foobar2000 v1.6.0
Сообщение #1 VEG » 30.06.2020, 14:07
Вышла финальная версия foobar2000 v1.6.0! Предыдущая версия: foobar2000 v1.5.5.
  • Changed system requirements: Windows 7 and a processor with SSE2 instruction set. Windows XP is no longer supported.
  • Default output mode is now WASAPI shared.
  • New fading capability that works with alternate output modes.
  • Default archive reader now supports 7-zip format.
  • Added support for WebP album covers (Default UI, Properties dialog). Settings need to be changed to look for folder.webp instead of folder.jpg.
  • Removed mixer volume sync feature due to bugs.
  • Cleaned up foo_rgscan alter-file-content & alter-opus-header methods.
  • Removed obsolete edit-replaygain-info menu command since Properties dialog does the same now.
  • Added an option to disregard mouse back/forward buttons (by default mapped to previous/next track).
  • Double clicking a line in Properties album art tab now opens a fullsize image viewer.
  • Fileops & Converter: Added alternate handling of invalid filename characters, toggled in Advanced Preferences.
  • Freedb component updated: now queries all configured servers and displays results grouped by server.
  • Updated File Operations & Converter file name pattern picker dialog, now auto selects current pattern on open if possible.
  • CDDA reading no longer requires admin privileges on Windows Server.
  • Updated autoplaylist editing dialogs, made resizable.
  • Standard DSP Array is no longer an optional component, as it's required for new WASAPI output to work correctly.
  • Converter: Added a toggle for encoding thru temp folder to custom command-line encoder setup, required for some encoders that don't support Unicode.
  • Added alternate menu commands for opening Properties dialog with specific tab open, for mapping keyboard shortcuts only.
  • Improved recovery from unplugged audio output device.
  • Additional editable Properties ReplayGain tab summary fields.
  • Fixed crash when trying to alter gain on a Matroska file with no recognized audio track.
  • Fixed incorrect handling of folder/file.ext relative paths in playlists served over HTTP/HTTPS/FTP.
  • New portable install puts all configuration data in 'profile' subfolder of install folder instead of saving in the installation folder directly. Doesn't affect upgraded installs or non-portable.
  • Fixed 'remove tags' not correctly stripping tags from raw AAC files.
  • Fixed ZIP reader memory leak.
  • Improved handling of last modification times in ZIP and RAR archives.
  • Fixed a bug causing high CPU usage with autoplaylists that are force-sorted but with no pattern specified.
  • Fixed installer incorrectly labelling some components as incompatible, if they have been installed by copying DLLs manually.
  • Fixed incorrect handling of ID3 itunescompilation=0.
  • Fixed a bug causing files with very long names inside ZIP archives to be unplayable.
Автор темы, Администратор
Сообщение #2 AHAPXICT » 30.06.2020, 14:42
Усё - приехали...
С нами: 12 лет 3 месяца
Сообщение #3 VEG » 30.06.2020, 17:02
AHAPXICT, это вы чему так огорчились? Переход на WASAPI давно планировался для версии 1.6. WASAPI не существует на Windows XP, так что отказ от этой версии ОС тоже понятен. Возможно было, конечно, сделать автооткат на DirectSound, если плеер запущен на XP, но наверняка автор foobar2000 пожелал использовать более новые инструменты разработке тоже. Компилятор VC++ в версии 2019 года лишился поддержки XP.
Сообщение #4 AHAPXICT » 30.06.2020, 17:23
VEG, ну, "чейндж-лог" с первого пункта уже говорит о многом, но это меня совсем не взволновало. Скачал, установил, а вот тогда - приехали. Это у кого там в сборках UI Hacks стоит? :biggrin:
Не. Новая идея. Написать автору что, новая версия плеера вызывает проблемы в работе компонента foo_ui_hacks и срочно необходимо исправление в следующей бета версии :clap: !
Сообщение #5 postED » 30.06.2020, 17:38
AHAPXICT, Какие претензии к Петеру? Ему абсолютно незачем подстаиваться под полтора пользователя компонента, который давно уже заброшен разработчиком. Берите исходники foo_ui_hacks у DRON'а, становитесь мейнтейнером компонента, правьте совместимость.
VEG:Возможно было, конечно, сделать автооткат на DirectSound, если плеер запущен на XP
Не думаю, что стоит тянуть совместимость и дальше - версии 1.5.5 с головой хватит на систему, которую признали устаревшей шесть лет назад)
Сообщение #6 VEG » 30.06.2020, 17:48
Ну у foo_ui_hacks какие-то проблемы с совместимостью были уже с версии 1.4. Там используются недокументированные особенности внутреннего устройства плеера, так что оно по-хорошему должно под каждую новую версию плеера затачиваться отдельно. Поэтому автор плеера и против такого подхода - если компонент перестанет поддерживаться, он со временем сломается, потому что внутреннее устройство программы может со временем меняться. Намеренно совместимость UI Hacks никто не ломает. К слову, я проверил пару функций UI Hacks - у меня работают. Поэкспериментируйте, определите что именно сломалось, и просто не включайте ту опцию.
Сообщение #7 postED » 30.06.2020, 18:05
А вот это хорошо, годно, потестируем) Надеюсь в будущем Петер завезет поддержку свежайших AVIF и JPEG XL, которые значительно превосходят jpeg по соотношению размер/качество.
Сообщение #8 AHAPXICT » 30.06.2020, 18:17
VEG, я всё понимаю, вы спросили, я ответил добавив немного иронии. Для меня последняя версия выпущена.
postED:AHAPXICT, Какие претензии к Петеру? Ему абсолютно незачем подстаиваться под полтора пользователя компонента, который давно уже заброшен разработчиком. Берите исходники foo_ui_hacks у DRON'а, становитесь мейнтейнером компонента, правьте совместимость.
А вот такие советы мне раздавать не надо.
Сообщение #9 str » 01.07.2020, 20:29
VEG:Double clicking a line in Properties album art tab now opens a fullsize image viewer.
а вот мне это не нравится. привык двойным кликом по альбум арту открывать папку с альбомом/файлом, который играет, там обложки поглазеть, лог какой почитать, копирнуть по-быстрому.
str M
Сообщение #10 iPhoneSasuke » 02.07.2020, 21:50
Пропатчил свою сборку до 1.6.0b2. Ничего не слетело, всё работает. Уже на этом спасибо. Наконец-то WASAPI по-умолчанию и бардак в интерфейсах (Output) стал по-скромнее. В практической части для «чисто музыку слушать» отличий не заметил. Я считаю, что плееру нужно причесать функции и удалить дубли. Например, кнопка Tagging стала рудиментарной: её функционал полностью поглощается через Properties. Можно эту кнопку убрать? М.б. это плагин?
Далее: можно ли сделать поддержку по умолчанию всех актуальных кодеков? APE, TAK и т.д. Как-то смешно в 2к20 году это реализовывать через отдельные плагины.
iPhoneSasuke M
С нами: 11 лет
Сообщение #11 Azaza » 02.07.2020, 22:42
str:а вот мне это не нравится. привык двойным кликом по альбум арту открывать папку с альбомом/файлом, который играет, там обложки поглазеть, лог какой почитать, копирнуть по-быстрому.
Поведение при двойном щелчке на картинку в UI-элементе Album art viewer не изменилось вообще-то. Речь шла о Properties, где раньше ничего не происходило при двойном клике на картинку.
iPhoneSasuke:Например, кнопка Tagging стала рудиментарной: её функционал полностью поглощается через Properties. Можно эту кнопку убрать? М.б. это плагин?
Пункты контекстного меню с незапамятных времён включаются/отключаются через File->Prefrences->Disaplay->Context menu
iPhoneSasuke:можно ли сделать поддержку по умолчанию всех актуальных кодеков? APE, TAK и т.д.
С нами: 9 лет 5 месяцев
Сообщение #12 Гармонист » 10.07.2020, 12:21
Наверно имеет смысл с ASIO перейти на WASAPI?
Правильно я думаю...
1. установить 1.6
2. удалить плагин ASIO
3. в Output выбрать WASAP
А драйвер ASIO4all будет работать? Этот драйвер рекомендован документацией ЦАПА AUDIOLAB 8200DQ
Гармонист
Сообщение #13 Azaza » 10.07.2020, 18:29
Гармонист:Наверно имеет смысл с ASIO перейти на WASAPI?
1. установить 1.6
Перейти на WASAPI всегда имело смысл. Но то WASAPI, что есть в 1.6 "из коробки" - это WASAPI shared, а не exclusive.
Сообщение #14 postED » 10.07.2020, 23:03
btw, переход на WASAPI Shared должен улучшить стабильность плеера под Wine.
Сообщение #15 iPhoneSasuke » 10.07.2020, 23:41
А вот, дяденьки... У меня через WASAPI не работает цифровой транспорт (точнее, ничего не видит). Карта E-MU 0404, со всеми канонами установки драйверов.
Работает только из-под ASIO. Причем, что меня удивляет: если воткнуть в ЦАП Parasound D/AC1600HD и оптику, и коаксиал, то ЦАП подает именно через то, что выберешь на его селекторе входов. Если отсоединить кокосовый кабель и выбрать coax, то звука нет. Подключишь кабель - звук появляется. Причем это всё через ASIO, которое не дает выбрать какой-то конкретный вывод, когда оба подключены.
iPhoneSasuke M
С нами: 11 лет
Сообщение #16 vladj » 11.07.2020, 00:25
Гармонист:А драйвер ASIO4all будет работать? Этот драйвер рекомендован документацией ЦАПА AUDIOLAB 8200DQ
ASIO4all, этот костыль суррогатный рекомендуют на то железо, которое аппаратно не поддерживает ASIO. И что спрашивать... взял и попробовал ?
Сообщение #17 Azaza » 11.07.2020, 00:34
iPhoneSasuke, Creative же так и не осилил написание нормальных драйверов для e-mu под современные windows.
Сообщение #18 Гармонист » 11.07.2020, 13:46
vladj:ASIO4all, этот костыль суррогатный
Вы можете это утверждение заполнить конкретикой?
Гармонист
Сообщение #19 seriousstas » 11.07.2020, 13:55
статейка (5 лет назад)
С нами: 11 лет
Сообщение #20 iPhoneSasuke » 11.07.2020, 16:50
Azaza:Creative же так и не осилил написание нормальных драйверов для e-mu под современные windows.
А в ZXR?
iPhoneSasuke M
С нами: 11 лет
Вернуться в Новости плеера
