uie_vis_peakmeter_spectrum.dll (2012-10-30 20:47:10 UTC)
foo_uie_wsh_panel_mod.dll (2012-10-28 16:33:31 UTC)
WSH Panel Mod 1.5.6
foo_unpack.dll (2014-07-16 13:28:20 UTC)
ZIP/GZIP/RAR Reader 1.6
foo_unpack_7z.dll (2011-09-21 16:56:32 UTC)
7-Zip reader 1.8
foo_verifier.dll (2013-04-09 07:34:05 UTC)
File Integrity Verifier 1.1.1
foo_vis_vumeter.dll (2013-02-16 07:44:26 UTC)
VU Meter 2013-02-16
foo_vst.dll (2011-03-05 07:19:04 UTC)
VST 2.4 adapter 0.9.0.3
foo_wave_seekbar.dll (2013-06-15 17:17:42 UTC)
Waveform seekbar 0.2.39.6
вставлены VST
iZotope.Ozone.5.Advanced.v5.04-R2R только EQ
BBE_Sound
jb_isone_pro
ПО УМОЛЧАНИЮ VST в PRESET на задействованы
СКАЧАТЬ: dropbox
https://www.dropbox.com/s/kq4qks17yaiiley/FOOBAR%20RELAX%20by%20dav.rar?dl=0
Последний раз редактировалось dav1977 27.09.2014, 15:57, всего редактировалось 2 раз(а).
dav1977
С нами: 10 лет 9 месяцев
Сообщение #2 simmons » 27.09.2014, 16:15
Посмотрим какой тебе рейтинг выставят. Меня уже минусовали за такую сбоорку - поэтому и просил админа удалить некоторые мои сборки.
Да, и меня просто рассмешило (автор неизвестен) (ты взял мой конфиг и переделал)...
Ну давай дерзай, удачи!
Сообщение #3 macarych » 27.09.2014, 16:20
simmons:Да, и меня просто рассмешило (автор неизвестен) (ты взял мой конфиг и переделал)...
похоже ты прав.
dav1977:Автор: неизв + remix by dav
а вы, уважаемый, не правы. Автора тут все очень хорошо знают, по аккуратнее надо, все-таки авторские права и все такое...
Последний раз редактировалось macarych 27.09.2014, 16:24, всего редактировалось 2 раз(а).
Сообщение #4 dav1977 » 27.09.2014, 16:22
дай ссылку на свой конфиг не видел?
Я ее качнул с deviantart.com
а теперь ее там не могу найти
а вот вы уж точно не правы macarych
я не обязан знать все сборки в мире
dav1977
Сообщение #5 macarych » 27.09.2014, 16:38
спокойнее, я не на кого не наезжаю, поэтому и скобки добавил, они у меня вместо смайликов )
Сообщение #6 dav1977 » 27.09.2014, 16:44
да действительно у simmons есть сборка FOO THUNDER
/viewtopic.php?t=5261
но мне мой remix больше нравиться (качнул я ее году этак в 2008, simmons может тоже ее просто ремиксует)
пускай народ пользуется
Последний раз редактировалось dav1977 27.09.2014, 16:46, всего редактировалось 1 раз.
dav1977
Сообщение #7 simmons » 27.09.2014, 16:45
Да ладно Dav :)
Потому что я ее выложил на девиант а потом стер. Вот так это было.
Ну Маккарыч ты меня просто развеселил, пусть Dav делает с этой сборкой что хочет, я например желаю ему успеха.
macarych:а вы, уважаемый, не правы. Автора тут все очень хорошо знают, по аккуратнее надо, все-таки авторские права и все такое...
Мы ведь говорили-то, что искуство принадлежит народу :)
Последний раз редактировалось simmons 27.09.2014, 16:48, всего редактировалось 1 раз.
Сообщение #8 macarych » 27.09.2014, 16:47
я подумал что ты разозлился )
Сообщение #9 simmons » 27.09.2014, 16:54
Я ? Да ну! Маккарыч пусть люди радуются тому что они делают, кто-то наверняка и взял что-то и из твоих сборок и твои индикаторы и впаял себе в сборку.
Это творческий процесс. Надо отоситься к этому с пониманием, с терпением... Кто знает как и кому тут что-то удалось сделать и каким образом он добился результатов, может он сидел долго над своей сборкой и все переделывал да переделывал?
Сообщение #10 dav1977 » 27.09.2014, 16:55
мне на рейтинг все равно, я тут проездом за 8 лет 2 раз
НА авторство не претендую
если хотите могу исправить "неизв" на известный :smile:
dav1977
Сообщение #11 simmons » 27.09.2014, 17:01
Да делай как хочешь Dav. Мне тоже все равно.
Сообщение #12 kgena_ua » 27.09.2014, 20:23
simmons, а я думаю что эта тема только в плюс для твоих конфигураций. Иногда твои сборки минусовали, а тут бац, и на основе твоей сборки...
С нами: 12 лет 3 месяца
Сообщение #13 vladj » 27.09.2014, 21:38
И что бац ? Спортил сборку мелькалками. Тоже мне, Relax... когда глаза в разбег от этих излишеств
прыгающих - мелькающих, несущих одну и ту-же функцию, избыточных по сути. ИМХО.
С нами: 15 лет 5 месяцев
Сообщение #14 kgena_ua » 27.09.2014, 22:08
vladj, я наверное не совсем правильно выразился. Я имел ввиду что сборку от simmons оценили и взяли за основу, и это главное, это в плюс для simmons. При этом оценку данной сборке я не давал.
Сообщение #15 simmons » 28.09.2014, 00:07
kgena_ua:simmons, а я думаю что эта тема только в плюс для твоих конфигураций. Иногда твои сборки минусовали, а тут бац, и на основе твоей сборки...
Иногда твои сборки минусовали, а тут тебе такой бац - все что бы ты не выкладывал минус, за вопрос за что минус еще один минус... И пошло и поехало. :))
...Прямо счастье привалило :) Весь просто сияю от счастья :)
Мы ведь всего лишь расположили компоненты (готовые компоненты) таким образом как нам кажется правильным, звук остался тем же да и плагины не написали.
vladj:И что бац ? Спортил сборку мелькалками. Тоже мне, Relax... когда глаза в разбег от этих излишеств
Только цветомузыки не хватает :)))
Сообщение #16 Qfile68 » 09.10.2014, 22:29
simmons,извините ,но Вы эту сборку пилили под себя со сборки ребят USETOOLS,вот там был минимализм... :smile:
Qfile68
Сообщение #17 kgena_ua » 10.10.2014, 11:01
Qfile68, я всегда следил за сборками от simmons и у меня есть большие сомнения, что simmons делал свои сборки, переделывая другие под себя.
Сообщение #18 simmons » 10.10.2014, 11:10
Qfile68:simmons,извините ,но Вы эту сборку пилили под себя со сборки ребят USETOOLS,вот там был минимализм... :smile:
От utbar (usetools) я взял только только ELP плейлист, да и то передалал его под себя. :smile:
Обсудим где что я своровал? :smile:
Сообщение #19 TaoZuiyin » 23.05.2022, 12:25
dav1977 Friends this download address is invalid, please connect :smile: :smile: :smile: :smile: :smile:
TaoZuiyin
С нами: 3 года 7 месяцев
