Сообщение #2001 musikomaniak » 12.11.2017, 12:25
Thank you MC Web.
musikomaniak F
С нами: 8 лет 3 месяца
Сообщение #2002 kgena_ua » 12.11.2017, 18:00
Rating & File attributes (JScript Panel)
version "12112017"
Надо тестировать.
// @name "Rating & File attributes (JScript Panel)"
// @author "kgena_ua"
// @version "12112017"
// @feature "v1.4"
// @feature "watch-metadb"
// foo_playcount.dll required
function getRed(color) {return ((color >> 16) & 0xff);}
function getGreen(color) {return ((color >> 8) & 0xff);}
function getBlue(color) {return (color & 0xff);}
function RGBA_color(c) {
    return RGBA(getRed(c), getGreen(c), getBlue(c), b_hover_alpha);
var font_name = window.GetProperty(" text: font name", "Arial");
var font_size = window.GetProperty(" text: font size", 10);
var font_style = window.GetProperty(" text: font style", 0);
var font;
get_font();
function get_font(){
    font = gdi.Font(font_name, font_size, font_style);
var ww, wh;
DT_LEFT = 0x00000000;
DT_CENTER = 0x00000001;
DT_VCENTER = 0x00000004;
DT_SINGLELINE = 0x00000020;
MF_ENABLED = 0x00000000;
MF_GRAYED = 0x00000001;
MF_SEPARATOR = 0x00000800;
IDC_HAND = 32649;
IDC_ARROW = 32512;
ColorTypeCUI = {
    text: 0,
    selection_text: 1,
    inactive_selection_text: 2,
    background: 3,
    selection_background: 4,
    active_item_frame: 6
ColorTypeDUI = {
   text: 0,
   background: 1,
   highlight: 2,
   selection: 3
function get_color(){
        color1 = window.GetColorCUI(ColorTypeCUI.text);
        color2 = window.GetColorCUI(ColorTypeCUI.selection_text);
        color_error = RGB(255,100,0);
        color1 = window.GetColorDUI(ColorTypeDUI.text);
        color2 = window.GetColorDUI(ColorTypeDUI.highlight);
get_color();
function on_colors_changed(){
    get_color();
var rating = 0, TAGrating, DBrating, nrating = 0;
var rating_mode = window.GetProperty("rating_mode", 0);
var set_rating_5 = window.GetProperty("set rating 5", false);
var x_text = window.GetProperty(" text: x", 0);
var y_text = window.GetProperty(" text: y", 0);
var text = window.GetProperty(" text", true);
var x_star = window.GetProperty(" star: x (0 - HCENTER)", 0);
var y_star = window.GetProperty(" star: y (0 - VCENTER)", 0);
var x_s, y_s;
var star_size = window.GetProperty(" star: size", 20);
var offset = window.GetProperty(" star: offset (percent of star size)", 20) / 100 * star_size;
var shadow = window.GetProperty(" shadow", true);
var fade_effect = window.GetProperty("fade effect", true);
var no_rating_transparent  = window.GetProperty(" no rating img transparent (0-255)", 120);
var file, file_attr, readwrite;
var lbtn_down = false;
var on_mouse = false;
var tooltip = window.GetProperty(" tooltip", true);
var tooltip_on = false;
var tooltip_text;
var tooltip_timer;
var t_type;
var metadb;
var count;
on_item_focus_change();
function on_paint(gr){
    x_s = x_star > 0 ? x_star + star_size / 2: (ww - (star_size + offset) * 4) / 2;
    y_s = y_star > 0 ? y_star + star_size / 2 : wh / 2;
    if (!lbtn_down) r_color = fb.IsPlaying ? color2 : color1;
    if (lbtn_down) r_color = readwrite ? fb.IsPlaying ? color2 : color1 : color_error;
    for (var i = 0; i < 5; i++) {
        x_d = x_s + (i * (star_size + offset));
        !tooltip_on && star(gr, x_d, y_s, star_size, true, 0, color1, false, bgcolor, no_rating_transparent);
        !tooltip_on && star(gr, x_d, y_s, star_size, true, 0, r_color, shadow, bgcolor, star_alpha[i]);
    h_t = gr.CalcTextHeight("000", font);
    w_t = gr.CalcTextWidth("000", font);
    y_t = y_text > 0 ? y_text : y_s - h_t * 0.5;
    x_t = x_text > 0 ? x_text : x_s - star_size / 2 - w_t;
    text && gr.DrawString( rating_mode == 0 ? "db" : "tag" , font, RGBA_color(color1), x_t, y_t, ww, wh);
    tooltip_on && draw_tooltip(gr);
    gr.GdiDrawText( "", font, RGB(255,255,200), 20, 10, ww, wh );
function getNRating(posx) {
    nrating = Math.ceil(( posx + star_size / 2 - x_s ) / (star_size + offset ));
    if (nrating > 5) nrating = 5;
    if (nrating < 0) nrating = 0;
    if (nrating != 0) nrating = set_rating_5 ? 5 : nrating;
function getRating(){
  if ( count > 1 ) {
        TAGrating = 0;
        DBrating = 0;
            DBrating += parseInt(fb.TitleFormat("$if2(%rating%, 0)").EvalWithMetadb(item));
            TAGrating += parseInt(fb.TitleFormat("$if2($meta(rating), 0)").EvalWithMetadb(item));
        rating = rating_mode == 0 ? DBrating : TAGrating;
        rating = Math.round(rating / count);
        DBrating = fb.TitleFormat("$if2(%rating%,0)").EvalWithMetadb(metadb);
        TAGrating = fb.TitleFormat("$if2($meta(rating),0)").EvalWithMetadb(metadb);
function setRating(){
   if ((nrating != rating) && metadb) {
        if (rating_mode == 0) {
            if (count > 1) {
                    fb.RunContextCommandWithMetadb("Playback Statistics/Rating/" + (nrating == 0 ? "<not set>" : nrating), item);
            } else{
                fb.RunContextCommandWithMetadb("Playback Statistics/Rating/" + (nrating == 0 ? "<not set>" : nrating), metadb);
            rating = nrating;
        if (rating_mode == 1) {
            if (count > 1) {
                    item_path = fb.Titleformat("%path%").EvalWithMetadb(item);//
                    try {
                        file = fso.GetFile(item_path);
                        var file_attr = parseInt(file.Attributes);
                    } catch(e) {};
                    var item_rw = file_attr == 32 ? true : false;
                    if (item_rw) {
                        var handle = item;
                        var handles = fb.CreateHandleList();
                        handles.Add(handle);
                        handles.UpdateFileInfoFromJSON(JSON.stringify({ "Rating" : nrating == 0 ? "" : nrating }));
                        handles.Dispose();
                        rating = nrating
                if (readwrite){
                    var handle = metadb;
                    handles.Dispose();
                    rating = nrating
    if (!readwrite && rating_mode == 1) {
        tooltip && info_tooltip();
    lbtn_down = false;
    setRating();
    check_star_state();
    lbtn_down = true;
    tooltip && clear_tooltip_timer();
    getNRating(x);
    check_star_state();
function on_mouse_mbtn_up(){
    nrating = 0;
    setRating();
    on_mouse = true;
    window.SetCursor(IDC_HAND);
    if (lbtn_down){
        getNRating(x);
    button_change_state();
    check_star_state();
    on_mouse = false;
    button_leave_change_state();
    window.SetCursor(IDC_ARROW);
    if (delta > 0) {rating_mode = 0};
    if (delta < 0) {rating_mode = 1};
    window.SetProperty("rating_mode", rating_mode);
function on_playback_stop() {
    switch (selection_mode) {
    case 0:
    case 1:
        metadb = fb.GetFocusItem();
    if (metadb) {
        rating_mode = window.GetProperty("rating_mode") == 0 ? 0 : 1;
        getRating();
        check_star_state();
        get_file_attr();
function on_size(){
    _menu.AppendMenuItem(MF_ENABLED, 10, "Prefer now playing");
    _menu.AppendMenuItem(MF_ENABLED, 11, "Follow selected track");
    _menu.CheckMenuRadioItem(10, 11 , selection_mode + 10);
    _menu.EnableMenuItem(selection_mode + 10, 1);
    _menu.AppendMenuItem(MF_ENABLED, 20, "Store Ratings in the database");
    _menu.AppendMenuItem(MF_ENABLED, 21, "Store Ratings in the file tags");
    _menu.CheckMenuRadioItem(20, 21, rating_mode + 20);
   _menu.EnableMenuItem(rating_mode + 20, 1);
    _menu.AppendMenuItem(MF_ENABLED, 30, "Set Rating 5");
    _menu.CheckMenuItem(30, set_rating_5);
    switch (file_attr) {
    case 32:
        txt = "to read - only";
    case 33:
        txt = "to read - write";
    default:
        txt = "";
    MF_STRING = txt ? MF_ENABLED : MF_GRAYED;
    _menu.AppendMenuItem(MF_STRING, 40, "Change file attributes " + txt);
    _menu.AppendMenuItem(MF_ENABLED, 50, "Fade effect");
    _menu.CheckMenuItem(50, fade_effect);
    _menu.AppendMenuItem(MF_ENABLED, 100, "Properties");
    _menu.AppendMenuItem(MF_ENABLED, 200, "Configure...");
    ret = _menu.TrackPopupMenu(x + 20, y - 20);
    if (ret == 0) return;
    switch (ret) {
    case 10:
    case 11:
        selection_mode = ret - 10;
    case 20:
    case 21:
        rating_mode = ret - 20;
    case 30:
        window.SetProperty("set rating 5", !set_rating_5);
        set_rating_5 = window.GetProperty("set rating 5");
    case 40:
        case 32:
            if (metadb) change_file_attr(33); //read only
        case 33:
            if (metadb) change_file_attr(32); //read write
    case 50:
    case 100:
        window.ShowProperties();
    case 200:
        window.ShowConfigure();
    _menu.Dispose();
    return true;
function get_file_attr() {
    t_type = track_type(metadb.RawPath);
    file_attr = 0;
    if (t_type == "file") {
            try {
                file_attr += parseInt(file.Attributes);
            } catch(e) {};
        file_attr = Math.round(file_attr / count);
    var file_read_only = file_attr == 32 ? false : true;
    var file_cue = t_type == "cue" ? true : false;
    var stream = t_type == "stream"  ? true : false;
    tooltip_text = file_cue ? " cue file " : file_read_only && t_type == "file" ? " file" + (count > 1 ? "s are " : " is ") + "read only " : stream ? " stream " : "";
    if ((file_cue || file_read_only || stream) && rating_mode == 1 ) {
        readwrite = false;
        readwrite = true;
function change_file_attr(k) {
            try {
                file.Attributes = k;
            } catch(e) {};
function star(gr, x, y, img_size, fill, line_thickness, color, sh, sh_color, alpha){
    var radius = img_size / 2;
        if (i % 2 == 0) {
    temp_gr.SetSmoothingMode(2);
    if (line_thickness > 0) {
    img.ReleaseGraphics(temp_gr);
    img.Dispose();
    temp_gr = null;
    img = null;
function track_type(p) {
    var type;
    if (p.indexOf("file") >= 0 && p.indexOf("cue") >= 0){
        type = "cue";
    } else if (p.indexOf("file") >= 0){
        type = "file";
    } else if (p.indexOf("cdda") >= 0){
        type = "cdda";
    } else if (p.indexOf('://') >= 0 || p.indexOf('www') >= 0 || p.indexOf("youtube") >= 0 || p.indexOf("video") >= 0 || p.indexOf("vimeo") >= 0){
        type = "stream";
        type = "";
    return type;
var b_hover_state, b_hover_alpha = 0;
var star_state = [];
var star_alpha = [];
check_star_state();
var b_timer_started = false;
function check_star_state() {
    star_state = [];
        r = lbtn_down ? nrating : rating;
        if (i < r) {star_state[i] = 1} else (star_state[i] = 0);
function button_change_state() {
    b_hover_state = 1;
    if (b_hover_state != 0) {
        b_hover_state = 0;
    b_timer_started = true;
    var on_step = 51;
    var off_step = 20;
        switch (b_hover_state) {
        case 0:
            b_hover_alpha = fade_effect ? Math.max(0, b_hover_alpha -= off_step) : 0;
        case 1:
            b_hover_alpha = fade_effect ? Math.min(255, b_hover_alpha += on_step) : 255;
            if (!star_alpha[i]) star_alpha[i] = 0;
            switch (star_state[i]) {
            case 0:
                star_alpha[i] = fade_effect ? Math.max(0, star_alpha[i] -= off_step) : 0;
            case 1:
                star_alpha[i] = fade_effect ? Math.min(255, star_alpha[i] += on_step) : 255;
        if (!on_mouse){
            var tmp_off = [];
            var tmp_on = [];
            for(var i = 0; i < star_alpha.length; i++) {
                if (star_state[i] != 1) tmp_off.push(star_alpha[i]);
                if (star_state[i] == 1) tmp_on.push(star_alpha[i]);
            if (b_hover_alpha <= 0 && Math.max.apply(null, tmp_off) <= 0 && Math.min.apply(null, tmp_on) >= 255){
    }, 30);
function info_tooltip() {
    tooltip_on = true;
    tooltip_timer &&  window.ClearTimeout(tooltip_timer);
        tooltip_on = false;
    }, 1000);
function clear_tooltip_timer(){
    if (tooltip_timer){
        tooltip_on = false;
        window.ClearInterval(tooltip_timer);
function draw_tooltip(gr){
    w_tt = 4 * (star_size + offset) + star_size;
    x_tt = x_s - star_size / 2;
    h_tt = gr.CalcTextHeight("0", font) + 2;
    y_tt = y_s - h_tt * 0.5;
    gr.GdiDrawText( tooltip_text, font, color1, x_tt, y_tt, w_tt, h_tt, DT_SINGLELINE | DT_CENTER | DT_VCENTER | DT_WORD_ELLIPSIS);
function print(msg) {
    fb.trace(msg);
С нами: 12 лет 4 месяца
Сообщение #2003 Aliado_71 » 13.11.2017, 21:58
kgena_ua:Надо тестировать.
Работает, сохраняет и в базу и в теги нормально, :beer:
С нами: 10 лет 5 месяцев
Сообщение #2004 kgena_ua » 14.11.2017, 13:42
Aliado_71:сохраняет и в базу и в теги нормально
Вот и славно. Осталось сделать поддержку одновременно WSH Panel и JScript Panel
Сообщение #2005 AHAPXICT » 14.11.2017, 14:24
kgena_ua, Приветствую :beer:
kgena_ua:Осталось сделать поддержку одновременно WSH Panel и JScript Panel
Я вчера проверял на ХР, на радио в БД пишет без проблем. А что есть несовместимость? Или ограничение по IE9?
Сейчас проверил на JS v1.2.4 при записи в тег выдало ошибку:
Объект не поддерживает свойство или метод "CreateHandleList"
File: <main>
Line: 221, Col: 21
С нами: 11 лет 9 месяцев
Сообщение #2006 kgena_ua » 14.11.2017, 18:20
AHAPXICT, привет.
Скрипт делался для JS v1.3.0. Именно с этой версии убрана поддержка UpdateFileInfoSimple и добавлен метод UpdateFileInfoFromJSON для записи данных в тэг.
Сообщение #2007 AHAPXICT » 14.11.2017, 18:55
Да я в курсе, сам оставлял сообщение в теме с изменениями к версии 1.3 . Просто когда запустил скрипт и записал рейтинг в БД, мне показалось что функция работает. В общем проехали, всё равно пока не планирую переходить на последнюю версию панели JS.
Сообщение #2008 kgena_ua » 14.11.2017, 19:00
AHAPXICT, а для записи рейтинга в БД ничего не менялось. Что в WSH, что в JScript - методы одинаковы.
Сообщение #2009 AHAPXICT » 14.11.2017, 19:14
Меня с толку сбила ошибка про которую раньше писал, так что это уже не важно.
Правильно MC Web сказал
MC Web:Похоже этот компонент скоро только на WIN10 будет работать.
Сообщение #2010 drobovik » 14.11.2017, 22:15
Добряки, расскажите пожалуйста как решить мою проблему.
Захотел я в сборку добавить себе пару панелей.
Добавить добавил, всё работает, но теперь не могу удалить ненужные. Я понимаю что это основы, но и я ну совсем зелёный новичок в этом вопросе.
У меня получилось только "выключить" отображение ненужной панели, но пустое место осталось - я его показал стрелочкой.
Ну и чтоб два раза не вставать - как можно поменять местами эти панели-кнопки?
Я имею в виду LYR, INF, BIO и т.д.
drobovik M
С нами: 15 лет 5 месяцев
Сообщение #2011 vladj » 14.11.2017, 23:34
drobovik:У меня получилось только "выключить" отображение ненужной панели, но пустое место осталось - я его показал стрелочкой.
Правильно назвал кнопки кнопками....что-бы ответить нужно иметь такую-же сборку, а так навскидку....это очень просто меняется в скрипте, где прописаны эти кнопки, там у них только поменять значения по горизонтали, а не нужную кнопку сначала закомментировать (двойным слэшем), затем удалить строки которые к ней относятся. Правой по кнопкам, Splitter Settings > Script. В окне скрипта ищешь строчки, которые относятся к кнопкам, типа
$imagebutton(120,40,50,50, т.е. это имидж-рисунок кнопки, где первое значение (тут 120 например) это расположение по горозонтали. Меняешь это значение (первый блок цифирок) что-бы кнопки выстроились так, как тебе нужно. Не нужную панель кстати не выключают, а удаляют или меняют на другую. PS. после изменений не забываем справа-внизу применить Apply.
С нами: 15 лет 6 месяцев
Сообщение #2012 drobovik » 15.11.2017, 00:18
vladj:Правильно назвал кнопки кнопками....
Терминологию я подтяну. Сегодня впервые занимаюсь "фубаростроительством". Хотя скорее это "фубаронастройка".
vladj:что-бы ответить нужно иметь такую-же сборку
Это сборка catrox_1_april_2014__by_extremehunter
Настройки скрипта я нашёл, но там $imagebutton имеет значения (,,,,,,,) - это меня поставило в тупик.
Добряк, а ты можешь посмотреть сам? Но самое главное показать мне как, я хочу уметь это делать и настраивать сам, а куда копать пока не пойму.
Чтобы было проще и исключить влияние моих возможных ковыряний, я снова скачал и настроил сборку по инструкциям под себя (добавил три кнопки через компонент foo_jscript_panel-v1.3.0 - больше ничего не делал)
Из хотелок - полностью снести крайнюю слева кнопку-панель BIO - и рассказать как это делается.
Кнопку TREE поставить крайней левой, кнопку LIB второй слева. Ну и показать как это делать.
Залил архив на ЯД. Сборка портабельная, возможно нужно будет установить пару шрифтов, но они есть в архиве.
Был бы весьма признателен за помощь и науку.
https://yadi.sk/d/EyvzLIrc3PhamS
drobovik M
Сообщение #2013 seriousstas » 26.11.2017, 04:20
Финальная версия модифицированного под тач варианта
@name "Biography Text & Album Info & Picture. www.last.fm"
@author "kgena_ua"
@version "18112016"
Подробно здесь .
Можно использовать и в обычных условиях ..
Изменения восновном в плане стабильности, исправления , например это исправил
работает и с JScript Panel v1.3.2 [25.11.2017]
За коментами есть возможность управления циклом из MPS (что-б не листал , когда спрятан)
и отключение кнопок и текста , когда используется ,как аватарка (мелкое окно)
применял в своей сборке, мож пригодится кому..
С нами: 10 лет 6 месяцев
Сообщение #2014 MC Web » 27.11.2017, 16:01
AHAPXICT:Правильно MC Web сказал
AHAPXICT, приветствую.
Похоже мои опасения подтверждаются, по данному принципу будут обновляться и новые версии Columns UI.
С нами: 11 лет 11 месяцев
Сообщение #2015 seriousstas » 27.11.2017, 17:39
AHAPXICT
Делал стресс тесты недавно для с JScript Panel v1.3.X успешно пройдены в отличии от с JScript Panel v1.2.X , с которой были ранее описанные проблены ,
можно смело перелазить ) , как (соглашаясь с duzzy) и на поновее ОС 7 или 10 по выбору .
Сообщение #2016 AHAPXICT » 27.11.2017, 22:37
Приветствую всех :beer:
MC Web, да я читал на гидрогене, по моему, что последняя бета версия будет последней что поддерживает ХР. Ну да это не проблема, CUI нормально и последовательно развивается. А вот что касается JS то "некоторые" по моему без тормозов.
seriousstas, у тебя есть желание каждую неделю скрипты переделывать, которые между собой тупо не совместимы не в какой последовательности?
Марк удалил рендеринг текста в последней версии, задали вопрос на форуме, выложил скрипт в котором просто удалил "лишние" строки или как-то так. Для меня это не приемлемо, и дело тут не в операционной системе. MC Web, ты смотрел этот скрипт(DarkOne4Mod v1)? Оцени проделанную работу, запустить можно и на v4 на панели WSH, достаточно строку // @import заменить на свою.
Сообщение #2017 MC Web » 28.11.2017, 00:57
AHAPXICT:ты смотрел этот скрипт(DarkOne4Mod v1)? Оцени проделанную работу, запустить можно и на v4 на панели WSH, достаточно строку // @import заменить на свою.
Посмотрел, только не понял, а в чем разница от такого же скрипта для DarkOne 3.0 - 4.0?
Сообщение #2018 AHAPXICT » 28.11.2017, 01:16
MC Web:Посмотрел, только не понял, а в чем разница от такого же скрипта для DarkOne 3.0 - 4.0?
Я сжато писал и толком не объяснил. Разницы не какой, tedgo тут не причём, Марк удалил из последней версии JS панели рендер текста, ну и естественно удалил его из скрипта исправленного под последнюю версию панели, теперь при переключении вообще не отображается название типа обложки. Ну ты понял о чём я)))
Сообщение #2019 MC Web » 28.11.2017, 01:35
JS панели меня разочаровали - удалил из своего меню и забыл.
Сообщение #2020 seriousstas » 28.11.2017, 02:57
AHAPXICT
Здравствуй , а примеры таких скриптов , где столько гемора ?
использую более десятка разных .. один раз поправил синтаксис после появления v1.2.X -ВСЁ!
хотя сознаюсь - опасения были , что автор снова чего-то "допилил"
Про то как править за три минуты старые WSH под JS есть пояснения у Марка - обычно все сводится к замене fb на plman..
WSH панель в мусорке год как ..)
