foobar2000 v1.6.0
Сообщение #1 VEG » 30.06.2020, 14:07
Вышла финальная версия foobar2000 v1.6.0! Предыдущая версия: foobar2000 v1.5.5.
  • Changed system requirements: Windows 7 and a processor with SSE2 instruction set. Windows XP is no longer supported.
  • Default output mode is now WASAPI shared.
  • New fading capability that works with alternate output modes.
  • Default archive reader now supports 7-zip format.
  • Added support for WebP album covers (Default UI, Properties dialog). Settings need to be changed to look for folder.webp instead of folder.jpg.
  • Removed mixer volume sync feature due to bugs.
  • Cleaned up foo_rgscan alter-file-content & alter-opus-header methods.
  • Removed obsolete edit-replaygain-info menu command since Properties dialog does the same now.
  • Added an option to disregard mouse back/forward buttons (by default mapped to previous/next track).
  • Double clicking a line in Properties album art tab now opens a fullsize image viewer.
  • Fileops & Converter: Added alternate handling of invalid filename characters, toggled in Advanced Preferences.
  • Freedb component updated: now queries all configured servers and displays results grouped by server.
  • Updated File Operations & Converter file name pattern picker dialog, now auto selects current pattern on open if possible.
  • CDDA reading no longer requires admin privileges on Windows Server.
  • Updated autoplaylist editing dialogs, made resizable.
  • Standard DSP Array is no longer an optional component, as it's required for new WASAPI output to work correctly.
  • Converter: Added a toggle for encoding thru temp folder to custom command-line encoder setup, required for some encoders that don't support Unicode.
  • Added alternate menu commands for opening Properties dialog with specific tab open, for mapping keyboard shortcuts only.
  • Improved recovery from unplugged audio output device.
  • Additional editable Properties ReplayGain tab summary fields.
  • Fixed crash when trying to alter gain on a Matroska file with no recognized audio track.
  • Fixed incorrect handling of folder/file.ext relative paths in playlists served over HTTP/HTTPS/FTP.
  • New portable install puts all configuration data in 'profile' subfolder of install folder instead of saving in the installation folder directly. Doesn't affect upgraded installs or non-portable.
  • Fixed 'remove tags' not correctly stripping tags from raw AAC files.
  • Fixed ZIP reader memory leak.
  • Improved handling of last modification times in ZIP and RAR archives.
  • Fixed a bug causing high CPU usage with autoplaylists that are force-sorted but with no pattern specified.
  • Fixed installer incorrectly labelling some components as incompatible, if they have been installed by copying DLLs manually.
  • Fixed incorrect handling of ID3 itunescompilation=0.
  • Fixed a bug causing files with very long names inside ZIP archives to be unplayable.
Автор темы, Администратор
С нами: 13 лет 11 месяцев
Сообщение #21 VlaKor » 11.07.2020, 18:00
seriousstas:статейка (5 лет назад)
Ага, ещё можно вот это посмотреть и будет полный экстаз https://youtu.be/JzWMwcy7R88
VlaKor
С нами: 8 лет 6 месяцев
Сообщение #22 Azaza » 11.07.2020, 18:03
своем режиме по умолчанию (WASAPI Shared) является деструктивным для музыки. Звук теряет в достоверности и близости к оригиналу. Безвозвратно исчезает множество деталей. Нарушается частотный баланс и творятся прочие непотребства. В сухом остатке мы получаем абсолютно непригодный для Hi-Fi системы протокол.
Автор "забыл" привести результаты слепых тестов для подтверждения своих слов.
Сообщение #23 iPhoneSasuke » 11.07.2020, 21:32
Azaza:Creative же так и не осилил написание нормальных драйверов для e-mu под современные windows.
Внезапно и случайно узнал, что всё-таки умеет. Ковырял цифровые выходы — только ASIO. А тут поставил Default (а это в 1.6.0 WASAPI): Динамики и звук идет... Аналоговыми кабелями к колонкам подключен внешний ЦАП. Хоть и понимаю, что по идее я подаю аналоговый сигнал... Но тут фишка такая: E-MU всегда подает сигнал по всем каналам (в смысле входам и выходам), а раз я для проверки удалил ASIO и оно работает, значит работает через WASAPI.
iPhoneSasuke M
С нами: 11 лет 3 месяца
Сообщение #24 sever2k » 14.07.2020, 22:31
Здравствуйте, подскажите где же здесь WASAPI?
sever2k
С нами: 8 лет 7 месяцев
Сообщение #25 postED » 14.07.2020, 22:55
sever2k, второй и третий. Null - выход вникуда (используется разрабочиками для тестирования или отладки)
Сообщение #26 vladj » 14.07.2020, 22:58
iPhoneSasuke:а раз я для проверки удалил ASIO и оно работает, значит работает через WASAPI
Работает-то работает, но высапи расшаренный как я понимаю. Проверка возможна только на цапе иницирующем частоту или на ресивере.
PS. как и ожидалось на расшаренном WASAPI ресэмпл, выкинул и поставил обычный. Юзать эту версию плеера без плагина от Дрона смысла не вижу.
Сообщение #27 sever2k » 15.07.2020, 08:53
postED, Понятно, спасибо.
sever2k
Сообщение #28 iPhoneSasuke » 15.07.2020, 17:45
vladj:Работает-то работает, но высапи расшаренный как я понимаю. Проверка возможна только на цапе иницирующем частоту или на ресивере.
Кстати да... Лажа какая-то получилась. У моего внешнего цапа есть автомат переключения частоты 44.1 и 48 KHz, и при переключении срабатывает реле. А сейчас на постоянке 48 KHz вне зависимости от музыкального файла.
Жду приезда Creative ZxR.
vladj:PS. как и ожидалось на расшаренном WASAPI ресэмпл, выкинул и поставил обычный. Юзать эту версию плеера без плагина от Дрона смысла не вижу.
Обычный это какой? foo_wasapis?
iPhoneSasuke M
Сообщение #29 vladj » 15.07.2020, 18:59
iPhoneSasuke:Обычный это какой?
WASAPI, а не WASAPI shared, который ресэмплит.
Сообщение #30 iPhoneSasuke » 15.07.2020, 19:26
vladj:WASAPI, а не WASAPI shared, который ресэмплит.
https://www.foobar2000.org/components/view/foo_out_wasapi
Этот? Который не умеет микшировать звуки? Либо кино смотри, либо музыку слушай.
iPhoneSasuke M
Сообщение #31 Azaza » 15.07.2020, 21:37
iPhoneSasuke:А в ZXR?
В ZxR, кстати, автомат частоты работает под WASAPI (exclusive, естественно), но не работает под ASIO.
Сообщение #32 vladj » 15.07.2020, 22:30
iPhoneSasuke:Этот? Который не умеет микшировать звуки? Либо кино смотри, либо музыку слушай.
Или шашечки или ехать, для кино есть свои плееры с очень богатыми настройками по звуку и по видео.
Сообщение #33 iPhoneSasuke » 15.07.2020, 23:09
vladj:Или шашечки или ехать, для кино есть свои плееры с очень богатыми настройками по звуку и по видео.
Я MPC юзаю. Если захочу сделать паузу походу просмотра анимы и послушать музыку, то фубар отберет себе звуковой поток, а потом, пока стоп не нажму и MPC не перезапущую, звук в видео не воспроизведется. Ужасно геморрно. Вроде же в теме по Wasapi обсуждали, что shared ок и ничем кроме расширенного функционала не отличается?
iPhoneSasuke M
Сообщение #34 vladj » 16.07.2020, 13:22
iPhoneSasuke:Вроде же в теме по Wasapi обсуждали, что shared ок и ничем кроме расширенного функционала не отличается?
Ткни ссылку на место где обсуждали, в теме плагинов по расшаренному пусто. Может у меня вин 7 виновата, что не вижу преимуществ, одни недостатки.
iPhoneSasuke:Ужасно геморрно.
Можно подумать , что каждые 5 минут туда-сюда перескакиваешь. Да и какой гемор пару раз кнопку на мыше нажать ?
Сообщение #35 iPhoneSasuke » 16.07.2020, 14:00
vladj:Ткни ссылку на место где обсуждали, в теме плагинов по расшаренному пусто.
М.б. затерялось в обсуждениях старых версий плеера... Но точно был разговор о том, что изначально был Shared, позже появились Executive, но в фубере реализация была в обратном порядке, а вообще wasapi to wasapi рознь, а exclusive просто неудобный.
vladj:Можно подумать , что каждые 5 минут туда-сюда перескакиваешь. Да и какой гемор пару раз кнопку на мыше нажать ?
Ну если серию где-нибудь в середине поставил на паузу, и так каждые минут 15-20... Или принимаешь вызов в дискорде, а фубар не отдает звук и т.д. Для меня это был большой головняк, а субъективной разницы не заметил.
iPhoneSasuke M
Сообщение #36 VEG » 16.07.2020, 21:38
Используйте shared и не дурите себе голову. Поставьте в системном микшере сведение с частотой дискретизации 48кГц для надёжности и радуйтесь жизни со всеми удобствами. Боязнь системного микшера - это не более чем иррациональное из мира аудиофилии (в одном ряду с аудиофильскими ethernet-кабелями за тысячи долларов для запущенных случаев).
Сообщение #37 vladj » 16.07.2020, 23:35
VEG:Поставьте в системном микшере сведение с частотой дискретизации 48кГц для надёжности и радуйтесь жизни со всеми удобствами.
Естественно кому надо поставят, но лично я забил, ибо зачем качал и слушаю альбомы с многоканалом 24/96000, стерео 24/192000. Насчёт аудиофилии не нужно ля-ля, ибо (пусть и возраст под 70) отчётливо слышу разницу.
Сообщение #38 Azaza » 17.07.2020, 00:00
Сообщение #39 vladj » 17.07.2020, 01:32
Подпись свою перечитай ("Аудиофилия - это болезнь,поражающая головной мозг"), лично я никогда не заморачивался например таким (слов-то некоторых не даже знаю) ...
Azaza:для правильной работы конвольвера (любого) частота дискретизации импульса должна соответствовать частоте дискретизации обрабатываемого сигнала (или программа должна автоматически делать ресемплинг перед конвольвером) Как это реализовано в viper, я не знаю. О том, как в Audacity создать "чистый" импульс с любой нужной частотой дискретизации
Сообщение #40 iPhoneSasuke » 17.07.2020, 01:41
Народ, ссориться ни к чему совершенно. Лучше подскажите методику, как поставить эксперимент по проверке — вот это будет разговор.
P.S. Сборка получилась настолько удачной, что ни у кого толком не к чему придраться?)
iPhoneSasuke M
Вернуться в Новости плеера
